Youtube video bad quality
JackHorror
Hallo!
I uploaded a video on youtube, and the quality is bad,
i exported the same file from AE
1) .mov (h.264) 1920x1080 25 fps 223.037 kbps
2) .mov (h.264) 1920x1080 25 fps 50.000 kbps
+ I added FilmConvert Grain and some Sharpness
I uploaded them both on youtube, i can't see that Grain it is like washed out and video as i said is bad..
Ok, why?
The basic reason:  Garbage in, garbage out.
You can use search engines to quickly find out the why and how of low-bandwidth video compression.  Understanding the technology you wish to use will ultimately make you better at it.
Higher end studios actually hire professionals to deal with this specific issue, so it's well documented across the world wide web super information highway.
Good luck!
Guest Ebrahim Saadawi
Vesku+1
Youtube seems to have a much more sophisticated compression algorithm for 4K videos compared to 1080p, try uploading a native 1080p file to youtube as a 1080p file, then try upscaling it to 4K in your NLE then upload it to youtube as a 4K video, now compare both videos when playen on YT, the 4K one has much less compression. It's just something I noticed lately.
