Julian Posted June 8, 2015 Share Posted June 8, 2015 The rotation on anamorphics is usually pretty stiff. At least it is on my Kowa B&H. A filter should rotate a lot smoother, so probably the movement won't cause the anamorphic to rotate with it. You could try with a circulair polariser or variable ND filter. Link to comment Share on other sites More sharing options...
premini Posted June 8, 2015 Share Posted June 8, 2015 or gaffer Julian 1 Link to comment Share on other sites More sharing options...
Nikkor Posted June 8, 2015 Share Posted June 8, 2015 Most projector lenses have a locking screw/s Link to comment Share on other sites More sharing options...
Julian Posted June 8, 2015 Share Posted June 8, 2015 How does an adapter like this actually work?I remember the topic about combining a diopter + wide angle adapter to turn anamorphics into single focus. This follows the same principle without the wide angle adapter? Does it consist of two diopters that move back and forth? If so: what kind of strength would the diopters have? Link to comment Share on other sites More sharing options...
solo Posted June 8, 2015 Author Share Posted June 8, 2015 How does an adapter like this actually work?I remember the topic about combining a diopter + wide angle adapter to turn anamorphics into single focus. This follows the same principle without the wide angle adapter? Does it consist of two diopters that move back and forth? If so: what kind of strength would the diopters have? ken, Endfallow Media, Ian Edward Weir and 1 other 4 Link to comment Share on other sites More sharing options...
