TheRenaissanceMan Posted July 29, 2015 Share Posted July 29, 2015 If you really need 24p output then just conform to 24p. The speed increase and pitch increase will be utterly negligible.However, unless your content is being projected its unlikely you do need 24p output.For PAL you would need to conform to 25p anyway, so no difference in effort there.And to do a 3-2 pull down to 59.94 NTSC or 29.97 you need 23.976 anyway.So even real 24p would have to be confomed to 23.976Converting perfect 24 to 23.976 is much more problematic than doing it the other way around, so that's what most people seem to recommend. There have been some good threads on this over at DVX User and Red User. Also, I've worked at 3 local film festivals and have never encountered a projector that couldn't handle 23.976. Link to comment Share on other sites More sharing options...
agolex Posted July 29, 2015 Share Posted July 29, 2015 Ohh well...Can't win em all. Still thinking if selling off the trusty 600D and Tamron 17-50 2.8I for one am keeping the RX10 II, it's a really impressive compact package. Oliver Daniel and kaylee 2 Link to comment Share on other sites More sharing options...
Oliver Daniel Posted July 29, 2015 Share Posted July 29, 2015 I for one am keeping the RX10 II, it's a really impressive compact package.How's the lens for manual focusing? Link to comment Share on other sites More sharing options...
Eric Westpheling Posted July 29, 2015 Share Posted July 29, 2015 How's the lens for manual focusing? It was pretty good, I tried following my friend around the block with it. The autofocus was reliable for any sort of wide shot or once you were at f5.6. I needed to use focus peaking for the onboard screen to make it viable at f2.8. I would rather use the graticle or 502/sidefinder to actually see it at high-resolution with a nice contrasty LUT. Link to comment Share on other sites More sharing options...
agolex Posted July 29, 2015 Share Posted July 29, 2015 How's the lens for manual focusing? Needs some getting used to, after all there's always software involved. Depending on the mode you're in, functions change and you can't always customize to your liking. Sometimes you have the automated magnification assist, sometimes you don't. Together with the AF switch on the front and the peaking w/ the large DoF it's workable for me. Think, you'll have to try it out yourself. Link to comment Share on other sites More sharing options...
Igor Campana Posted July 29, 2015 Share Posted July 29, 2015 Converting perfect 24 to 23.976 is much more problematic than doing it the other way around, so that's what most people seem to recommend. There have been some good threads on this over at DVX User and Red User. Also, I've worked at 3 local film festivals and have never encountered a projector that couldn't handle 23.976. they all want perfect 24pI understand that for US it doesnt matter, but to me it matters if it is 23,97 or 24pI cant understand why Sony does advice that the cam can shoot 24p, when it doesnt. the gh4 can handle it perfectly too, and I suppose other Sony cams can also do perfect 24p How's the lens for manual focusing? it's a pain.... for video you need to switch to MF, caus in DMF it still runs the zoom, while in Af Mode you can either use DMF or MF to focus. In my opinion, focus peaking and the display does work really BAD Link to comment Share on other sites More sharing options...
MattH Posted July 29, 2015 Share Posted July 29, 2015 they all want perfect 24pWhat? They all specify specifically "not 23.976" without you prompting it? Or are they just saying they want "24p" or "perfect 24p". This is an important distinction given that most people don't know the difference. They may just mean 24p rather than 25p.But if it really matters to you, then it obviously isn't the camera for you. Brian Williams 1 Link to comment Share on other sites More sharing options...
Greg Padgett Posted July 30, 2015 Share Posted July 30, 2015 Hello everyone. A question if I may?I have been playing around with the slog function and was wondering if like the A7s, there is a base iso for log with the RX10? I tried iso 800 as a starting point with decent results but was wondering if like the A7s, I should be using 3200?Thanks in advance for any advice you may have. Link to comment Share on other sites More sharing options...
Brian Williams Posted July 30, 2015 Share Posted July 30, 2015 it's a pain.... for video you need to switch to MF, caus in DMF it still runs the zoom, while in Af Mode you can either use DMF or MF to focus. In my opinion, focus peaking and the display does work really BADwell, of course, if you're shooting video professionally you would never want to use DMF anyway. Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted July 30, 2015 Share Posted July 30, 2015 they all want perfect 24pI understand that for US it doesnt matter, but to me it matters if it is 23,97 or 24pI cant understand why Sony does advice that the cam can shoot 24p, when it doesnt. the gh4 can handle it perfectly too, and I suppose other Sony cams can also do perfect 24p Pretty much select very few cameras shoot at 24p.On the 7DII I remember finding a dedicated menu setting separate from the normal res/fps one, it's called 24p. When you activate it, the camera gives you a warning not to use this mode for anything other than inter-cutting the video with footage shot 24p negative film. Link to comment Share on other sites More sharing options...
agolex Posted July 30, 2015 Share Posted July 30, 2015 Hello everyone. A question if I may?I have been playing around with the slog function and was wondering if like the A7s, there is a base iso for log with the RX10? I tried iso 800 as a starting point with decent results but was wondering if like the A7s, I should be using 3200?Thanks in advance for any advice you may have.3200 is hardly usable, just stick with the SLOG minimum of 800, pretty sure that will be the native. The small sensor is no good in high ISO. Link to comment Share on other sites More sharing options...
