Panasonic G7 settings for video
David Brunckhorst
Hi,
Not sure there's a topic which tackles precisely this issue, so there you go.
I wanted to check whether the usual rule of thumb applied to GH4 settings works the same way on G7. In other words, I've had better results with sharpness dialled down to -1 rather than -5, for example. Also, the jury is still out (for me) on Cinelike D or Natural for low light shots. At any rate, I did some tests with Canon FD 1.4 50mm and maybe the sharpness worked because of it. For the kit lens (14-42), I was happy with sharpness to go to -5 and NR to -2. It's a harsher lens. Need to do more tests, but would be good to hear different opinions on the video setting. Anyone?
