revello Posted January 27, 2015 Share Posted January 27, 2015 Hi community,I got myself a Panasonic FZ1000 to shoot a promotion film of hot-air ballooning in the Austrian Alps.Since the FZ1000 will be my A-cam I am looking for the right ND-filter. Budget is very modest so I have to stick with a fixed ND.condition: I expect a lot of snowy mountains, sun and overcast weather, shooting only in daylight. Also I'll probably film through the whole zoomrange. 4k.I am doubting between 3stops (ND8) and 6stops (ND64). I am anxious 3 stops won't do the trick with all the snow reflecting and when shooting 35mm.Any advices?Kind regards,Florian Link to comment Share on other sites More sharing options...
animan Posted January 27, 2015 Share Posted January 27, 2015 Its a good question, Ive used a ND8 solely in bright conditions before with a GH3 and 12-35 2.8 and it was almost always enough, sometimes I wished it was a touch darker, if possible and if you really only can afford one I would look for something in between (16 or 32), with the FZ1000 lens being slightly slower then you should be fine. Link to comment Share on other sites More sharing options...
revello Posted January 27, 2015 Author Share Posted January 27, 2015 Thanks a lot Animan, Your answer made me reconsider! Link to comment Share on other sites More sharing options...
JazzBox Posted January 28, 2015 Share Posted January 28, 2015 In one of the last video I shot I had a problem in a couple of shots: some "ghosts" in one take and an horrible "moire-like" in another one.This was thanks to the ND filter: I had a Tiffen (120 € more or less) and it screwed up my images... Before that Tiffen I had an Hoya (same problems) and a variable 100 € ND...From that day I stopped to use ND at all: I do my best to shot in the magic hour or with a higher shutter angle. p.s.: Revello, I read "Crete"... wow you are lucky, I had the best food in my life in Vamos at Parasia Rakadiko! Not to talk about the amazing beaches (Elafonisi, Marathi, Balos, Gramvousa...) Link to comment Share on other sites More sharing options...
revello Posted January 29, 2015 Author Share Posted January 29, 2015 Hi JazzBox,Great to hear you enjoyed Crete, Vamos.... that's very close to where they shot the film "Zorba the Greek"!. But I see you came around, ...yeah Elafonisi is fantastic!I am not a native Cretan though, just taking time off to get some projects done ;-)Thanks for your "experience-talking", in the end I ended up buying a 10€ china ND filter, variable. If it doesn't work out then it's just 10€, after your post I am even less willing to buy an expensive one.Cheers!! JazzBox and Cinegain 2 Link to comment Share on other sites More sharing options...
Cinegain Posted January 29, 2015 Share Posted January 29, 2015 Yeah, I was gonna suggest that. Fotga makes decent filters. I had one 62mm that I used on the 14-140mm back in the day with the GH2 that works pretty okay. They go for very cheap on eBay. If you're on a bit of a budget and pick the FZ1000 over an interchangeable lens system, I already take you expect your audience not to pixel peep that much.Because it's a variable ND, so you might run into some weird behaviour (saturation, reflections, patterns), especially stopped down close to the maximum, but otherwise, it doesn't even lose that much sharpness. Color is ok too. Gives you a bit more flexibility, on-the-go control and ease of use. JazzBox 1 Link to comment Share on other sites More sharing options...
