Administrators Andrew - EOSHD Posted December 6, 2025 Administrators Share Posted December 6, 2025 Let's talk Chinese anamorphic stuff, vs vintage. I don't have much modern stuff although did get the full frame Great Joy 60mm T2.8 for L-mount a few months back. Recently picked up one of these though... https://siruishop.de/en/products/saturn?srsltid=AfmBOoqYgHSzTnkpJQ0HBLwj-2r6w0uskpYgytF1N-2y1XJX3hglGgMO It has come down from 1399 euro to 600. I got mine for 180 euros... Aperture blades were broke, so I removed them. Plan to put a DIY oval aperture in it. The look is good, in terms of sharpness and bokeh. Distortion is quite heavy - and pincushion, it's a very wide lens and I don't mind a bit of distortion but would prefer there to be barrel distortion like a Hollywood Panavision anamorphic, pincushion is a bit unexpected. Flare is weak, this is an area the good value for money lenses still can't seem to get right. I'll do some comparison shots with my Iscoramas. It is a 1.6x stretch so very similar to the Iscorama 36 (1.5x). Minimum focus distance is just a tad under 1 meter. It's a full frame lens so this isn't too bad, you can crop for closer-ups. Mainly I am impressed by the size and weight of the thing... It is absolutely tiny for an anamorphic cine lens. Link to comment Share on other sites More sharing options...
J S H Posted December 8, 2025 Share Posted December 8, 2025 Great find! I have been using these lenses since Sirui introduced them with the earlier/larger Venus series. The new Saturn series that you reference is an improvement across the board...not only are they smaller & lighter, but the optical qualities are also improved. I have even used the 35 for astrophotography, as it's pretty wide on 3:2 open gate, with good performance across the frame wide open. I feel they are really a nice compromise between size and performance and I appreciate the 1.6x squeeze. If you don't like the pincushion distortion, it's really easy to correct back to neutral or even barrel in Resolve and you don't lose any of the image, as you are expanding the frame when you make the correction. Ninpo33 1 Link to comment Share on other sites More sharing options...
Jahleh Posted December 11, 2025 Share Posted December 11, 2025 Had the 75mm Saturn with the S5II. With 6k25p open gate occasionally the footage looked awesome, but most of the times it looked like not in focus and crappy. All Panas have 1.5x desqueeze, and this Sirui is 1.6x so focusing was a bit of pain via S5II’s mediocre EVF, or my Saturn copy was just bad at focusing. In 4:3 3.3k50p mode it looked just bad and like out of focus all the time. Sold the Saturn, as frame graps from the 6k footage did not look as good as with spherical lenses. Miss the 2.4:1 AR though. Link to comment Share on other sites More sharing options...
newfoundmass Posted December 11, 2025 Share Posted December 11, 2025 Chinese lenses have gotten really good in general while remaining really affordable. I'm not shocked of the reports that the A7V isn't working well with them, and that Sony is now stressing they don't guarantee compatability. It's bad business every time one of the YouTuber shills favorably compare them to G Master lenses. The anamorphic lenses, including the auto focusing ones, coming out are very interesting. I've been waiting for a really good deal to pop up to try one out. Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted December 11, 2025 Author Administrators Share Posted December 11, 2025 I've yet to see any that have the rendering of an Iscorama or Soviet era LOMO, or the TOTL Hollywood lenses. They need to dial the coating down a lot and get rid of the very thin chickenwire flare. Anamorphic flare is much more than that as an aesthetic. Ninpo33 1 Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted December 11, 2025 Author Administrators Share Posted December 11, 2025 The modern lenses are closer to the Panasonic LA7200 in terms of look, just a lot sharper edge to edge. Whereas the Iscorama even when there's no flare still looks more cinematic and it borrows from the look of the taking lens you pair it with as well so you can play with that. There are no decent adapters as good as the Iscorama 2x. Still for £150 I am not complaining 🙂 Jahleh 1 Link to comment Share on other sites More sharing options...
