Mister99 Posted August 29, 2023 Share Posted August 29, 2023 Hello everyone, I'm thinking of using a Canon EOS M50 because it's good value for money. I have a few questions before buying. I'd like to know if at average temperatures (like outside, so max 34 degrees in France) for fixed use (in its tripod without movement), and without ventilation after 2-3 hours of use the battery heats up or causes the camera to shut down. I've also been told that the memory card can saturate, so how often does this happen and what are the effects if it does? If it's really not worth it and doesn't work well enough for videos lasting more than 2 hours, I could change even if it hurts my wallet. That's my little question and I hope you'll answer it! Thanks a lot! Have a nice day. SRV1981 1 Link to comment Share on other sites More sharing options...
ntblowz Posted August 30, 2023 Share Posted August 30, 2023 M50 have 30min record limit so you will have to keep pressing record every 30min In terms of overheating, well when I had it I only used indoor so not sure about outdoor at 34degrees. Link to comment Share on other sites More sharing options...
Gandulf Posted September 3, 2023 Share Posted September 3, 2023 for what you seem to want to do, you will be better off with a panasonic gh5, I found them as low as 550 euro second hand what exactly are you shooting if I may ask? Link to comment Share on other sites More sharing options...
