Jimmy Posted April 9, 2015 Share Posted April 9, 2015 Frustrating news.... Canon's new codec is supported, but still no love for H265.Samsung really need to scratch Adobe's back or allow another codec via firmware. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted April 9, 2015 Administrators Share Posted April 9, 2015 Canon's "new" codec is just H.264.I am sure they are working on H.265 support but since the hardware to support it isn't really common yet, I can see why they're taking their time over it.In the meantime, EditReady is your friend. Link to comment Share on other sites More sharing options...
Jimmy Posted April 9, 2015 Author Share Posted April 9, 2015 I have tested every known convertor.... They are ok, but they introduce gamma changes that concern me.Not Adobe's fault, this is still a niche codec and probably requires untold hours of coding to perfect. Samsung really should add H264 support while this is sorted out (or scratch Adobe's back, like i'm sure RED did to get REDcode support). Link to comment Share on other sites More sharing options...
Geoff CB Posted April 9, 2015 Share Posted April 9, 2015 Um, it still might be in the new update. Just because it's not listed in the major new features doesn't mean it won't be added. Usually we don't get a full list until it's actually in the wild. Loving what I am seeing with the new Color adjustments in premiere though! Link to comment Share on other sites More sharing options...
markr041 Posted April 9, 2015 Share Posted April 9, 2015 I have tested every known convertor.... They are ok, but they introduce gamma changes that concern me.Not Adobe's fault, this is still a niche codec and probably requires untold hours of coding to perfect. Samsung really should add H264 support while this is sorted out (or scratch Adobe's back, like i'm sure RED did to get REDcode support).It is not a "niche" codec, it is a new codec. It is in fact the new standard. It is used by Netflix, for example. Samsung is just the first to use it in a camera (maybe there are others). Cyberlink added support months ago, and the specs have been available for a long time. Obviously this is Adobe's fault that they do not now support this new standard.As for adding H264 to the camera - the bitrates would have to be gigantic to achieve the same quality as the HEVC 80Mbps (more than 200 Mbps). That is the point. That bitrate would be too much for the card slot and may also cause overheating. Or we could settle for mediocre lower H264 bitrates just so we can use Adobe? Beritar 1 Link to comment Share on other sites More sharing options...
IronFilm Posted April 9, 2015 Share Posted April 9, 2015 The new Premiere has an option to export as H.265, still unknown as to if editing in it is happening or not. Geoff CB and Nick Hughes 2 Link to comment Share on other sites More sharing options...
Jimmy Posted April 9, 2015 Author Share Posted April 9, 2015 Niche just means specialised.... For a capture/edit codec, it is very much specialised .... As a deliverable, it is slowly growing, but not yet mainstream. Link to comment Share on other sites More sharing options...
Santiago de la Rosa Posted April 9, 2015 Share Posted April 9, 2015 On june AMD will probably present their new R9 390X with full hardware support for H265.I expect then some update for Vegas and Premiere supporting H265. Link to comment Share on other sites More sharing options...
markr041 Posted April 9, 2015 Share Posted April 9, 2015 On june AMD will probably present their new R9 390X with full hardware support for H265.I expect then some update for Vegas and Premiere supporting H265.Intel is already supporting H265 in hardware with its existing fourth and later-generation chips. H265 is a standard, and there is no reason to let Adobe Or Sony Vegas for that matter) off the hood for being slow to support it. Link to comment Share on other sites More sharing options...
Geoff CB Posted April 9, 2015 Share Posted April 9, 2015 The new Premiere has an option to export as H.265, still unknown as to if editing in it is happening or not. YES! At the very least that means that Media Encoder/Prelude support it. Cannot wait.Just got the GTX 960 with on board H265 decoding, really hope it's fully supported in the next update. Link to comment Share on other sites More sharing options...
DigitalEd Posted April 9, 2015 Share Posted April 9, 2015 It will take a very powerful system to handle it when they do the video will maybe play back at 3 frames a second if that with what most people have for a editing system. I think it will cost a good $1200 or so to upgrade a system to even come close to being able to handle it. So when they do have it everyone will say it dose not work well. Link to comment Share on other sites More sharing options...
