Tilt Shift video ?
bobodude
If you are looking for the lens, the canon 24 ts-e ii is the best one, there is no way around it (the samyang would be the cheap option). For 45mm the nikon seems to be better, but at that focal length you can use shift adapters and medium format lenses which is way cheaper and which opens up a whole new world of cheap great optics. There is also the canon ts-e 17mm which is pretty amazing if you think of it (rectilinear, 17mm, big image circle...).
If you want it to shoot people, a simple camera pan/tilt with a normal lens is better as it doesn't give them strange deformations.
thanks, for all the info !
i've looking at tilt shift adapter for a while, and found some interesting options,
this one looks pretty cool, but is the most expensive, anyone have any experience with it ?
http://www.cambo.com/Html/products_p...roup34297.html
I'm using this for perspective and dof control:- https://www.flickr.com/photos/melting_bloke/sets/72157641407451984/
using the sony A7S and rollei medium format lenses.
this was shot with it:- https://vimeo.com/103970668
