AnamorphClick Posted January 9, 2015 Share Posted January 9, 2015 Hey guys,My LA7200 is stuck on my lens...it only rotates. I lost the set screw and I believe the threading has been stripped. How can I fix this? Where can I find a replacement for the set screw? Been looking all over for this... Link to comment Share on other sites More sharing options...
AnamorphClick Posted January 9, 2015 Author Share Posted January 9, 2015 Does anyone know what I'm talking about? Link to comment Share on other sites More sharing options...
Rudolf Posted January 10, 2015 Share Posted January 10, 2015 What a pity...Altough I sold mine nearly three years ago I recall it was very easy to dissamble the adapter. I did this for cleaning. Therefore I would suggest to do the same in your case. I think the mounting mechanism is very simple and it is easy to check when the glass and 'mattebox'-like body is seperated. You could then trie to loosen it maybe with the gentle help of some leather or so.Good luck Link to comment Share on other sites More sharing options...
Tito Ferradans Posted January 11, 2015 Share Posted January 11, 2015 the problem is all the screws to disassembling this lens are on the back and, from what I understood at the first post, the adapter is stuck to the taking lens, right?I don't know how to help, you gotta find out the correct screw size to replace the missing one. Link to comment Share on other sites More sharing options...
