roccoforte Posted June 22, 2015 Share Posted June 22, 2015 I've found a really nice lens combo that works well for me: Voightlander 40mm 2.0Bolex 8/19/1.5On a: Canon 7D (APS-C) To get the most out of this lens combo what other cameras can I use? Are there any raw 23.98 1920x1080 or higher options out there for me? What other cameras have the same or similar sensor size to the 7d? Or are there larger sensor cameras that offer a "zoom in" or crop mode, so I can keep this lens combo with the same wide field of view? Images below are photos (not video stills) with the above lenses. Thanks for any suggestions. Link to comment Share on other sites More sharing options...
Julian Posted June 22, 2015 Share Posted June 22, 2015 Have you tried Magic Lantern Raw on the 7D? Link to comment Share on other sites More sharing options...
dhessel Posted June 22, 2015 Share Posted June 22, 2015 For raw the only option I can think of that will get you 24P at full HD and an APS-C size sensor would be a black magic camera with a speedbooster BMCC or pocket, or the 4K as is without a booster. Other than that the A7s has an option to shoot full frame or APS-C. It has a log mode and other benifits but no raw. Like Juilian mentioned you can try ML raw but if I recall correctly you won't be able to get continuous raw HD with a 7D, you may not even be able to get full HD at all but it would be best to check out their site as I a don't follow it as closely as I used to and things may have changed. Link to comment Share on other sites More sharing options...
roccoforte Posted June 23, 2015 Author Share Posted June 23, 2015 Thanks, very helpful. I didn't consider the speed booster w BMC, that could be a great option as well as the A7s. From what I can tell ML maxes out at 1728x972 on the 7D, not too bad. Link to comment Share on other sites More sharing options...
