Shield3 Posted August 5, 2015 Share Posted August 5, 2015 More tests done @ dvxuser. This comment stood out: "Slightly alarmingly this time it didn't give the customary overheat message. It just went dead!"http://www.dvxuser.com/V6/showthread.php?339161-Newsshooter-Sony-A7RII-overheats-and-shutdown-after-recording-4K-for-a-while Link to comment Share on other sites More sharing options...
noone Posted August 5, 2015 Share Posted August 5, 2015 While I would love an A7Rii I will be happy keeping my A7 and A7s pair instead.42mp is a bit much for my current computer and I use ISO 51200 often with the A7s for stills and video even above that. I find setting auto ISO to 102400 for video, the camera will often go to something like ISO 80,000 and that is still quite good. I just use it to record bands using either a 17mm f4 or 24mm 3.5 Canon TS-E lens often at f5.6 with the camera on a tripod or even table and get all the band in focus and turn it on and let it run (let the band do the work). I don't need 4k for this and full HD from the camera FF is nice.I would therefore not get as much use out of the A7Rii with ISO limited to 25600 for video. The A7s also auto focuses to a lower light level than the A7Rii (or anything really) for stills at least in AF-S (DMF). Link to comment Share on other sites More sharing options...
sean Posted August 5, 2015 Share Posted August 5, 2015 I can't seem to get IBIS to turn off using the Metabones Ultra Speedbooster. The option is greyed out, greyed out being ON and the Symbol for IBIS is displayed on screen while recording as well.Not to seem alarmist or annoying, but can anyone confirm the camara has an internal fan? Because if you put it to your ear the camera in fact does rattle and hum, which is kind of new to me. Link to comment Share on other sites More sharing options...
ntblowz Posted August 5, 2015 Share Posted August 5, 2015 On 8/5/2015 at 9:36 PM, sean said: I can't seem to get IBIS to turn off using the Metabones Ultra Speedbooster. The option is greyed out, greyed out being ON and the Symbol for IBIS is displayed on screen while recording as well.Not to seem alarmist or annoying, but can anyone confirm the camara has an internal fan? Because if you put it to your ear the camera in fact does rattle and hum, which is kind of new to me. That is the IBIS in the work Link to comment Share on other sites More sharing options...
sean Posted August 5, 2015 Share Posted August 5, 2015 @NTBLOWZit appears there are two types of sound. One constant humming even if IBIS is off and the slight rattling of the IBIS adjusting when it is on. The hum is very constant and it really resembles the sound of a fan. Update:Got heat warning at around 25 minutes of rec time in 4k FF mode. It finished up to 30, then I swapped the battery as it was down to 6% and resumed record. The heat warning was gone. The battery change was performed very quickly. This is giving me hopes that the heat issue is in part due to battery adding heat in the body and this can be perhaps remedied by using a battery grip, or a battery dummy / external battery solution. Link to comment Share on other sites More sharing options...
ntblowz Posted August 5, 2015 Share Posted August 5, 2015 On 8/5/2015 at 10:12 PM, sean said: @NTBLOWZit appears there are two types of sound. One constant humming even if IBIS is off and the slight rattling of the IBIS adjusting when it is on. The hum is very constant and it really resembles the sound of a fan. Update:Got heat warning at around 25 minutes of rec time in 4k FF mode. It finished up to 30, then I swapped the battery as it was down to 6% and resumed record. The heat warning was gone. The battery change was performed very quickly. This is giving me hopes that the heat issue is in part due to battery adding heat in the body and this can be perhaps remedied by using a battery grip, or a battery dummy / external battery solution. I wonder can any one do test with external battery solution and see if that helps with long time recording? Link to comment Share on other sites More sharing options...
Francesco Spiezia Posted August 6, 2015 Share Posted August 6, 2015 Wonder if the grip would make a difference... move that battery out and reduce heat. Used to happen to my old 7D all the time and a fresh battery cures the temp issue. Link to comment Share on other sites More sharing options...
Shield3 Posted August 6, 2015 Share Posted August 6, 2015 On 8/5/2015 at 10:12 PM, sean said: @NTBLOWZit appears there are two types of sound. One constant humming even if IBIS is off and the slight rattling of the IBIS adjusting when it is on. The hum is very constant and it really resembles the sound of a fan. Update:Got heat warning at around 25 minutes of rec time in 4k FF mode. It finished up to 30, then I swapped the battery as it was down to 6% and resumed record. The heat warning was gone. The battery change was performed very quickly. This is giving me hopes that the heat issue is in part due to battery adding heat in the body and this can be perhaps remedied by using a battery grip, or a battery dummy / external battery solution. That's very interesting actually. The 1dx/1dc shooting stills will have the framerate reduced when the battery is less than 50% (I think the 5d3 as well). Are you saying after only shooting 25 minutes your battery is almost completely gone? Yikes. Link to comment Share on other sites More sharing options...
The Chris Posted August 6, 2015 Share Posted August 6, 2015 On 8/5/2015 at 10:12 PM, sean said: it appears there are two types of sound. One constant humming even if IBIS is off and the slight rattling of the IBIS adjusting when it is on. The hum is very constant and it really resembles the sound of a fan. 5-axis sounds like a fan. I shot with the EM5 a few years ago and now the A7II/A7RII and they all sound similar - like a fan inside the camera.Even if you turn IBIS off, the sensor is still suspended by the IBIS mechanism. Take off your lens, turn on the camera and you'll see it in action. Link to comment Share on other sites More sharing options...