TheRenaissanceMan Posted July 30, 2015 Share Posted July 30, 2015 3200 is hardly usable, just stick with the SLOG minimum of 800, pretty sure that will be the native. The small sensor is no good in high ISO.For stills, it's surprisingly good at 3200. For video, best sticking to the native ISO in SLog. Link to comment Share on other sites More sharing options...
agolex Posted July 30, 2015 Share Posted July 30, 2015 For stills, it's surprisingly good at 3200. For video, best sticking to the native ISO in SLog. Reviewed my stills again and you're right. Quite a few nice shots around 3200. The ones I complained about before, I've just noticed, just had fast shutter. I like the grain very much, too, looks nicely organic. kaylee and TheRenaissanceMan 2 Link to comment Share on other sites More sharing options...
Greg Padgett Posted July 30, 2015 Share Posted July 30, 2015 agolex, TheRenaissanceMan,Thank you. I didn't realize the camera would automatically pick an iso when I chose PP7. I just manually set the camera to iso 800.3200 did seem a bit high for such a small sensor but I thought I'd ask to be sure. Now the learning curve with Davinci resolve and maybe I'll be able to make some nice videos.Thank you again. TheRenaissanceMan and vaga 2 Link to comment Share on other sites More sharing options...
kaylee Posted July 30, 2015 Share Posted July 30, 2015 What? They all specify specifically "not 23.976" without you prompting it? Or are they just saying they want "24p" or "perfect 24p". This is an important distinction given that most people don't know the difference. They may just mean 24p rather than 25p.But if it really matters to you, then it obviously isn't the camera for you.i just prefer the number 24 aesthetically tbh Link to comment Share on other sites More sharing options...
Igor Campana Posted July 30, 2015 Share Posted July 30, 2015 What? They all specify specifically "not 23.976" without you prompting it? Or are they just saying they want "24p" or "perfect 24p". This is an important distinction given that most people don't know the difference. They may just mean 24p rather than 25p.But if it really matters to you, then it obviously isn't the camera for you.The client and the cinema projections says 24,00p. No 23,98, no 23,976, nothing else.Since Sony statet out it is 24p (while they are mentionin 23,97 as 23p on their website) I thought the camera cna support also perfect 24p cinema standard like the gh4, that also can handle 23,97 / 24,00 / 25,00 / 29,97 Hello everyone. A question if I may?I have been playing around with the slog function and was wondering if like the A7s, there is a base iso for log with the RX10? I tried iso 800 as a starting point with decent results but was wondering if like the A7s, I should be using 3200?Thanks in advance for any advice you may have.Native ISO is 800 as I understood. I would go up to 1600 and maybe 3200 since the cpu is very good. But the chip is only 1".Have you been able to get a better display quality in Av Mode when shooting in low light conditions? It looks like to me the display is switching to SD resolution well, of course, if you're shooting video professionally you would never want to use DMF anyway.yes no doubt. but what I dont understand why in Av mode DMF + MF is controlling the focus and why in video mode it drives the zoom in DMF. Looks pretty unlogical to me. When you are going to shoot pictures in AV you need to switch back from MF to DMF becouse otherwise you have focus zoom in on the display.I whished that the controls would be more logicla and intuitive like on the GH4.... Link to comment Share on other sites More sharing options...
flipside Posted July 30, 2015 Share Posted July 30, 2015 Can anyone point me to the review? The link in the first post is broken. Thanks. Link to comment Share on other sites More sharing options...
Mat Mayer Posted July 30, 2015 Share Posted July 30, 2015 Can anyone point me to the review? The link in the first post is broken. Thanks.http://www.eoshd.com/2015/07/sony-rx10-m2-first-part-of-my-review-and-a-mini-comparison-with-the-a7s-and-canon-1d-c/That is more of a preview. Someone has posted a mini review in the Anamorphic section of the forum too. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted July 30, 2015 Author Administrators Share Posted July 30, 2015 Final part of the review is coming soon.Delay due to accommodating RX100 IV as well.Spoiler: I ended up preferring the small one!! elkanah77 1 Link to comment Share on other sites More sharing options...
dafreaking Posted July 30, 2015 Share Posted July 30, 2015 Final part of the review is coming soon.Delay due to accommodating RX100 IV as well.Spoiler: I ended up preferring the small one!!Noooo. I still hope you manage to get more of the RX10 in the review! Link to comment Share on other sites More sharing options...
