OS EIs there any way to adapt a Micro 4/3 lens to EF Mount?
marfinites
Guest Ebrahim Saadawi
M43 to EF is not possible. The distance between the mount & the sensor on the 70d is longer than m43s, meaning, the m43s lens needs to get closer to the sensor, which is impossible without taking the camera apart...
While the above is true, you may be able to get some interesting ultra-macro effects by just holding the lens (carefully) in front of your camera. You'll get super super shallow DOF and tons of light leaks that will make it unusable for any kind of client work, but those lenses aren't exactly the kind you'd use for that kind of work anyways.
