feanorfinwe Posted March 10, 2015 Share Posted March 10, 2015 in videorecording (firmware v1.22):i can't switch display/EVFi don't see AF area indicator in EVFi can't use SAF in EVFPlease help, are there some settings for it? Thank you. Link to comment Share on other sites More sharing options...
Brian Luce Posted March 10, 2015 Share Posted March 10, 2015 I'm not having those issues. Can firmware be reinstalled? Was your battery fully charged during the install? Link to comment Share on other sites More sharing options...
Beritar Posted March 10, 2015 Share Posted March 10, 2015 I have the V1.21 firmware and i can't do that either. Link to comment Share on other sites More sharing options...
The Chris Posted March 10, 2015 Share Posted March 10, 2015 in videorecording (firmware v1.22):i can't switch display/EVFi don't see AF area indicator in EVFi can't use SAF in EVFPlease help, are there some settings for it? Thank you.I have 1.2.2With the display/EVF, are you talking about the EVF button not switching between the LCD and EVF? If so mine works fine. I definitely have the AF indicator and SAF works fine as well . Link to comment Share on other sites More sharing options...
Beritar Posted March 10, 2015 Share Posted March 10, 2015 I have 1.2.2With the display/EVF, are you talking about the EVF button not switching between the LCD and EVF? If so mine works fine. I definitely have the AF indicator and SAF works fine as well .Do you also have the Af indicator and the possibility to switch bewteen the LCD and EVF during video recording ? Link to comment Share on other sites More sharing options...
Marco Tecno Posted March 10, 2015 Share Posted March 10, 2015 For me, the evf button is totally disabled both during recording AND during video standby. If you want to change that, you have to be in still capture mode. If there is a way to have it working during video, please let us know. Beritar 1 Link to comment Share on other sites More sharing options...
Beritar Posted March 10, 2015 Share Posted March 10, 2015 For me, the evf button is totally disabled both during recording AND during video standby. If you want to change that, you have to be in still capture mode. If there is a way to have it working during video, please let us know.It's the same for me, that's what I thought.I think Brian Luce and The Chris can switch Display/EVF only in still mode and not during video recording. Geoff CB 1 Link to comment Share on other sites More sharing options...
The Chris Posted March 10, 2015 Share Posted March 10, 2015 I misunderstood what the OP was asking, I didn't realize it was while recording, not just in video mode. Then no I can't change while recording. Its locked in when you hit record. Slightly OT, I assigned video standby mode to the preview button on the front to make it easier to jump into video mode when shooting from the EVF. Its now easier to move between stills and video for me. Link to comment Share on other sites More sharing options...
Marco Tecno Posted March 10, 2015 Share Posted March 10, 2015 Chris, this is clever, thx for the hint. I almost never use preview button, so that's a nice idea. Samsung should allow changing evf to display and vice versa through recording via evf button. There should also be a way to trigger saf while recording through evf. Link to comment Share on other sites More sharing options...
The Chris Posted March 10, 2015 Share Posted March 10, 2015 No problem, I have never used the preview button either, it sits right under my ring finger when holding the NX1, its really convenient for a useful function.I agree, you should be able to use SAF while recording. I haven't found a back-button AF function like I have with the 5d3 outside of the touchscreen. Still working my way through the manual and learning the functions of the NX1. Link to comment Share on other sites More sharing options...
Brian Luce Posted March 11, 2015 Share Posted March 11, 2015 Sorry, yes, in stills mode I can do it. Hasn't the cam always been that way? Link to comment Share on other sites More sharing options...
hk908 Posted March 11, 2015 Share Posted March 11, 2015 Not to derail this, but regarding EVF/display, I'm trying to do a night lapse of the stars over the weekend in the desert so I want to completely turn off the display to save battery. So i turned quickview off, auto display off to 30 secs (lowest) and power save to 1 min (lowest). Then I hit the EVF button to switch from display to viewfinder only. However, after all that, when I actually start the interval capture (shutter 20 secs, 5 sec interval to test) it turns on the display for a popup saying "capturing, keep camera steady" on every shot, then it keeps turning on the display in full color to show the interval countdown. Is there any way to do what I want it to? It's kind of a waste of battery the way it is. Link to comment Share on other sites More sharing options...
Marco Tecno Posted March 12, 2015 Share Posted March 12, 2015 I guess there is no way to completely turn off the display. That'd be a nice addition from samsung. hk908 1 Link to comment Share on other sites More sharing options...
hk908 Posted March 12, 2015 Share Posted March 12, 2015 Ok I guess I'll need to pick up an external battery pack to keep shooting the next day. Link to comment Share on other sites More sharing options...
Dean Posted June 7, 2015 Share Posted June 7, 2015 Is there any way around this? I'd really like to keep recording and use use SAF to lock focus on what I want and keep it there and not have the camera continually readjust focus. I realise you can use the touch screen to engage SAF, but any way to do this using the shutter button ... especially when using the EVF on a bright day? Cheers. Link to comment Share on other sites More sharing options...
