QuickHitRecord Posted July 3, 2012 Share Posted July 3, 2012 Does anyone have any experience incorporating a 15mm rod system into the Velbon SPT-1 without getting too bulky or too expensive? Barbagao15 1 Link to comment Share on other sites More sharing options...
QuickHitRecord Posted September 20, 2012 Author Share Posted September 20, 2012 I posted this months ago but only just came figured out a simple solution: [img]http://www.eoshd.com/comments/uploads/gallery/album_14/gallery_18451_14_57990.jpg[/img] [img]http://www.eoshd.com/comments/uploads/gallery/album_14/gallery_18451_14_641.jpg[/img] [img]http://www.eoshd.com/comments/uploads/gallery/album_14/gallery_18451_14_43570.jpg[/img] Here is the part that you need to buy: [url="http://www.ebay.com/itm/270941674813"]http://www.ebay.com/itm/270941674813[/url] Specifically this one because the center groove on the top shelf is long enough to cover two of the three Velbon mounting holes located on the bottom of the main assembly. You could do it with a cheaper one (there are many out there, just search for "DSLR base plate"), but you probably will not get full hole coverage and you may have twisting issues. I also put two screws in the Manfrotto quick release plate to prevent twisting (I have been doing that a lot lately). Now it easily slides into any Manfrotto fluid head with no chance of twisting. I took out the adjustable-height riser and re-bolted it together so that it would be more compact, but you can always leave it in if you want to. This method is useful for putting a matte box in front of a Lomo square front, a Hypergonar HiFi-2, or any oversized lens. You could also mount a follow focus to use with your lens while keeping the ease-of-use afforded by the Velbon. I hope that this is helpful to someone. Julian 1 Link to comment Share on other sites More sharing options...
Julian Posted September 21, 2012 Share Posted September 21, 2012 Thanks! I'm using the SPT-1, no need for rods right now, but If I do I know what I should get :) Link to comment Share on other sites More sharing options...
