greg weisert Posted April 6, 2015 Share Posted April 6, 2015 hey guys,i own a pre-36 iscorama and have some questions. first off, i have a tokina +0.5 diopter. just to understand, how much does this diopter make the iscorama focus closer? normal it is 2 meters and with the diopter is it one meter or how do i calculate that?i'm looking for another diopter to focus even closer. can u recommend one? how about the +1 from slr magic, does it work fine with the isco?i find it somehow hard to judge focus with the isco. when i look at the peaking on my gh4 it shows up on elements even though they are nearer or more further away than the distance shown on the scalings of the isco. and sometimes things seem to be in focus but peaking doesnt really show up..maybe u have some advices for me? bestgregory Link to comment Share on other sites More sharing options...
dhessel Posted April 7, 2015 Share Posted April 7, 2015 To calculate you take the max and minimum distance and do 1/distance. So if your lens goes from infinity to 2 meters you do these calculations.1/infinity = 01/2 meters = 0.5So the isco has a 0 to 0.5 focus strength. Next you add the power of the diopter(+0.5) to these numbers, so it now goes from 0.5 to 1.0. Last you divide 1 by the new focus strength. A +0.5 diopter would be.1/ 0.5 = 2 meters maximum focus1/1 = 1 meter minumum focus distance. If you had a +1 diopter it would be1/1 = 1 meter maximum focus1/1.5 = 0.67 meters minimum focus. And so on... Link to comment Share on other sites More sharing options...
Art V. Posted August 3, 2015 Share Posted August 3, 2015 Hi Gregory...How close do you want to get? I'm using an Iscorama pre-36 for macro anamorphic still photography, using objectives from old telephoto lenses reverse mounted on the Isco compression module, used with a variety of prime lenses. I have no trouble shooting down to a working distance of around an inch, with a field width of about .5 inch. I'm not sure whether this would have any value in video production, though. As an example, the front cell (objective) from an old Soligor 450mm telephoto lens (cheap price generally, gives a field width of 5 inches at a working distance of 12 inches when reverse mounted on the Isco, used with my Nikkor-H 85mm.Art V. Link to comment Share on other sites More sharing options...
Tito Ferradans Posted August 3, 2015 Share Posted August 3, 2015 about how diopters work. pretty easy read and simple math! Link to comment Share on other sites More sharing options...
