Karpalino Posted June 1, 2015 Share Posted June 1, 2015 Hi,I had a GH4 for testing video, and some questions came up, maybe you could help on these.1. I had a 16GB UHS1 card, and longer clips were cut into 4GB files, is there a workaround on this?2. I shot 4K to check resolution, and it was nice What would you recommend software for batch processing the 4K clips to 1080p? My current laptop does not have enough power to play clips in Premiere.3. As a PC user, should I set GH4 to save mp4 or mov files? If I user mp4, do I miss some compatibility which would come up later...All the best,Kari Link to comment Share on other sites More sharing options...
johnnymossville Posted June 1, 2015 Share Posted June 1, 2015 1. The 4GB clips are a function of the file system used on SD cards. It uses FAT32 which has a maximum file size of 4GB. Be thankful they span beautifully on the GH4.2. Do you have Adobe Media Encoder?3. I don't think it matters either way whether you use mp4 or mov. I could be wrong so get other opinions on this one. Link to comment Share on other sites More sharing options...
John Palmer Posted June 1, 2015 Share Posted June 1, 2015 shooting in 4k I think the camera automatically cuts a continuous shot into sections that are usually about 4 GB i think. No workaround as far as I know. they all match up just fine if you lay them in the timeline like normal. recording in 1080p might not have a limit but I'm not completely sure. Johnny's correct, be thankfulI use mpeg sreamclip for some things. its free and has a good bit of features. Id use adobe media encoder though if you have that. You should download the DNxHD codec too if you don't already have it. I normally just make a project with a 1080p timeline and put the 4k files in as they are. If your computer is having trouble just don't always playback in full resolution. A lot of computers can have trouble playing back compressed 4k files in real time. Need to have a good graphics card and a good amount of RAMmpegstreamclip - http://www.squared5.com/I am a PC user and shoot them as .mov. Unless I'm using the 4:3 anamorphic mode which only records in mp4. I haven't noticed any real differences, though they are not 100% identical Link to comment Share on other sites More sharing options...
TSV Posted June 1, 2015 Share Posted June 1, 2015 1. The 4GB clips are a function of the file system used on SD cards. It uses FAT32 which has a maximum file size of 4GB. Be thankful they span beautifully on the GH4.http://suggestionofmotion.com/blog/panasonic-gh4-memory-file-size-limit/ A nice article that explain the limit. Now what is still unclear is why it does have this limit even if the SDXC Cards on the GH4 formated in ExFAT have this limit. Link to comment Share on other sites More sharing options...
johnnymossville Posted June 2, 2015 Share Posted June 2, 2015 I suspect cards that are formatted to ExFAT are reformatted to FAT32 when you insert them into the GH4. I'm going to check this later. Link to comment Share on other sites More sharing options...
