New travel film-making setup and pipeline - I feel like the tech has finally come of age
kye
  • Super Members
29 minutes ago, kye said:
it was a crazy hot day (37C/99F) and direct midday sun, so seriously challenging conditions.
Not to mention that Museum Of Modern Moiré building.
39 minutes ago, kye said:
For the first time it feels like I'm getting the results I want because of the equipment I have, rather than in spite of it.
That's a good feeling. Nice to see you posting again as I always like to hear what you have to say. The shots look really good! So, did you get the Arri LUT add-on?
Part 2...  how did I get here?
I've written about this previously, but the summary is that I went through a sequence of trial and error, continually bumping up against the limits of the hardware, the software, my skill, and mindset.
Setup: GH5, fast manual-focus primes
I shot a bunch with the GH5 and a set of very fast MF primes.  I chose this setup as it had 10-bit LOG, IBIS, and the fast primes gave good low-light and some background blur.  I knowingly sacrificed AF, essentially swapping a fast / accurate / robotic AF for a slow / human / aesthetically-appropriate focusing mechanism.
The MF worked, but not always (especially for my kids, who wait for no-one), and took time and effort to operate the camera away from the things that literally every other crew member does on set.
The 10-bit LOG worked, but wasn't a properly supported LOG profile so didn't colour grade flawlessly in post.
The primes provided the low-light and shallow-DoF but the shots I missed because I couldn't change lenses fast enough were more valuable in the edit than having shallow-DoF.
The DR was lacking.
Setup: GX85 with 12-35/2.8
I owned the GX85 and 12-35mm zoom, so I did some testing.
I loved the speed of AF-S, and the deeper DoF meant that the number of shots unusable due to missed focus dropped to almost zero.
I tested it with low-light and for well-lit night-time areas, like outdoor shopping malls, it was sufficient.
The Dual IS (IBIS + lens OIS) was absolutely spectacular and a welcome addition, and having a zoom made me realise why doco and ENG shooters have them as standard issue.
The DR and 709 profile was a real limitation though, and I really felt it in the grade.
It was around this time I figured out proper colour management, and the Film Look Creator was released.  These made a huge boost to grading the GX85, despite its 709 profile.
The mindset shift
The fundamental pivot was in mindset.  As social media became faster and more showy, I noticed the gulf between it and 'real' film-making more and more.  I went minimalist, thinking more and more about the days before digital where the process was to shoot as best you could, cut it, do sound-design, and that was it.  The focus was on what was in-front of the camera, how the cuts made you feel, and sound design that supported that vision.  Even those shooting docs on 16mm film could make magic.
Without throwing away the baby with the bathwater, I decided to re-focus.  To shoot what I could shoot, to learn to cut with feeling, and to simulate a film-like colour grading process where the look was applied and only very basic adjustments were made.
Setup: OG BMMCC with 12-35/2.8
I owned these already, and on my last trip to South Korea I took these as well as the GX85.  My shooting moved from shooting people I knew to shooting more general scenes, giving me more time and taking the time pressure off.
The setup was large (comparatively!) and very slow to work with, but it validated my mindset shift.
The images were organic and rich, but in a way that drew you into their contents, rather than towards the medium.
The DR was finally sufficient, and the colours were delightful.
But the monitor wasn't bright enough, the lack of IBIS meant that the OIS stabilised tilt and pan but not roll, so the images all needed to be stabilised in post, but had roll motion blur due to the 180 shutter.
The low-light wasn't ideal either, even with fast lenses.
The moire from the 1080p sensor was real and ruined shots.
I also got a lot more comfortable shooting in public with a more visible camera setup.
New Setup: GH7 with 14-140 and 12-35.....
So what I wanted was the best of all worlds.
Dynamic range.
I knew the OG BMMCC and OG BMPCC were the same/similar sensor, and I knew the GH7 had more.
What I didn't expect was how much more that would be in real life.  Here's a high DR scene from Monday.
1107140658_2025-03-24GH7Freoonhotday-DRtest-FLC.thumb.jpg.80a47650e980b8824fa43719d9ec3da2.jpg
Here it is without the FLC, which I set to add contrast.
514251822_2025-03-24GH7Freoonhotday-DRtest-709.thumb.jpg.2c199b086ba54e78a1bb71ea4a0e4834.jpg
Now with the shot raised by 3 stops.  Notice the detail in the railings and under the eves on the right.
60879404_2025-03-24GH7Freoonhotday-DRtest-7093.thumb.jpg.daccc9511638cb143e50e4f42978f4ac.jpg
Now with the shot lowered by 3 stops.  Notice that the roof, and even the body of the car are still not clipped, with the only clipping being the sun reflecting off the car window.
74609937_2025-03-24GH7Freoonhotday-DRtest-709-3.thumb.jpg.10e6928bb19058fbda5a20f93f72195e.jpg
In grading, there is more DR than you can fit in the DR of the final shot - assuming you haven't developed Stockholm Syndrome for your LOG footage that is.
Low light.
I had previously established that the GX85 and 12-35mm F2.8 were good enough for well-lit night locations.  I also knew that the BMMCC at ISO800 and the 12-35mm F2.8 set to a 360 shutter was good enough for semi-well-lit night locations.  I also knew that the BMMCC with my 50mm F1.2 lens was passable at the darkest scenes I shot in Korea - which were from the hotel window at night.
