Kodak Vision3 vs Sigma Fp-L RAW Cinema DNG
  On 1/3/2025 at 2:29 PM, eatstoomuchjam said:
To each their own, I think.  A lot of these things are really subjective.  I bought both the FP and FP-l and while I felt some level of happiness using them and the 12-bit CinemaDNG looked really nice SOOC, I'd often be a bit disappointed when I started to grade them because while the SOOC colors were nice, the dynamic range was ho-hum and the rolling shutter seemed really terrible sometimes on the FP-l (in APS-C mode, it actually got worse and was noticeable even when panning slowly).
I ended up selling mine because I was getting to have too many cameras (there again!) and if I pushed myself on it, I needed to agree that aside from a positive emotional response to a lot of things about the camera, there was nothing that it really did "better" than any of my other cameras, including "be small" since the EOS R5 is effectively smaller if you want to shoot in anything other than an 8-bit codec or have a screen that you can see without holding the camera at eye level (the DPL mod helps with that, at least, but I never bought it).  Heck, even adding the EVF made it pretty close to the same size as the R5.
I'd really love to see a next generation FP with a better/faster sensor, the ability to record 10-bit internally, and either/both of an integrated tiny EVF (small enough to make YouTubers cry in rage is fine) and a screen that can at least tilt up a bit.  Add those things, keep the body the same size, and keep uncompressed raw internal recording and it'll instantly be my favorite travel/carry-around camera.
Expand
All good points, thank you.
  • 2 weeks later...
  • Super Members
  On 12/31/2024 at 2:28 AM, Andrew Reid said:
Perfect for C-mount, Super 16mm stuff?
Expand
It’s likely way too niche for them but I’d love to see the Chinese lens manufacturers like 7Artisans etc do some C mount Super 16mm lenses.
It would avoid the eBay crapshoot and based on their Super35 prices they could probably produce some good stuff for circa £150 a pop or even less.
Expand
I'd love to see this too.
One could probably just put in an order for them to make some. There would of course be a minimum order quantity. For a small lens company it might only be 100 or 500. Some existing lenses might only need some modifying of the back elements and mount to work. (I'm just speculating here, I really don't know how it works.)
I speculate also that maybe one of those companies that rehouse vintage lenses into modern housing could also rehouse new lenses into c-mount and for a Super 16 size sensor.
Expand
This is a bit like how SLR Magic started off isn't it? I agree it would be a very nice thing... would they sell? Hard to say. C-mount seems to have been a bit like the vintage anamorphic bubble... The early adopters and adventurous production houses gobbled them all up, created a price bubble, but then abandoned beauty for practicality and easily replaced professional Chinese cine lenses.
It would be great if Pentax could get their act together and do a Pentax Q size body with a GH7 sensor in it. And market two versions... one for photographers, and one in a slightly different but also very tiny form factor as a Digital Bolex type cinema camera for pros...
Or for that matter, if Nikon would bring back the 1 series, but with an sort of modern specs/codec.  If I remember right, the sensor on the 1 series was pretty close to 16mm, but even the V3 was only 1080p 8 bit H.264.  If they put out one with 4k 10-bit HEVC, I'd have an EDC camera with some lovely C mount glass.  ðŸ˜ƒ
  • Super Members
Expand
All this needs is an old Ninja 2 to make an interesting DIY CCD ProRes shooting cine camera with a smaller sensor 😉
598817520_ScreenShot2025-01-14at14_52_49.thumb.png.375ddc544ec0edff5d2e94b0724ffade.png
https://www.aliexpress.com/item/1005003731513738.html
  On 1/18/2025 at 6:03 PM, PannySVHS said:
I had wondered why seemingly noone has tried to do that! Digital Bolex sports a KAI-2050 or KAI-4050 sensor from what I read. There used to exist small c-mount cameras with these sensors irrc. Diy digital bolex anyone?:) @BTM_Pix
Expand
It might be possible. There are many industrial cameras meant for quality control on assembly lines, in airplanes, etc. These usually have global shutters too. They tend to have Camera Link as the output standard so there would have to be a way to record the signal. https://en.wikipedia.org/wiki/Camera_Link
It's probably all possible though. Maybe the guys at the YouTube Channel Alt Cine should look at repackaging an industrial camera with a recorder and monitor and make a cinema camera.
It may or may not be worth it though compared to just getting a used Blackmagic Production Cinema camera off Craigslist. (They going for less than CAN$1000 now.)
Having the original Kodak CCD in a much better form factor than a BM production camera would be nice though. A small industry camera could provide that, with a form factor like a BM micro, a small cube, perfect to be rigged out.
I don't know if Altcinecam have delivered some of their Bmmcc based cameras, nor have i seen tests for ergonomy and handling nor their current price. @Clark Nikolai
