Canon C80 coming soon
ntblowz
7 hours ago, gt3rs said:
Number game interpretations. For RAW with no processing you should compare to the max DR possible so it would be 14.9 vs 13.4.
The proof that in 4k Log R5II 13.6 stops of usable DR vs 12, indeed disappointing 😉
And view that you are disappointed can you point hybrid cameras with more than 13.6 stops? I believe only A1 has 0.2 more...
But again, I don't care about the numbers too much as I just open the files from both camera that I own and is definitely visible the better DR.
On Imatest results, the acceptable signal-to-noise ratio at .5 "Medium" will provide the usable DR. Otherwise, using your methodology of max DR, the R5C 8K RAW (16.1 stops) comes out way ahead of the R5 II 8K RAW (15.1 stops) when both are placed on a 4K timeline:
There is no way you can recover the max DR (16.1 stops) on an R5C. So max DR is often pointless, except for camera marketing purposes. I would rate the R5C at about 11 stops, which is confirmed by the usable DR above (10.8). That would mean the R5 II (11.7) is giving us almost 1 stop more than the R5C when 8K RAW is placed on 4K timeline. However, by the same methodology, the R5 II has no advantage (both were about 11 stops) when looking at the 8K RAW source on an 8K timeline.
I absolutely agree with the eye test and everyone should just go with that. As I stated above, it is obvious the R5 II has improved noise performance in the shadows, except at high ISOs where the R5C seems better.
What I'm not seeing is any improvement in the highlight roll-off, which is a problem with the R5 cameras. The Sony A1 by comparison has better highlight roll-off than any R5 camera, including the R5 II.
The new 6K sensor in the C80/C400 (and possibly in the R1) should demonstrate significant improvement in all these areas.
2 hours ago, eatstoomuchjam said:
Otherwise, beyond some chat about specs, it's really worth waiting for the camera to get into the hands of real users.  Then the truth will be understood.
As for me, I'm going to guess that we'll see a lot more owner-operators and documentary crews running around with C80's and C400's than we will see them using R1's.  The R1 will likely be a niche camera, used primarily by sports photographers.
I never stated otherwise. We need the R1 and its CRM files to make real assessments about how it performs in relation to the C80/C400. It could be that the faster sensor readout on the R1 undermines any DR advantages seen in all the C400 footage and tests. The AF circuitry is also different. But I can't imagine that Canon spent the last 2-3 years designing completely different and new 6K BSI sensors to be released at the same time in such low-volume cameras.
Also, no one in his right mind who needs a proper cinema cam should go for the R1 over the C400, even if they share a similar sensor and image quality. It just becomes interesting when comparing the R1 with the C80, which is still using SD cards, and lacks the FF 6K 60p RAW, IBIS, and EVF. For those who need portability in the field, which is what the C80 is supposed to offer, the R1 is just another choice and obviously a better hybrid.
16 hours ago, Kino said:
I have no intention of buying an R1. It's just an idea for the future. For VND, you shouldn't be getting any green shift. On the R5C, I use the Freewell V2 Hybrid VND/CPL (3-7 stop) and it is really impressive in preventing color shift. It is magnetic, easy to use, and comes with a nice case. You should try it.
The green cast does not bother me, and there's no way I am going back to a lens end vND after using a lens mount vND. I get 1.5-9 stops of ND, no X pattern, and the cast is consistent so when I choose to remove it, it takes seconds in post, or a few seconds on set using WB. It also provides another layer of protection for the interior of the camera if I have to switch lenses on set. My point is, casts don't matter in the real world if they are consistent.
I have yet to see a single thing in all of your charts and graphs that matters in the real world. I also have yet to have a single customer tell me in the real world that they want a discount or reshoot because my camera did not have enough stops of DR. I have been shooting with the R7 for the past 2yrs and it paid for itself many times over.....to this day I still have no idea how many stops of DR it has nor do I care.
If I went by YT BS, and all of these uselsess charts and graphs I would have been lugging around the C70 to every hybrid shoot and brought the R5 for the photography part of it, and likely had less satisfied customers because I would have had a lower photography and video shot count and missed valuable moments throughout the events because I was too busy fiddling with the gear or switching cameras.
