JaeM Posted March 6, 2015 Share Posted March 6, 2015 Hi there,Can I please get some opinions on what I should rent each of the following 4 packages out at,per day and per week,in US Dollars?Many thanks.ISCORAMA 36 with fitted 0.8 pitch focus gear ringIsco-Nikon-mount f2.8 body & EOS adapter Tokina +0.4 72mm Achromatic DiopterSLR Magic +.033 77mm Achromatic Diopter + Heliopan Step-ringSLR Magic +1.33 77mm Achromatic Diopter + Heliopan Step-ring0.43x 72mm Wide Angle adapter+1,2,4&10 72mm Diopters (Cheap)Redstan ClampStep-rings for most common taking-lens sizesPelican CaseISCORAMA 42 MC with fitted 0.8 pitch focus gear ringRedstan +0.25 82mm Achromatic DiopterRedstan +1 82mm Achromatic Diopter+1,2,4&10 82mm Diopters (Cheap)Redstan ClampStep-rings for most common taking-lens sizesPelican CaseISCORAMA 54 Non MC with fitted 0.8 pitch focus gear ring+0.5 95mm DiopterVoightlander Focar A 95mm DiopterVoightlander Focar B 95mm Diopter+1,2,4&10 95mm Diopters (Cheap)Redstan ClampLens Support for 15mm rails.Step-rings for most common taking-lens sizesPelican CasePENTAX SMC TAKUMAR PRIME LENS SET with EOS MountsAll de-clicked, shimmed for infinity focus, with 3d printed .8 pitch gears for aperture and focus.All but the 17mm have 80mm cine fronts17mm f424mm f3.535mm f250mm f1.4 - 7 element50mm f1.4 - 8 element55mm f1.885mm f1.8105mm f2.8135mm f2.5200mm f4+ Pelican Case Link to comment Share on other sites More sharing options...
