Davide DB Posted Sunday at 05:14 PM Share Posted Sunday at 05:14 PM Other than "see it" or opening in Resolve, is there a program that allows you to tell from the metadata of the file if the clip is in vlog? I was opening vlog clips with the stainless MediaInfo and in the metadata I can't find anything. In fact I only find rec.709. Quote ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.2@High Codec ID : hvc1 Codec ID/Info : High Efficiency Video Coding Duration : 15 s 360 ms Bit rate : 191 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 50.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.462 Stream size : 351 MiB (99%) Encoded date : UTC 2024-06-14 10:43:43 Tagged date : UTC 2024-06-14 10:43:43 Color range : Full Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : hvcC Quote Link to comment Share on other sites More sharing options...
Attila Bakos Posted Monday at 08:22 AM Share Posted Monday at 08:22 AM Check it with Exiftool, you'll see that the file has a tag called "Panasonic Semi-Pro Metadata Xml" (at least that's what I have on the S5IIx), which is actually an XML and it has an element called CaptureGamma, in which you'll see "V-Log" when the clip has been shot in V-Log. ac6000cw and Davide DB 1 1 Quote Link to comment Share on other sites More sharing options...
MurtlandPhoto Posted Monday at 01:42 PM Share Posted Monday at 01:42 PM I use MediaInfo. It will do exactly what you need. It's been super useful for me identifying random video clips from other videographers at my day job. Davide DB 1 Quote Link to comment Share on other sites More sharing options...
Davide DB Posted Monday at 02:53 PM Author Share Posted Monday at 02:53 PM I realized that also mediainfo gives this info. I was using the wrong visualization. Everything is inside the Panasonic Semi-Pro Metadata Xml tag and based on the visualization I get a cluttered or more clear view. I discovered I have ISO too. Very useful. For example: com.panasonic.Semi-Pro.metadata.xml : <?xml version="1.0" encoding="UTF-8" standalone="no" ?> / <ClipMain xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="urn:schemas-Professional-Plug-in:Semi-Pro:ClipMetadata:v1.0"> / <ClipContent> / <GlobalClipID>060A2B340101010501010D2113000000977DFA29AA8CC0044199109111620092</GlobalClipID> / <Duration>768</Duration> / <EditUnit>1/50</EditUnit> / <EssenceList> / <Video> / <Codec BitRate="200">H265_420_LongGOP</Codec> / <ActiveLine>2160</ActiveLine> / <ActivePixel>3840</ActivePixel> / <BitDepth>10</BitDepth> / <FrameRate>50p</FrameRate> / <TimecodeType>NonDrop</TimecodeType> / <StartTimecode>14:51:36:12</StartTimecode> / </Video> / <Audio> / <Channel>2</Channel> / <SamplingRate>48000</SamplingRate> / <BitsPerSample>16</BitsPerSample> / </Audio> / </EssenceList> / <ClipMetadata> / <Rating>0</Rating> / <Access> / <CreationDate>2024-06-14T10:43:43+01:00</CreationDate> / <LastUpdateDate>2024-06-14T10:43:43+01:00</LastUpdateDate> / </Access> / <Device> / <Manufacturer>Panasonic</Manufacturer> / <ModelName>DC-GH5M2</ModelName> / </Device> / <Shoot> / <StartDate>2024-06-14T10:43:43+01:00</StartDate> / </Shoot> / </ClipMetadata> / </ClipContent> / <UserArea> / <AcquisitionMetadata xmlns="urn:schemas-Professional-Plug-in:P2:CameraMetadata:v1.2"> / <CameraUnitMetadata> / <ISOSensitivity>800</ISOSensitivity> / <Gamma> / <CaptureGamma>V-LogL</CaptureGamma> / </Gamma> / <Gamut> / <CaptureGamut>V-Gamut</CaptureGamut> / </Gamut> / </CameraUnitMetadata> / </AcquisitionMetadata> / </UserArea> / </ClipMain> Quote Link to comment Share on other sites More sharing options...
ac6000cw Posted Monday at 04:09 PM Share Posted Monday at 04:09 PM 1 hour ago, Davide DB said: I realized that also mediainfo gives this info. I was using the wrong visualization. Everything is inside the Panasonic Semi-Pro Metadata Xml tag and based on the visualization I get a cluttered or more clear view. I discovered I have ISO too. Very useful. Which MediaInfo visualisation is the best one to see all the extra info? Quote Link to comment Share on other sites More sharing options...
Davide DB Posted Monday at 05:52 PM Author Share Posted Monday at 05:52 PM 1 hour ago, ac6000cw said: Which MediaInfo visualisation is the best one to see all the extra info? I don't remember, maybe "text". This is the screen Quote Link to comment Share on other sites More sharing options...
