IronFilm Posted December 3, 2024 Share Posted December 3, 2024 6 hours ago, eatstoomuchjam said: That or just wait for somebody like Duclos https://www.ducloslenses.com/products/mk-fz-kit OUCH! $500 so that I can use it on my Sony PMW-F3 😞 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted December 3, 2024 Share Posted December 3, 2024 1 hour ago, IronFilm said: OUCH! $500 so that I can use it on my Sony PMW-F3 MTF services are a lot more affordable, on the other hand. https://mtfservices.com/products/fuji-mk-lens-conversion-from-e-to-sony-fz-mount?_pos=1&_sid=b99bda7ff&_ss=r Pair that with a used price of about $1,400-1,500 each for the 18-55 and the 50-135 and you've got a $3.5k T2.9 lens set covering everything from 18-135mm (depending on sensor size, that's 24-27mm on the wide end and 180-200mm on the long end). Oh yeah, and each lens is fully parfocal (after about a 5 minute back focus calibration) and has 0 breathing. Oh, and the image is beautiful with great falloff and smooth bokeh, and imo it's sharp without being clinical, but also keep in mind that I've used mine exclusively on a Komodo-X which has OLPF which renders most lenses less clinically sharp than they really are. 😅 The only real drawbacks that I've found so far are that using the macro switch might knock my backfocus adjustment slightly out of whack (I still need to verify, but it seems to be the common factor in both cases - both times, I still had usable images, but with the focus noticeably slightly off) and that on the K-X, I have to take off the hood when using any lens wider than around 22mm or I'll get a hard vignette in the corners. With the hood off, there's plenty of coverage. Anyway, IMO a used MK set is the best value in cinema nowadays. And shoots are going a lot faster without me swapping primes every 20 minutes. 😅 IronFilm 1 Link to comment Share on other sites More sharing options...
JulioD Posted December 5, 2024 Author Share Posted December 5, 2024 On 12/3/2024 at 12:16 AM, IronFilm said: Many decades ago Nikon made cinema lenses. Not really. They made lenses that went on 8mm cameras. Hardly cinema lenses. 8mm movies were just consumer level cameras. The film version of GoPros or mass market cameras. The optics weren’t anything that was going to make a meaningful imaging difference to the end result. Many of their 35 stills lenses have been adopted and used on cinema cameras and are revered (aside from focusing the wrong way) But Nikon never made their own native “cinema” lenses for motion picture cameras. 8mm cameras don’t count. Davide DB 1 Link to comment Share on other sites More sharing options...
Davide DB Posted December 5, 2024 Share Posted December 5, 2024 http://www.marcocavina.com/articoli_fotografici/Nikon_Cine-Nikkor/00_pag.htm https://www.savazzi.net/download/manuals/Cine-Nikkor.pdf eatstoomuchjam and IronFilm 1 1 Link to comment Share on other sites More sharing options...
IronFilm Posted December 5, 2024 Share Posted December 5, 2024 6 hours ago, JulioD said: They made lenses that went on 8mm cameras. They made 16mm lenses as well, so while I agree with your point about 8mm, it's different with 16mm as that's where professional usage often starts (although a few non-pros used it, maybe you might argue 16mm is "prosumer") Link to comment Share on other sites More sharing options...
Chrille Posted December 5, 2024 Share Posted December 5, 2024 On 12/3/2024 at 7:16 AM, IronFilm said: "And in terms of the high-end, it's ARRI, ARRI and VENICE" 😝 (or maybe I should have said: "And in terms of the high-end, it's ARRI, ARRI, ARRI, ARRI, and VENICE" Or even "And in terms of the high-end, it's ARRI, ARRI, ARRI, ARRI, VENICE, ARRI, ARRI, ARRI, RED, ARRI, ARRI, and VENICE") 😁 Link to comment Share on other sites More sharing options...
JulioD Posted December 9, 2024 Author Share Posted December 9, 2024 On 12/5/2024 at 5:00 AM, IronFilm said: They made 16mm lenses as well, so while I agree with your point about 8mm Have you got a link? I’ve never seen 16mm format Nikors. Seen a few 8mm in the wild. I stand by what I said. Nikon have never made cinema lenses for “movies” They made 8mm lenses mostly for their own Nikon branded 8mm HOME movie cameras. They made some broadcast (tv) lenses which I think were only for the local Japanese broadcast market. Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted December 9, 2024 Share Posted December 9, 2024 35 minutes ago, JulioD said: Have you got a link? Are you asking IronFilm for more links beyond those that Davide DB was already kind enough to provide you? IronFilm 1 Link to comment Share on other sites More sharing options...
IronFilm Posted December 9, 2024 Share Posted December 9, 2024 11 hours ago, JulioD said: Have you got a link? Davide DB and eatstoomuchjam 2 Link to comment Share on other sites More sharing options...
Davide DB Posted December 9, 2024 Share Posted December 9, 2024 Speaking about old (non cinema) lens I saw a couple of post from Filippo Chiesa on FB about these Hong Kong lens NONIKKOR 🙂 https://artralab.com/#page-4 eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
JulioD Posted December 9, 2024 Author Share Posted December 9, 2024 20 hours ago, eatstoomuchjam said: Are you asking IronFilm for more links beyond those that Davide DB was already kind enough to provide you? My mistake. I didn’t see those links. They aren’t lenses that were ever widely available or made. I suspect they were maybe only for the Japan market. I’ve never seen those 16mm lenses. And they “probably” are really for the broadcast video market. Davide DB 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted December 10, 2024 Share Posted December 10, 2024 They were literally called "cine-nikkor." IronFilm 1 Link to comment Share on other sites More sharing options...