Michael Ma Posted April 9, 2015 Share Posted April 9, 2015 Frustrating news.... Canon's new codec is supported, but still no love for H265.Samsung really need to scratch Adobe's back or allow another codec via firmware.Adobe explicitly lists the new XF-AVC Canon codecs just announced with their 2 new cameras. We can see that Canon is definitely scratching Adobe's back."...including new support for Avid DNxHR media, Canon XF-AVC, ProRes 4444XQ, and Panasonic 4K_HS..."Source: http://blogs.adobe.com/premierepro/2015/04/premiere-pro-next-colorful.html?scid=social43472736&adbid=884596851583649&adbpl=fb&adbpr=341657335877606 Link to comment Share on other sites More sharing options...
Julian Posted April 9, 2015 Share Posted April 9, 2015 Like Andrew says, XF-AVC is just H.264 with a fancy name, like Sony X-AVC. So Adobe hardly doesn't have to do anything to support the files. Link to comment Share on other sites More sharing options...
Jimmy Posted April 9, 2015 Author Share Posted April 9, 2015 They did with REDraw though.Back scratching goes along way. Link to comment Share on other sites More sharing options...
jcs Posted April 9, 2015 Share Posted April 9, 2015 I've been experimenting with creating 422 10-bit H.264 (ALL-I and IPB) using Photon as well as editing the files in Premiere. While the files work for the most part, the performance wasn't as high as I would expect. 444 10-bit H.264 didn't work at all. Thus, even though Canon's XF-AVC is part of the H.264 standard, NLEs may need to update their H.264 decoders to handle more parts of the spec. Link to comment Share on other sites More sharing options...
ntblowz Posted April 9, 2015 Share Posted April 9, 2015 Powerdirector from Cyberlink already support native H.265 editing, can't really see why Adobe can't. Michael Ma and IronFilm 2 Link to comment Share on other sites More sharing options...
markr041 Posted April 9, 2015 Share Posted April 9, 2015 It will take a very powerful system to handle it when they do the video will maybe play back at 3 frames a second if that with what most people have for a editing system. I think it will cost a good $1200 or so to upgrade a system to even come close to being able to handle it. So when they do have it everyone will say it dose not work well.This is just speculative nonsense. The fact is that current and last-generation Intel chips decode H265 in hardware, even Celeron chips. H265 video files play fine on cheap machines. I play them (the 80 Mbps Pro one from the NX1) smoothly, and on cheap machines (also on not cheap machines).Again, there is no excuse for Adobe not to support the H265 standard. I do not understand why it benefits anyone to defend Adobe on this even if you love their products. H265 is here; it is already supported by commonly available, cheap computers in hardware as well as one consumer software editing program natively (for a while). It is also supported in hardware by many 2015 HDTV manufacturers - just plug in your usb with H265 files and they play fine. The main reason is Netflix, which uses H265. Link to comment Share on other sites More sharing options...
Jimmy Posted April 9, 2015 Author Share Posted April 9, 2015 I'm gonna post here as Andrew closed the Philip bloom thread.... My post was ironic, due to our debate about the Clarkson stuff... You must see the irony, surely?Clarkson would have made a similar quip ;-) And yes... Assault is terrible thing and, if found guilty by none social media means, his respect will evaporate Link to comment Share on other sites More sharing options...
agolex Posted April 9, 2015 Share Posted April 9, 2015 I'm gonna post here as Andrew closed the Philip bloom thread.... My post was ironic, due to our debate about the Clarkson stuff... You must see the irony, surely?Clarkson would have made a similar quip ;-) And yes... Assault is terrible thing and, if found guilty by none social media means, his respect will evaporateShame on you for hijacking this thread! Down with everything even remotely humorous and long live the technocracy. Link to comment Share on other sites More sharing options...
Geoff CB Posted April 10, 2015 Share Posted April 10, 2015 The new Premiere has an option to export as H.265, still unknown as to if editing in it is happening or not. Do you have a source on this? Link to comment Share on other sites More sharing options...