If you are not filming the next Hollywood feature length blockbuster these charts mean nothing and if you are then you still aren't looking at these charts and you are just renting trailers worth of equipment packages that will work for your project.
Great.  So since we agree that most of the discussion is useless until the cameras are released and in the hands of real users, you can stop the lengthy rants and pasting screenshots from YouTube and reviewer websites and demanding that one camera (that you have never actually touched) is better than another camera (that you have never actually touched).
Again, you like to put words in my mouth. I made no such "demands." I posted test results on the R5C, a camera I own and use. When it comes to C400, C80, and R1 comparisons, everything on this thread is speculation. Some are very offended that the R1 should be considered here or that it may turn out to be a better video hybrid than the the R5 cameras. That's not my problem.
The idea that the R1 is a camera that some people might choose instead of the C80 is not offensive.
However, your continuous bombarding of this thread with test charts and graphs to demand that it's a better choice than the C80, once again despite that you have touched neither camera is not necessary.  If the R1 is noticeably better than the C80 in real-world usage once both cameras have been released, Canon will sell more R1's than they would otherwise.  I'd certainly consider it once it's available on the used market or there's a big sale, just as I am considering the C80 now (but no way I'm paying full price).
Regardless, neither camera is "better" than the other - but one might be a better fit for you.  If it is, that's great.  You should get that camera.  If you plan to buy/use neither camera, then you should stop caring about which one is "better."
I never stated that the R1 would be a better on-set cinema cam than the C80. I actually said the opposite way up there. I just think it could be an alternative for those also interested in the C80 (like me) who need something mobile.
Then we had the discussion about why you would get an R1 over an R5 II, which I did not initiate. I only responded to the R5 fans (pun intended) with all those graphs and charts to suggest that the R5 II does not really improve on the highlight clipping problems I have with the R5C. The point here is that the 6K sensor in the C80/C400 is going to offer a substantial IQ improvement on all the R5 cameras, which really can't be compared with proper Cinema EOS.
In the meantime, I've recently seen more RAW C80 footage and it is pretty awesome:
The C80 also looks fantastic in XFAVC 10 bit. Here are some XFAVC files available for download:
Despite the charts I posted above, in most scenarios the differences between the C80 and C400 will be minor. Perhaps you will see some differences in extreme low-light with noise in RAW LQ, but otherwise the C80 looks gorgeous overall. I don't use HFR much, so that C400 advantage doesn't worry me. In any case, RED and Sony should be scared.
Hard call for me to get exited about the footage above. Color grading seems the devil here. If the C80 looks as good as the C500II, it is a compelling image taking powerhouse. FX6 would be a direct contender, which works pretty well as a shoulder cam. Looking forward to rigging tutorials for the C80.
CineD does a much better job by shooting a mini doc with it, ProAV just makes the camera look bad.
For rigging ideas, I would just take a look at some rigging ideas for the C70.
Below is how I rigged my C70, I know the thread says S5, but my C70 setup is identical. When I create rigging setups I want to be able to swap in any future camera body without having to buy anything new (except the camera cage and a few small parts) and it worked perfectly for me. I only have 7 setups and with those I can shoot anything that I typically shoot and use any camera body.
With my setup I can swap in the R5, R5II, R7, or C70 without buying anything new for everything from handheld to gimbal to tripod long form content.
Thanks for posting and linking to your setups. Looking cool. Just not a solution for shoulder cam operation. I'm not a fan of the cine d video nor color grading. But if it is delivering image quality of the C500II and if battery life operation and sturdiness are just as fine, then we got a winner. It deserves a convincing non Frankenstein setup though for shoulder work .
This French technical review with available English CC compares the C400 with the C500 II, FX6, and RED KX.
Considering the new triple-ISO, the C400 has better ISO performance than the C500 II. DR (14 stops usable in RAW 6K) and color fidelity ("Delta E" at two different exposure levels: lower score is better) are very similar between the two cameras.
Unfortunately, there is no real-world comparison here, but at least you can get an idea of how the C400/C80 sensor should perform in challenging conditions.
I think shoulder work with the C80 or C70 will be tough, without an EVF and with the DSLR type form factor as well as the attached screen it's really not ideal nor is it built with ENG uses in mind. Even if you rig it in a way where you can view an external monitor while it is on your shoulder, getting to the controls for even simple things or using the touch screen will be difficult.
