Canon G1X - compacts go pro
[html]
[img]http://www.eoshd.com/wp-content/uploads/2012/01/canon-g1x-announced.jpg[/img]
Once again the rumours were right and the no-show of Canon’s G12 successor has been explained by the appearance of a pro-compact with much larger 1.5 inch sensor and DIGIC 5. Rather than just cut and paste the press release like so many blogs do, I’ll take a deeper look at what this all means.
[url="http://www.eoshd.com/content/6723/canon-g1x-compacts-go-pro/"]Read full article[/url]
[/html]
I still don't quite believe those specs. Why make a slightly bigger sensor instead of using the same one as the S100? Really, 1/1.5" is just marginally bigger and won't give any real advantage in S/N ratio or control over depth of field (especially with slower lens than the smaller and cheaper S100).
But it it's a 1.5" sensor (or 1.5 crop factor) then it means APS-C size. Again, why not use the same sensor that they use for DSLRs in that case? And with such sensor, how to make a 4x zoom starting at f/2.5 that's small enough for such type of camera?
I think we should wait for official announcement to be sure of what this is.
I know I'm nitpicking but you made a typo at the end of the article:
"2012 is going to be a big year for Canon product releases, with the 1Dx and G1x followed by the [u]5D Mark II[/u], 650/700D and possibly even the 4K Cinema EOS camera, mirrorless system and 7D Mark II by the end of the year."
Should be Mark III no? :D