J S H Posted December 11, 2025 Share Posted December 11, 2025 10 hours ago, Jahleh said: Had the 75mm Saturn with the S5II. With 6k25p open gate occasionally the footage looked awesome, but most of the times it looked like not in focus and crappy. All Panas have 1.5x desqueeze, and this Sirui is 1.6x so focusing was a bit of pain via S5II’s mediocre EVF, or my Saturn copy was just bad at focusing. In 4:3 3.3k50p mode it looked just bad and like out of focus all the time. Sold the Saturn, as frame graps from the 6k footage did not look as good as with spherical lenses. Miss the 2.4:1 AR though. I have the 35/50/75 Saturn in E mount and haven't experienced any focusing issues on the A1, and of course that's with no Desqueeze support. It does have a bit better EVF than the Panasonic cameras, but I haven't found the EVF to be a night and day difference. I own the 35 & 50 Saturn in L mount and have had great results on the S1RII. The 35 isn't quite as well corrected as the longer lenses, so it has a bit of character, especially against the light. Still, none of the Sirui lenses can rival the results I get with my favorite anamorphic adapters, but there is something to be said for simplicity and reliability. Also - I'm not sure if the S5II was included, but the recent update for the S1II/S1RII now provides 1.6x desqueeze. Still attached from the 35 Saturn on S1RII. newfoundmass, Jahleh and Ninpo33 3 Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted December 11, 2025 Author Administrators Share Posted December 11, 2025 8 minutes ago, J S H said: I have the 35/50/75 Saturn in E mount and haven't experienced any focusing issues on the A1, and of course that's with no Desqueeze support. It does have a bit better EVF than the Panasonic cameras, but I haven't found the EVF to be a night and day difference. I own the 35 & 50 Saturn in L mount and have had great results on the S1RII. The 35 isn't quite as well corrected as the longer lenses, so it has a bit of character, especially against the light. Still, none of the Sirui lenses can rival the results I get with my favorite anamorphic adapters, but there is something to be said for simplicity and reliability. Also - I'm not sure if the S5II was included, but the recent update for the S1II/S1RII now provides 1.6x desqueeze. Still attached from the 35 Saturn on S1RII. Yeah, thanks this shot is exactly what I'm talking about - the muted way it handles the sun is not what a good cinema anamorphic should look like. They don't have the big stretched ovals in the horizontal flare, the fatter flare lines and blooming. All these kids putting down pretty significant $$$$ for all this sterile stuff from China No question is it more practical though.... But better image it ain't 🙂 Jahleh and Ninpo33 2 Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted December 11, 2025 Author Administrators Share Posted December 11, 2025 By the way the collapse in price of the vintage stuff is extraordinary, you can get an Iscorama close to 500 euros now, almost back to 2010 pre-DSLR video prices Jahleh and Ninpo33 2 Link to comment Share on other sites More sharing options...
J S H Posted December 12, 2025 Share Posted December 12, 2025 3 hours ago, Andrew Reid said: Yeah, thanks this shot is exactly what I'm talking about - the muted way it handles the sun is not what a good cinema anamorphic should look like. They don't have the big stretched ovals in the horizontal flare, the fatter flare lines and blooming. All these kids putting down pretty significant $$$$ for all this sterile stuff from China No question is it more practical though.... But better image it ain't 🙂 Agreed completely on your assessment of the image characteristics. I truly appreciate the performance of classic anamorphic adapters and am happy that they are coming down in price. I just picked up a baby Kowa Anamorphic 8 2X for cheap and it's a jewel. A few examples of what I consider ideal performance below. First three are the ZIA 1.5x with an older Leica 50 Elmar collapsible, which is a tiny and wonderful combo that just covers full frame 3:2. Second is the baby hypergonar 1.75x with a Voigtlander 75 2.5, which also covers full frame but is a bit more muted (although this adapter can be fickle against the light sometimes). newfoundmass and maxJ4380 2 Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted December 12, 2025 Author Administrators Share Posted December 12, 2025 The Chinese are great but they need to watch this And this... Ninpo33 1 Link to comment Share on other sites More sharing options...
newfoundmass Posted December 12, 2025 Share Posted December 12, 2025 4 hours ago, J S H said: Agreed completely on your assessment of the image characteristics. I truly appreciate the performance of classic anamorphic adapters and am happy that they are coming down in price. I just picked up a baby Kowa Anamorphic 8 2X for cheap and it's a jewel. A few examples of what I consider ideal performance below. First three are the ZIA 1.5x with an older Leica 50 Elmar collapsible, which is a tiny and wonderful combo that just covers full frame 3:2. Second is the baby hypergonar 1.75x with a Voigtlander 75 2.5, which also covers full frame but is a bit more muted (although this adapter can be fickle against the light sometimes). I definitely like the way these look better but I still thought the 35 Saturn image looked good! To me, I'm just grateful that there are more options out there, as anamorphic has been out of my price range for a long time. And they'll only get better as they fine tune them. Ninpo33 1 Link to comment Share on other sites More sharing options...
