A mystery 3rd Blackmagic camera is coming at NAB
Guest Ebrahim Saadawi
I just hope any of these is a BM with improved low-light performance and battery life (with keeping all the great characteristics of previous cameras)
bmcc-nab-2015-mystery.thumb.jpg.1fb04b84
I just received a tidbit of info from a reader. Apparently Blackmagic have a third camera we've not seen yet on any of the posters at NAB. The show opens shortly.
Read the full article
​Maybe this gives a little credence to my theory that the products with the little blue 'New' label on Blackmagic's website will be receiving an upgrade. But no label is on the Pocket, so...
Or the black magic micro studio camera
Blackmagic Micro Studio Camera 4K
With such a small Micro Cinema Camera design, we quickly realized that if we removed the built in recorder and digital film sensor cooling and replaced with SDI connections and a 4K video image sensor, we could build a really small studio camera for live production!
The Blackmagic Micro Studio Camera 4K looks the same as the new Micro Cinema Camera but it’s really a completely different camera because its a broadcast quality Ultra HD studio camera!
Although you can use it with an external recorder as a production camera, it’s really designed to be used in live production with a live production switcher. It has an Ultra HD sensor so it works in native Ultra HD and of course with a sensor at that high resolution, it makes an incredible HD camera also!
Because it’s a live camera, it’s features are almost identical to our Blackmagic Studio Camera 4K. It has SDI in and out, a built in color corrector and all the control to the camera can be sent via the SDI input so it uses the same SDI control protocol as our studio cameras and ATEM switchers. It uses 6G-SDI, so supports all Ultra HD frame rates up to 30 fps, but it does 1080 HD frame rates up to 60 fps using the full sensor size.
It includes an expansion connector, but it’s also different. This camera has a PTZ serial connection out and this can be used for controlling a remote head. Any pan, tilt and zoom commands sent to the camera via SDI from the switcher will be output on this PTZ connection and if you have a zoomable MFT lens, it will adjust the zoom on the lens as well.
Also on the expansion connector is a B4 lens control connection so we can control broadcast lenses. We have been asked for this a lot by high end broadcasters and now with this camera and the B4 lens connection you can use add accessories to turn this camera into a fully featured studio camera. Imagine using it as a full sized studio camera with external monitor and broadcast lens. Or using it on set concealed so you can get all kinds of exciting and interesting camera angles!
The Blackmagic Micro Studio Camera 4K will be available in July for $1,295.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