With ENG cameras you don't need a frankenrig to make it work on your shoulder.  At the end of the day IMO the C70, C80, and other "cinema cameras" really are meant to live on a tripod or gimbal with occasional handheld work if any at all, and little if any shoulder work. I learned early on that my C70 will probably never leave my tripod again and I will stick to other cameras with IBIS for anything handheld or any gimbal work.
As far as color grading, it shoots in 6K raw in CLOG2 and has 13+ usable stops of DR.....with that as a starting point you can color grade it to look like anything including the C500. The battery life for my C70 is great, with my V Mount battery and the onboard battery I can shoot continuously for around 8hrs, the C80 is probably similar.
Sturdiness is questionable in the C70, I would assume it's better in the C80.
  • 3 months later...
I don't seem able to find a review video that compares the c500ii with the canon c80 and the c400. Did anybody came across one? I want to see the image difference between those camera's. I recently have used the C500ii and I love the image over lots of camera's (packs a lot of dr, and has good color, and looks smooth). The c500ii is quite bulky though. So I wonder if the C80 and C400 provide the same IQ.
On 9/9/2024 at 1:12 PM, Mmmbeats said:
I'm pretty dubious about all of that!
I'm not so sure about the low light 'big advantage'.  Yes, the 12,800 ISO base is going to be a fantastic feature, but the C70 is already a fantastic camera in low light because of the rich inky blacks you get with DGO.  You're essentially getting an additional exposure at the shadow level and (with the great dynamic range) you get fantastic low-light imagery.  This was actually a key factor that made me buy the camera in the first place.
I film in subterranean poorly-lit locations with the C70 all the time, and it is brilliant for those kind of scenarios.  Unlike the cameras that have to crank up ISO (like the A7S derived Sonys) you get great highlight control alongside rich shadows.
The C400 (albeit pre-production at this stage) looks noisy and thin by comparison.
Also - when do you ever actually shoot at 12,800 ISO?  Like I say, I shoot in dark spaces very often, but never require that kind of facility.  Don't get me wrong - it's a nice feature to have, and might come in handy here and there.  But it isn't a key feature in my books, almost always makes things look unnatural, and you are going to be better off with DGO in most situations.
I'm talking here as someone who is likely to buy the C400 and is excited by it, so I'm not trying to rubbish the sensor tech and implimentation (which is the same as the C80).
C70 is soft by design, just like many high-end cinema cameras.  Its a point of preference really, and not something that needs to 'fixed' in my view.  I'm looking forward to being able to choose between softer (doc and fiction) and sharper (corporate / client work).
You don't lose a stop of light between sensor sizes.  Speedboosters work in a unique way to refocus light, which is where the stop gain comes from.
I notice that the C80 has SDI though - that is another differentiator from the C70 (HDMI only).
When you say you have "low light experience" with the C70, how low are you talking?
I recently created a post in trying to decide which camera is suitable for me and am pretty much as of now looking at the C70 or C80....
For me low would be a high contrast situation where you have vehicles with headlights and lightbars going through the frame in pitch black night, or alternately while camping with just headlights providing illumination.
I did watch a Youtube video comparison of the low light performance between the C70 and C80, but it was processed in post so obviously both looked pretty good (to my inexperienced eyes in any case)
  • 2 months later...
Apologies for the delayed reply.
I think it depends how you want to expose.
In low light situations, similar to the ones you describe, I find that at least a part of the subject is usually decently well lit.  In the example of camping headlights a nearby subject (person, tree, what-have-you) would be illuminated - you can expose fairly normally for it, but everything else (background, distant subjects) will fall off into shadow.  And the shadow area will be nicely controlled, not noisy.  That looks nice to me on video.
The problems come when people want to 'see in the dark', and treat a night time scene a little more like a daytime scene.  If you raise distant subjects or background info up, either using exposure or in post, you can run into problems with noise and unnatural colours.  Also, to me, the whole scene starts to look 'off' as the viewers mind starts to reject the unnatural light levels being portrayed.
If you want the former exposure effect, rather than the latter, I think the C70 is the better option.  If you want the latter effect then the C80 is definitely going to win.
Funny enough it was head torch only footage that sold me on the C70 in the first place.
