Lumix S5iix vs BMCC6k
zlfan
11 hours ago, zlfan said:
nteresting, bmpcc 6k/ff has gyro info for post stabilization. this is very critical. just not sure how good it is and how complicate it is.
It does involve a crop, and for best results you need to use a shutter angle of 45 or 90 degrees, not the more typical 180. This will make your footage look a bit choppy but that's easily fixed by adding back motion blur with Resolve. An advantage is that gyro stabilization also reduces rolling shutter artifacts. As always, the best stabilization is external: tripod, gimbal, or steadicam. Not even the best IBIS or gyro stabilization can beat it, although IBIS can stand in for a tripod on non-moving shots. It's once the camera starts moving that external stabilization beats everything else.
