SRV1981 Posted October 12, 2023 Share Posted October 12, 2023 Fuji seems naturally pleasing whereas a6700 is a bit more clinical? Enjoy this guys channel Link to comment Share on other sites More sharing options...
kye Posted October 13, 2023 Share Posted October 13, 2023 2 hours ago, SRV1981 said: Fuji seems naturally pleasing whereas a6700 is a bit more clinical? Enjoy this guys channel If you learn to colour grade then your images will be nicer than either of these by a very wide margin. On camera forums it is standard practice to compare cameras using only the manufacturers LUT or some standard transform, which is a reasonable way to compare cameras, but when you go into the world of colourists and colour grading they will often break down colour grades step-by-step, and compared to the final graded image the standard 709 conversion looks like pallid anaemic garbage in comparison - even with Alexas and REDs. Seriously, buy the camera and lenses and accessories that are most compatible with your workflow and then learn to colour grade. Even if you only apply a film-emulation LUT and then adjust exposure, contrast, WB, saturation, and sharpening, you'll be creating images that absolutely smoke the standard conversions. MrSMW 1 Link to comment Share on other sites More sharing options...
Marcio Kabke Pinheiro Posted October 17, 2023 Share Posted October 17, 2023 Never recorded in log, started now with the X-S20. Will have to study a lot, because all my log gradings until now have the color quality of a Barbie cam. SRV1981, kye and MrSMW 3 Link to comment Share on other sites More sharing options...
