norliss Posted February 11, 2015 Share Posted February 11, 2015 I've built up a collection of C/Y mount Zeiss Primes (with one zoom) but currently don't have a proper box in which to keep them.I was looking at Peli/Pelican cases but read all sorts of things about the little bits of foam getting in the lenses, the foam containing gases, that they shouldn't be kept in there for anything other than brief transportation etc.Can anyone recommend any quality, sturdy storage & transportation solutions for my glass?Thanks! Link to comment Share on other sites More sharing options...
pablogrollan Posted February 11, 2015 Share Posted February 11, 2015 Hi Norliss,I have mine in a Pelican with foam and have had no such issues. Still, if you don't like foam you could still use the same pelican cases with dividers. Link to comment Share on other sites More sharing options...
M Carter Posted February 11, 2015 Share Posted February 11, 2015 I really don't understand why anyone uses foam vs. dividers... yes, dividers cost a bit more in most cases, but you can quickly reconfigure the case when you upgrade or for specialty gigs. Pelican (and SKB makes cases which are pretty much knockoffs but a bit bigger for each class, and Nanuk makes nice ones as well) are investment-type cases. You'll own them long after you've sold the gear you kept in them. I think replacement foam for the 1550 is like $60. I've found it breaks down after a few years though, but it gets hot here in TX.If money is really tight, check Craig's list of you're in a decent sized city, search things like "ATA" and "Surplus" - sometimes you can luck out. Use all kinds of search terms on eBay and check the "used" box (I found a custom-made roller case that was for a 4x5 film camera and all the holders, lenses, etc for $100 with dividers - it's my main camera case now for motion gigs, was probably $600 new, holds a fully rigged camera, all my NDs, and main-squeeze lenses). There's military cases, military-spec pelicans, all kinds of stuff. Link to comment Share on other sites More sharing options...
studiodc Posted February 11, 2015 Share Posted February 11, 2015 Trekpak makes fantastic dividers which are WAY nicer than the velcro+foam ones. I also second M Carter's suggestion to avoid foam. My recommendation is the Pelican 1510 case with the Trekpak divider kit. It's fully carry-on legal nearly everywhere (including the European value airlines, from direct personal experience), it's got wheels when you've got a ways to go, it's not so heavy by itself, and it's absolutely durable. I love mine, and with the lid organizer, it's held an entire guerrilla shoot's worth of gear multiple times, including lenses, bodies, led lights, batteries, tools, pretty much everything except the tripod.And I can't say enough good things about Trekpak's gear organization. I have a Trekpak system in every single case i own, now. Worth every cent. Not paid, sponsored, or otherwise benefitting for me saying this, just a happy customer. Link to comment Share on other sites More sharing options...
JazzBox Posted February 11, 2015 Share Posted February 11, 2015 HPRC is a very good alternative to Pelican and you can configure them with foam or with divisors etc...http://www.amazon.it/HPRC-custodia-bauletto-fotocamera-digitale/dp/B00JJU5Q4C/ref=sr_1_4?ie=UTF8&qid=1423671998&sr=8-4&keywords=hprcOne of the case I own:http://www.plaber.com/2500.htmbut they produce a lot of different cases:http://www.plaber.com/2530.htm Link to comment Share on other sites More sharing options...
M Carter Posted February 12, 2015 Share Posted February 12, 2015 ...and SBK makes a pretty direct knockoff the the everyone's-favorite-carry-on Pelican, $20-$30 cheaper. Link to comment Share on other sites More sharing options...
norliss Posted February 13, 2015 Author Share Posted February 13, 2015 Thanks for the replies. I think dividers are probably better than foam although I only want this purely for lenses not a camera and other items, so I need to find a suitable divider insert. Link to comment Share on other sites More sharing options...