IronFilm Posted December 12, 2024 Share Posted December 12, 2024 On 12/10/2024 at 6:58 AM, Davide DB said: Speaking about old (non cinema) lens I saw a couple of post from Filippo Chiesa on FB about these Hong Kong lens NONIKKOR 🙂 https://artralab.com/#page-4 Calling themselves "Nonikkor" is hilarious/awesome! I can see indeed how in their physical look they are indeed taking inspiration from the early Nikkor lenses. https://fstoppers.com/reviews/artra-lab-nocty-nonikkor-50mm-f12-retro-inspired-manual-lens-bokeh-lovers-687091 https://www.thephoblographer.com/2023/07/26/artralab-35mm-f1-4-80s-review-the-perfect-lens-for-the-nikon-zf/ https://nikongear.net/revival/index.php?topic=10883.0 Price seems to be a tad high though? For that price I could just pick up a Voigtländer or similar one of those higher-ish priced manual lens. (maybe even Zeiss? Hmm... maybe a step too far, unless going secondhand) Davide DB 1 Link to comment Share on other sites More sharing options...
MrSMW Posted December 12, 2024 Share Posted December 12, 2024 I watch just one review and apparently the lens is completely dumb ad does not talk to the camera in any way? Yes, I'd go for a Voigtlander over this. Link to comment Share on other sites More sharing options...
Davide DB Posted December 12, 2024 Share Posted December 12, 2024 10 hours ago, IronFilm said: Calling themselves "Nonikkor" is hilarious/awesome! I can see indeed how in their physical look they are indeed taking inspiration from the early Nikkor lenses. https://fstoppers.com/reviews/artra-lab-nocty-nonikkor-50mm-f12-retro-inspired-manual-lens-bokeh-lovers-687091 https://www.thephoblographer.com/2023/07/26/artralab-35mm-f1-4-80s-review-the-perfect-lens-for-the-nikon-zf/ https://nikongear.net/revival/index.php?topic=10883.0 Price seems to be a tad high though? For that price I could just pick up a Voigtländer or similar one of those higher-ish priced manual lens. (maybe even Zeiss? Hmm... maybe a step too far, unless going secondhand) Let's say that the product is so unique that the price simply reflects the commercial aspect. I mean it is mainly aimed at an audience that wants to take a whim off and look cool. BTW I agree, Voigtlander! IronFilm 1 Link to comment Share on other sites More sharing options...
IronFilm Posted December 13, 2024 Share Posted December 13, 2024 11 hours ago, Davide DB said: Let's say that the product is so unique that the price simply reflects the commercial aspect. I mean it is mainly aimed at an audience that wants to take a whim off and look cool. It's perfectly matched after all with a Nikon ZFc / ZF after all, which is aimed at the same target market! (which is hey also the same the old Nikon Df existed for. And a similar market that Fujifilm often targets.... just look at their X-Pro or X-T etc series) I certainly do understand the appeal myself. Davide DB 1 Link to comment Share on other sites More sharing options...
MrSMW Posted December 13, 2024 Share Posted December 13, 2024 I’m regretting selling mine now. Quite fancy one again with the Voigt 40mm f1.2… Only thing is, lack of AF which I would need and would rather not be changing lenses to have so probably would need to be Sigma 35 or 50mm f2… BUT NO, AAAAARGH, not happening! Well, maybe if an S2R appears and then my entire apple cart might get upset… Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 14, 2024 Administrators Share Posted December 14, 2024 On 12/13/2024 at 3:08 AM, IronFilm said: It's perfectly matched after all with a Nikon ZFc / ZF after all, which is aimed at the same target market! (which is hey also the same the old Nikon Df existed for. And a similar market that Fujifilm often targets.... just look at their X-Pro or X-T etc series) I certainly do understand the appeal myself. The thing with Fuji is they are not so much consciously targeting hipsters and the camera designs are not a fake clone of a prior era. They are designing photography tool classics in good taste, for the modern era. Would be great it Canon could do the same and not a separate niche line, but an EOS R5 Mark II which FEELS more like a camera and less like an inkjet fucking printer. Davide DB 1 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted February 13 Super Members Share Posted February 13 The first Z mount RED cameras have been released. There is also a bundle with the new Nikkor 28-135mm Power Zoom lens for under $10K. Not sure how appropriate that full frame lens is focal length wise for a Super35 camera like the Komodo X but here we are. https://www.red.com/komodo-x-z-mount-black?quantity=1&kxzpackage=2 eatstoomuchjam 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted February 13 Share Posted February 13 Cool that Reds will now have the most flexible lens mount on the market! I suppose that opens up a ton of Sony E mount options too since there's an adapter for E->Z. For most of the shoots I do, a 28-135 on the K-X wouldn't be ideal - but if you don't need anything wider than 37mm FF equivalent, it'll probably look great. For affordable zooms on an S35 camera, I still can't think of any that I'd rather have than the Fujinon MK's. I finally picked up a used set mid-last year (along with a kit to replace the E mount with RF) and I've been delighted! The 18-55 has barely been off my K-X since then. With A Z mount and the E mount adapter, there's no longer even a need for the RF conversion! IronFilm and BTM_Pix 2 Link to comment Share on other sites More sharing options...
