milkyc Posted May 16, 2015 Share Posted May 16, 2015 Hi,I currently have two IR flash heads with 1/4" female sync ports.I wish to use my canon 600d to wireless trigger my two heads (interfit exd200) and a speedlite 430ex iiI wish to use the 'yongnuo rf-603 ii' triggers or similar, but not sure how I can send these through RF to my interfit heads.Do I just need a correct sync cable that link from the yongnuo receiver to plug into the flash head?And if so, can someone send me the correct ebay link! As I'm struggling to get my head around this.Thanks Link to comment Share on other sites More sharing options...
tupp Posted May 16, 2015 Share Posted May 16, 2015 Not very clear on the configuration of the strobe head and receiver you mention, but flash sync connectors are standardized and most monobloc strobes these days come with built-in optical slaves. Indeed, the specs on the Interfit EXD200 show that it has a built-in optical slave and that it ships with a sync cord. So, if you are using your camera flash, you can use the optical slave to sync, as long as slave on the EXD2000 sees the light from your camera flash. Here is a sync cable that plugs into the receivers. Link to comment Share on other sites More sharing options...