I've compared the GH7 vs the GX85 and BMMCC and the noise profiles are all very different, but I concluded that the GH7 had probably 2-4 stops of advantage over those.  This means that I might be able to shoot well-lit night locations with the 14-140mm lens, and might be able to shoot from the hotel window at night with the 12-35mm lens.
I'm still contemplating if I should take my F1.2-1.4 primes on my up-coming trip, but if I don't I'll still be able to shoot 99% of what I want to with the zooms.
Camera size.
Perhaps the only drawback when compared to my previous setups.
I'll be taking the GX85 and 14mm F2.5 pancake lens as the pocketable tiny camera.  This combo is no slouch by itself, so although it lacks some of the specs from more serious cameras, it is easily in the capable category, especially when helped by Resolve+FLC and from a shoot-cut-sound-publish mindset.
Absolute speed.
When it comes to absolute speed, nothing beats a smartphone, which is always in your pocket, can be pulled out and rolling in seconds.  This is also a serious tool when combined with Resolve+FLC and a shoot-cut-sound-publish mindset.
HA!  I didn't notice that until you pointed it out, as I hadn't hit play on that shot yet.
I guess nothing is immune to moire, although this was worse than I would have thought.
The GH7 has no crop in its full resolution modes, and none in the 1080p modes, but the 4K modes do have slight crops - with the C4K having slightly less crop which is why I chose it, so I wonder why that is and what tom-foolery might be going on with that.  The bitrates for the native resolutions are pretty brutal without Prores LT, so I'll likely stick to the C4K mode unless it starts being an issue.
Thanks!
I didn't get the LogC upgrade.  I haven't seen any tests that were done properly so am assuming that it's not worth the cost unless proven otherwise.  I also figure that even if there is some magic in there, I'm taking a hammer to the image with the FLC anyway, so it's not like I'm precious about it.  The only thing I am precious about is getting images that have the right aesthetic to support the subject matter and get out of the way rather than being distracting.
When I saw Goodfellas and a bunch of film trailers projected on 35mm film, the two most stunning things about the images were:
1) how fundamentally flawed they were from a technical perspective
2) how quickly and completely those incredible flaws evaporated and you saw effortlessly through and into the scene
I'm still at the beginning of my FLC journey, but I'm convinced this pipeline is capable of removing the digital distractions from the image that bug me so much.
When FLCs were introduced in Resolve I had seen some tutorials on how to apply them. I had never actually played with them because I was only working with underwater footage at that time.
Some time ago I took up the subject again and realized that several YouTube videos gave wrong directions on how to apply them and the results are very different.
I am certainly stating a trivia and I apologize in advance.
This should be a correct example:
https://www.youtube.com/watch?v=uwcItNYhOV4
Impressive @kye no idea what this forum would be without you, really. Food for thought. You're such an asset and a few people here, if no more or/and elsewhere, miss you when you're absent : )
You've summed up the whole thing : ) it's all about that, no more no less, one of the reasons why people love (and use) anamorphics :- )
Is it me or is the GH7 a recent camera release no one speaks about? Every Panny user seems to have jumped over to the FF S line. Anyways surprised OP hasn't purchased the LogC3 license considering how many posts about ARRI color science etc! My pipeline usually involves CST to LogC just to benefit from the excellent ARRI look/LUT library. Would be cool to be able to skip this step in post and access it straight in cam a bit like Fuji film simulations. Definitely one of the highlights of GH7 for me personally.
On 3/29/2025 at 11:15 AM, fuzzynormal said:
Regardless of whatever pipeline you ultimately use, I really like what you're willing to do with the blacks.
Thanks..
To be honest I just find it baffling that everyone is throwing the word "cinematic" around and yet all the colour grades look like they haven't been converted from LOG to 709.  It's one of the easiest changes you can make in post to take your footage from video to cinema, and yet hardly anyone does it.
Pushing as much contrast and saturation as you can was the best film-making advice I ever got.
40 minutes ago, kye said:
Thanks..
i like high contrast high saturation style too. for landscape, i push as much as i can. really pushing the sensor and the dsp to their limits.
On 3/28/2025 at 9:53 PM, kye said:
  • K&F True Colour 1-5 stop vND
  •  stop vND had enough range, when combined with the DR of the GH7, so I never needed to change settings, despite going in and out of shadow (and even inside, which isn't included in the above images)
  • The vND had a much more consistent sky and colour render than my old (crappy) vND, so I'm really happy with it
Is that the same one that Btm_pix has shown on the lenses page?  because i have to confess i got one too 🙄
Btm_pix You should probably add affiliate links...
From your screen shots, I feel that OM1 has better dr than GH7. I use art filter 1, which is a high sat high contr filter. On EM5, the dr is too narrow, although I like the color and the contrast, I kind of don't not like the whole pictures. On OM1, it is very usable, I get good contrast, good color, and relative good dr, at least the dr does not distract my eyes.
Yes, that's the one.
K&F Concept 58mm True Color Variable ND2-32 (1-5 Stops) ND Lens Filter, Adjustable Neutral Density Filter with 28 Multi-Layer Coatings for Camera Lens
The key phrases are "True Color" and "ND2-32 (1-5 Stops)".  They sell ones that have a wider range, but aren't as high quality and will have greater colour shifts over the operating range.
Having hard stops is the key to preventing you pushing it too far and getting into the range where the performance is poor (which I think is inevitable of this design, so the hard stops just stop you before you get there).
