Peter Rzazewski Posted June 11, 2015 Share Posted June 11, 2015 Current about 75% completed a pilot for a political comedy tv series and in pre production for a docu style tv series along the lines of chef's table. Our team is currently borrowing/renting lights for these shoots and Ive decided we're getting busy enough that I would like to buy some of my own. I have about $2000 and would like a decent starter setup. Thinking LED's but then how would I do a spot light on an actor or a element in the scene with LED? Maybe a combination of LED's and a fresnel? Also, what modifiers would you suggest to cover exterior and interior shoots? I don't really know if this is the right way to go. I am on a budget so if you have suggestions to save costs on a kit, let me know:4 1x1 led's (dimmable) daylight balanced (with optional tungsten/flourescent filters) 1 tungsten spot light with gels to match led4-5 used c-stands for butterfly frame and flags/scrims as needed3-4 various sized flags, scrims, and gobos (wouldn't be averse to using black cardboard in place of flags, and have punched holes thru black foil as a make shift gobo in the past)soft box (not sure what's a good size, etc)?impact reflectora butterfly frame (for exterior or as a large softbox)large rolls of ND filters to control exterior window lightvarious gels for gobo background lightI do currently have a 1x1 dimmable led, several lights stands with one 36" reflector and an arm to hold it, and a few gels and white and black cardboard as reflector/flag. You think that's a good start or am I missing something critical? Thanks for your input all. Link to comment Share on other sites More sharing options...
Peter Rzazewski Posted June 17, 2015 Author Share Posted June 17, 2015 Bump. Would like some input from the community. Surely I'm not alone in using lights and modifiers? Link to comment Share on other sites More sharing options...
Cinegain Posted June 17, 2015 Share Posted June 17, 2015 There was a little discussion on lights a little while ago, maybe it's of any use to you: http://www.eoshd.com/comments/topic/8033-led-lighting-fresnels-redheads-etc/ .From the recent NAB 2015 one of the highlights seems to have been the Wescott Flex: http://www.fjwestcott.com/led-lighting/flex .Can't really give you any recommendations as all I got myself is some low-end stuff: Aputure AL-H160, AL-198 & AL-198C LED video lights with 2 stands (König KN-LS10) & 1 ministand (PhotoSEL ST121) and one eBay ringlight softbox. Peter Rzazewski 1 Link to comment Share on other sites More sharing options...
sanveer Posted June 17, 2015 Share Posted June 17, 2015 Most LEDs and small lights have absolutely no throw, and can only be used as fill lights, in smaller spaces (cars, tiny rooms, etc etc). The problem with more affordable lights is that their color temperature is unique to them. hahahaTry these:http://www.amazon.com/Aputure-Amaran-AL-528S-Video-Light/dp/B00LC0OVEI#Ask or these:http://www.bhphotovideo.com/c/product/1081927-REG/switronix_tl_bt220r_bolt_220r_dimmable_led.html or these:http://www.bhphotovideo.com/c/product/1123056-REG/rotolight_rl_neo_rotolight_neo_on_camera_led.html Check them at a store close to you, and then decide which ones to pick up. try not to pick up too many different lights, cause then your colour temperatures will look different every few feet. Also, please post your own experiences with the lights.Good luck Peter Rzazewski 1 Link to comment Share on other sites More sharing options...
AaronChicago Posted June 17, 2015 Share Posted June 17, 2015 For modifiers I use this small kit on 80% of shoots: http://www.adorama.com/djfkpb.html sanveer and Peter Rzazewski 2 Link to comment Share on other sites More sharing options...
sanveer Posted June 18, 2015 Share Posted June 18, 2015 For modifiers I use this small kit on 80% of shoots: http://www.adorama.com/djfkpb.html Pretty neat kit. Link to comment Share on other sites More sharing options...
cpc Posted June 19, 2015 Share Posted June 19, 2015 Well, since you've been renting lights you should know best what works for you?I'm not sure how the 1x1 lights can be enough for lighting a normal scale set/location from scratch. Are you only shooting closeups or using the LEDs to augment daylight? Link to comment Share on other sites More sharing options...
jax_rox Posted June 20, 2015 Share Posted June 20, 2015 I'd get 4 fresnels over 4 LED panels if you're looking for versatility.LEDs can be good for small spaces (though I prefer kino flos), but it's a lot more difficult to make a soft source hard than it is to make a hard source soft. The only advantage LEDs provide is that of color temp (I.e. You don't lose a stop and a half when correcting it to daylight like you do with tungsten lights) but then with all but the most expensive LEDs you'll be battling the green cast at the very least anyway. Link to comment Share on other sites More sharing options...
