Turboguard Posted March 2, 2015 Share Posted March 2, 2015 I've talked about this before on the forum, and have since tried multiple solutions (incl. one from Philip Bloom).But it NEVER works. My latest try was like this;1. Shot a short 1min sequence on the Blackmagic Pocket in RAW.2. Opened the sequence in Adobe Bridge and accessed the Camera Raw feature.3. Colored one frame, selected all and synchronized. Now they all look the same in Bridge but not in preview mode on my mac nor in Premiere Pro.4. Opened Bridge again but this time in Camera Raw saved all my frames as .TIFF (with Adobe RGB (1998)), put them in a new folder.5. Imported first frame into Premiere Pro just like I do with DNG to get my sequence but now only the frame shows up as a single frame in Premiere Pro. What am I doing wrong? Why doesn't it work? The reason why I want ACR to work is because I love the fast workflow and also access to Chroma Noise reduction. I can't afford DaVinci Resolve and I think the workflow with it takes more time any way. Has anyone every gotten this to work? If so, how? I'm out of options and so extremely upset with nothing working out for me.Thanks Link to comment Share on other sites More sharing options...
Jimmy Posted March 2, 2015 Share Posted March 2, 2015 re: 5) there should be a check box "import images as a sequence" or something like that. Link to comment Share on other sites More sharing options...
Turboguard Posted March 2, 2015 Author Share Posted March 2, 2015 Oh my god, it worked! Thank you so much Jimmy!One more question, about the wav file. Do I just have to add it manually after or is there some other trick to it?Again, what a relief, thanks so much! Jimmy 1 Link to comment Share on other sites More sharing options...
Jimmy Posted March 2, 2015 Share Posted March 2, 2015 yea, just bring it in manually and sync it up to the start of the raw sequence. There might be a simpler way, but that is what I do also. Link to comment Share on other sites More sharing options...
sam Posted March 3, 2015 Share Posted March 3, 2015 I've talked about this before on the forum, and have since tried multiple solutions (incl. one from Philip Bloom).But it NEVER works.Glad you got it!If you have more than just a couple of Dng folders to process for your project, there is a faster and very easy way to use Adobe Camera Raw compared to the Adobe Bridge route I shared in your previous thread. 1. Open AE, then click File> Scripts> Run script file> browse to the location of the Immigration script, select it and click ok.2. A window opens and you simply browse to the location of your dng folders and double click. Let the script do its work and then select the dng folders you wish to import.You will get to use ACR on each file and have them ready to go for either immediate use in AE or simply select all and send to Render Queue for export.You will need to download the Immigration script http://aescripts.com/immigration ( free unrestricted for more than a month I believe. Link to comment Share on other sites More sharing options...
andrgl Posted March 3, 2015 Share Posted March 3, 2015 I can't afford DaVinci Resolve and I think the workflow with it takes more time any way. Resolve Lite is free. (Exactly the same features as the regular version, minus noise reduction and some 3D stuff.)Adobe Camera Raw is absolutely primitive. Think about it: you're grading a single frame in ACR. In Resolve you're able to grade the entire sequence. Practice using Resolve a few minutes a day. Link to comment Share on other sites More sharing options...
sam Posted March 3, 2015 Share Posted March 3, 2015 The workflow may be primitive, but the results aren't. Before the release of Resolve 11.2 (less than a month ago) in which the debayering process was updated, ACR certainly provided an optimal debayer for the BM, ML, and fs700/CD raw files (can't speak for other raw files) as well as easy lens and perspective correction without plugins, plus grain and noise control. Anyways, both are great products intended for different purposes. I prefer Resolve though and agree with andrgl that with a little practice you will be far happier with Resolve for motion. Raw debayer after (top) and before (bottom) Resolve 11.2 More info http://vanhurkman.com/wordpress/?p=3208 (these are his images) andrgl 1 Link to comment Share on other sites More sharing options...
andrgl Posted March 3, 2015 Share Posted March 3, 2015 The workflow may be primitive, but the results aren't. Before the release of Resolve 11.2 (less than a month ago) in which the debayering process was updated, ACR certainly provided an optimal debayer for the BM, ML, and fs700/CD raw files (can't speak for other raw files) as well as easy lens and perspective correction without plugins, plus grain and noise control. Anyways, both are great products intended for different purposes. I prefer Resolve though and agree with andrgl that with a little practice you will be far happier with Resolve for motion. Raw debayer after (top) and before (bottom) Resolve 11.2 More info http://vanhurkman.com/wordpress/?p=3208 (these are his images)Maybe primitive was the wrong word to use. I agree ACR has great features that are way more accessible. Resolve is overwhelming but incredibly powerful. It's also becoming easier to use with each update. Thanks for the blog post. Link to comment Share on other sites More sharing options...
