Jedi Master Posted January 20, 2024 Share Posted January 20, 2024 17 hours ago, kye said: If it keeps failing I think I'll look up what unix commands I can use to compare the files, I'd imagine there's a unix utility that will compare two folders and give me a nice report listing all the failures. Beyond Compare is what most people where I work use. There's a Mac version available. Link to comment Share on other sites More sharing options...
Jedi Master Posted January 20, 2024 Share Posted January 20, 2024 7 hours ago, kye said: So, I realised that it kept failing on these files beginning with "._" I realised that they were actually there, despite Finder not showing them to me when I put it into the mode for showing hidden files, so it was only the command line that revealed their existence. All UNIX, and UNIX-derived, systems hide files with names starting with "." from directory searches. You can see these using ls on the the command line with "ls -a" (or "ls -al" if you want more detail). Link to comment Share on other sites More sharing options...
ac6000cw Posted January 20, 2024 Share Posted January 20, 2024 2 hours ago, Jedi Master said: Beyond Compare is what most people where I work use. There's a Mac version available. +1 for Beyond Compare. Link to comment Share on other sites More sharing options...
IronFilm Posted January 22, 2024 Share Posted January 22, 2024 On 1/21/2024 at 12:04 AM, kye said: We might be closer to Adelaide than you are to Sydney, but have you been to Adelaide? From any kind of perspective it's a non-place, so I'd rather be slightly further away from Sydney! Still much better than any other non-Auckland place in New Zealand! kye 1 Link to comment Share on other sites More sharing options...
