Gregormannschaft Posted June 4, 2015 Share Posted June 4, 2015 I'll be shooting a documentary in the next few months and am looking into grabbing a shoulder rig that's gonna cut down on any camera shake from doing handheld work. I wish I lived in the US as they have a Manfrotto Sympla rig that looks great, but getting it shipped to Germany makes it mega expensive.http://www.bhphotovideo.com/c/product/999925-REG/manfrotto_mva525wk_sympla_lightweight_shoulder_mounted.htmlLooking on Amazon here is a bit of a nightmare, there's a million branded shoulder rigs branded with names you've never heard of and with hardly any reviews out there from places you'd trust. Does anyone here have a setup they could recommend? Particularly looking at one for the Sony A7s, something thats small, easy to transport and lug around. Link to comment Share on other sites More sharing options...
Asmundma Posted June 4, 2015 Share Posted June 4, 2015 By useing a stabalized lense you may not need any rig - i use FE 24-70 supported to the eye - the footage is very stable. Link to comment Share on other sites More sharing options...
Gregormannschaft Posted June 4, 2015 Author Share Posted June 4, 2015 Generally that is the case, but using a Metabone EF to E adapter with the Canon 24-105, the IS can suddenly turn off unexpectedly. You only see it in post and it's annoying to fix. Plus, arms do get tired after a while and shake, sometimes too much for the IS to really help with. Link to comment Share on other sites More sharing options...
Nick Hughes Posted June 4, 2015 Share Posted June 4, 2015 I recommend piecing together your own rig. It is often cheaper and allows you to customize everything exactly as you like it. Of course, it's hard to know exactly what you need until you're able to actually use it, but a modular rig will allow you to add and change everything as you go. I'm a big fan of SmallRig - they do have complete rigs available, but they also have every individual part you'd ever need (mostly). The key to building a good rig is making sure it's balanced well. You'll need a counterweight at the back, otherwise it'll hurt your arms almost as much as handholding the camera. Those big brick batteries are great for this because they can also power your whole system, but a normal weight will work fine. There are many available with 15mm connections. If you have an external monitor/EVF, it's best to position the camera on your shoulder (for good balance) and have the monitor in front of you. If not, you should be able to position the EVF of your A7s right up to your eye. You'll need some sort of offset to do this.Here's a list that could get you a simple, but versatile rig:A few different sections of rods (length is definitely subject to personal liking):http://smallrig.com/2pcs-black-15mm-rod-w-m12-thread-40cm.htmlhttp://smallrig.com/2pcs-black-15mm-rod-w-m12-thread-20cm.htmlhttp://smallrig.com/2pcs-black-15mm-rod-w-m12-thread-15cm.htmlShoulder Pad:http://smallrig.com/shoulder-pad-1485-15mm-railblock.htmlMounting Place (best to attach some sort of quick-release to this):http://smallrig.com/smallrig-tripod-mounting-plate-to-balance-long-length-front-heavy-camera-packages.htmlHandlebar clamp:http://smallrig.com/c90-15mm-handlebar-rail-clamp.html2x handles:http://smallrig.com/smallrig-15mm-rod-handle-rubber-red-ring.htmlA counterweight (not sure if they'll ship to DE for cheap, but you can find all kinds on BH and Amazon by searching 15mm counterweight):http://www.amazon.com/Flashpoint-Counter-Weight-15MM-Rods/dp/B00N5FQPN8/ref=sr_1_1?ie=UTF8&qid=1433427650&sr=8-1&keywords=15mm+counterweight All this costs under $300 USD and is a great starting point, IMO. jcs and Gregormannschaft 2 Link to comment Share on other sites More sharing options...
Gregormannschaft Posted June 4, 2015 Author Share Posted June 4, 2015 I recommend piecing together your own rig. It is often cheaper and allows you to customize everything exactly as you like it. Of course, it's hard to know exactly what you need until you're able to actually use it, but a modular rig will allow you to add and change everything as you go. I'm a big fan of SmallRig - they do have complete rigs available, but they also have every individual part you'd ever need (mostly). The key to building a good rig is making sure it's balanced well. You'll need a counterweight at the back, otherwise it'll hurt your arms almost as much as handholding the camera. Those big brick batteries are great for this because they can also power your whole system, but a normal weight will work fine. There are many available with 15mm connections. If you have an external monitor/EVF, it's best to position the camera on your shoulder (for good balance) and have the monitor in front of you. If not, you should be able to position the EVF of your A7s right up to your eye. You'll need some sort of offset to do this.Here's a list that could get you a simple, but versatile rig:A few different sections of rods (length is definitely subject to personal liking):http://smallrig.com/2pcs-black-15mm-rod-w-m12-thread-40cm.htmlhttp://smallrig.com/2pcs-black-15mm-rod-w-m12-thread-20cm.htmlhttp://smallrig.com/2pcs-black-15mm-rod-w-m12-thread-15cm.htmlShoulder Pad:http://smallrig.com/shoulder-pad-1485-15mm-railblock.htmlMounting Place (best to attach some sort of quick-release to this):http://smallrig.com/smallrig-tripod-mounting-plate-to-balance-long-length-front-heavy-camera-packages.htmlHandlebar clamp:http://smallrig.com/c90-15mm-handlebar-rail-clamp.html2x handles:http://smallrig.com/smallrig-15mm-rod-handle-rubber-red-ring.htmlA counterweight (not sure if they'll ship to DE for cheap, but you can find all kinds on BH and Amazon by searching 15mm counterweight):http://www.amazon.com/Flashpoint-Counter-Weight-15MM-Rods/dp/B00N5FQPN8/ref=sr_1_1?ie=UTF8&qid=1433427650&sr=8-1&keywords=15mm+counterweight All this costs under $300 USD and is a great starting point, IMO. Nick, this is brilliant, thanks a lot for putting it together.I had a look at their complete setups which helped in working out the individual parts needed. Have emailed them about shipping and at this point looks promising. Thanks again. Link to comment Share on other sites More sharing options...
Nick Hughes Posted June 4, 2015 Share Posted June 4, 2015 They also have a few cages designed specifically for the A7s that may be of interest. I don't personally use a cage, but may start soon for easy mounting of accessories (mic/audio, monitor, etc.), which can be particularly useful for quick switching from shoulder rig to a tripod. Link to comment Share on other sites More sharing options...
Cinegain Posted June 4, 2015 Share Posted June 4, 2015 Other ideas. Ginirigs. Kamerar.ProAIM / Cinecity / Camtree perhaps. Link to comment Share on other sites More sharing options...
Gregormannschaft Posted June 4, 2015 Author Share Posted June 4, 2015 They also have a few cages designed specifically for the A7s that may be of interest. I don't personally use a cage, but may start soon for easy mounting of accessories (mic/audio, monitor, etc.), which can be particularly useful for quick switching from shoulder rig to a tripod.Yeah I looked into cages but don't use an EVF or follow focus so at this point I think a rig would be a better option. Link to comment Share on other sites More sharing options...
Nick Hughes Posted June 4, 2015 Share Posted June 4, 2015 Yeah I looked into cages but don't use an EVF or follow focus so at this point I think a rig would be a better option.Definitely agree that a shoulder rig is a better starting piece. A cage is something that you could eventually work into your rig as your list of equipment grows. A good quick release system would allow you to pop the cage off your shoulder rig and onto a tripod/monopod/whatever in a matter of seconds. It's not so useful or desirable for people who prefer a more lightweight/minimal setup. I myself prefer to at least have the option of a built-up rig in case the gig calls for it. Link to comment Share on other sites More sharing options...