Husah Posted August 6, 2015 Share Posted August 6, 2015 On 8/6/2015 at 2:40 PM, Shield3 said: The 1dx/1dc shooting stills will have the framerate reduced when the battery is less than 50% (I think the 5d3 as well). Are you saying after only shooting 25 minutes your battery is almost completely gone? Yikes.Where did he say battery ran out only after recording for 25 minutes and nothing else? Link to comment Share on other sites More sharing options...
Francesco Spiezia Posted August 6, 2015 Share Posted August 6, 2015 Need someone with a grip to test the 4K heat issue out... I don't get mine until the 12th Link to comment Share on other sites More sharing options...
Alexander Leith Posted August 7, 2015 Share Posted August 7, 2015 I posted my heat testing results on DVXuser (mine was the camera that turned off without warning).Further testing yesterday with an external power supply and a cable battery adapter, and there's no difference in overheating. Again around 27 minutes in S35 and about 48 mins (with a 1min break at 29mins) in FF. I did notice that in S35 4K mode, that it did sometimes overheat without first getting a temperature warning icon.And testing with USB power wasn't enough to to keep the camera on. Palpet and ntblowz 2 Link to comment Share on other sites More sharing options...
Asmundma Posted August 8, 2015 Share Posted August 8, 2015 On 8/7/2015 at 7:40 AM, Alexander Leith said: I posted my heat testing results on DVXuser (mine was the camera that turned off without warning).Further testing yesterday with an external power supply and a cable battery adapter, and there's no difference in overheating. Again around 27 minutes in S35 and about 48 mins (with a 1min break at 29mins) in FF. I did notice that in S35 4K mode, that it did sometimes overheat without first getting a temperature warning icon.And testing with USB power wasn't enough to to keep the camera on.Why do you not use a recorder (then the 30 limits is also gone). Link to comment Share on other sites More sharing options...
Emanuel Posted August 9, 2015 Share Posted August 9, 2015 On 8/7/2015 at 7:40 AM, Alexander Leith said: I posted my heat testing results on DVXuser (mine was the camera that turned off without warning).Further testing yesterday with an external power supply and a cable battery adapter, and there's no difference in overheating. Again around 27 minutes in S35 and about 48 mins (with a 1min break at 29mins) in FF. I did notice that in S35 4K mode, that it did sometimes overheat without first getting a temperature warning icon.And testing with USB power wasn't enough to to keep the camera on.In any case, there is the chance a fresh battery may somehow refresh the temperature of the camera. And let her work. The point is to know if this can bring any damage to the sensor. Worthy to give it a try and test the thing anyway, isn't it? ;-) Link to comment Share on other sites More sharing options...
ntblowz Posted August 9, 2015 Share Posted August 9, 2015 On 8/8/2015 at 6:53 AM, Asmundma said: Why do you not use a recorder (then the 30 limits is also gone). It still overheat when just output 4K to hdmi out wowhttp://www.dvxuser.com/V6/showthread.php?339161-Newsshooter-Sony-A7RII-overheats-and-shutdown-after-recording-4K-for-a-while&p=1986566907&viewfull=1#post1986566907 Link to comment Share on other sites More sharing options...
Asmundma Posted August 9, 2015 Share Posted August 9, 2015 On 8/9/2015 at 5:26 AM, ntblowz said: It still overheat when just output 4K to hdmi out wowhttp://www.dvxuser.com/V6/showthread.php?339161-Newsshooter-Sony-A7RII-overheats-and-shutdown-after-recording-4K-for-a-while&p=1986566907&viewfull=1#post1986566907That's not good. Someone suggested to pull out the LCD screen to mitigate. I have both the A7s and A7R ii, + ShoGun, but leave for a trip today. Link to comment Share on other sites More sharing options...
Oliver Daniel Posted August 9, 2015 Share Posted August 9, 2015 Seems this is a very risky proposition for client work. Maybe someone can design a fridge type rig for it, or just wrap it with an underwater covering and dunk it inside an ice bucket between shots. Xavier Plagaro Mussard 1 Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted August 9, 2015 Super Members Share Posted August 9, 2015 On 8/9/2015 at 9:11 AM, Oliver Daniel said: Seems this is a very risky proposition for client work. Maybe someone can design a fridge type rig for it, or just wrap it with an underwater covering and dunk it inside an ice bucket between shots. I think I would rather shoot HD TheRenaissanceMan and kaylee 2 Link to comment Share on other sites More sharing options...
Gregormannschaft Posted August 9, 2015 Share Posted August 9, 2015 Whats the 1080 verdict from the A7RII? Link to comment Share on other sites More sharing options...
Don Kotlos Posted August 9, 2015 Share Posted August 9, 2015 On 8/9/2015 at 12:18 PM, Gregormannschaft said: Whats the 1080 verdict from the A7RII?Yes that is something that I want to know as well. Both FF and S35 at 24p compared to the A7s, GH4... Link to comment Share on other sites More sharing options...