J S H Posted December 13, 2025 Share Posted December 13, 2025 22 hours ago, newfoundmass said: I definitely like the way these look better but I still thought the 35 Saturn image looked good! To me, I'm just grateful that there are more options out there, as anamorphic has been out of my price range for a long time. And they'll only get better as they fine tune them. Yes. There is absolutely nothing wrong with the Sirui 35, especially for $500. I also expect Sirui to update their 1.6X lineup soon and add wider/longer lenses in the process. This is a really great time to be getting into anamorphic. There are so many great options amongst the newer Chinese made lenses...I can also recommend the Blazar Cato 2X lenses. I like 2X, especially with open gate and the Cato 85 & 125 are pretty nice lenses. I can get better results with an anamorphic adapter setup, but not without some hassles. Link to comment Share on other sites More sharing options...
J S H Posted December 15, 2025 Share Posted December 15, 2025 A couple more stills shot with the Sirui 35. Even though I have quite a few other options, this lens usually stays on my S1RII because it’s so versatile. newfoundmass and Ninpo33 2 Link to comment Share on other sites More sharing options...
Ninpo33 Posted December 18, 2025 Share Posted December 18, 2025 I am having a lot of fun with the Blazar Nero 1.5x adapter and the ability to fine tune the look based on various taking lenses. For me it really is an underrated adapter and it’s nice to be able to have a compact form factor. i got mine for $500 barely used and am looking to pick up a second one for my B cam. I’m excited to try it out on the 5K mode my new Lumix S1R because it performs well on Super 35 with a little less wild edge distortion. I have a whole desk full of vintage taking lenses to adapt so i’ll post some results once I get things dialed in. 52mm rear threads make it a nice fit for older 60’s glass and I’m adapting Canon FL, Kowa R’s, Miranda and Yashica stuff from the early 60’s. The amber flare option was removed from sale pretty early so i’ve had trouble finding one. The blue flares are more common but gives mixed results with my mostly amber coated 60’s/70’s glass. Link to comment Share on other sites More sharing options...
Ninpo33 Posted December 18, 2025 Share Posted December 18, 2025 Speaking of the Kowa R’s… If anyone is looking for a great taking lens option for anamorphic adapters the 50mm f1/1.8 can be had for cheap. $35 on average attached to a camera. There are adapters on ebay but i chose to go for a custom Leica M mount to keep it versatile. The 28mm, 35mm and 100mm have gotten crazy expensive due to cinema rehousing but the 50mm options are available still for cheap. There are also some rangefinder options but those require a bit more tinkering and i’ll save that for another post. Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted December 18, 2025 Author Administrators Share Posted December 18, 2025 Nice frog, thought it was real for a second 🙂 I have recently picked up another 'faulty' anamorphic from Sirui, cost 160 euros and this time is the Sirui 50mm T2.9 1.6x anamorphic for Sony E-mount. Repairing it was quite easy as whoever put it in the spares & repairs bin doesn't seem to know that the anamorphic squeeze and 'de-centered internal elements' are not the same thing 🙂 It's definitely not in same league as an Iscorama for character but it still has a cinematic look and much less distortion than the little Saturn from earlier. https://store.sirui.com/blogs/guides/full-frame-anamorphic-sirui-50mm-t2-9-1-6x-lens-review?srsltid=AfmBOooPLqqtjgePHhwDkxLrA3fHpbTeyJOCB631Vf1LeSC6Fh2TRP1N I think for $450 it's a bargain really. Ninpo33 1 Link to comment Share on other sites More sharing options...
Administrators Andrew - EOSHD Posted December 18, 2025 Author Administrators Share Posted December 18, 2025 13 hours ago, Ninpo33 said: I am having a lot of fun with the Blazar Nero 1.5x adapter Got any shots from that? Ninpo33 1 Link to comment Share on other sites More sharing options...
Ninpo33 Posted December 18, 2025 Share Posted December 18, 2025 2 hours ago, Andrew - EOSHD said: Got any shots from that? Right now I’m out of town, but before I left, I was waiting on a couple step up rings from Amazon so I can fit some of these older taking lenses. I think the Miranda‘s are gonna work out really well and they have a 46 mm front filter thread, which works out perfect for the 52 mm rear on the Nero adapter. I’m going to do a shoot out with the Kowa R’s and some of the other 60’s glass on both Lumix S1 R, and the Fuji sensor in super 35 modes. I’ve seen good results with Super 35 on the FX30. Here are a couple links in the meantime. First one is pretty clean without showing much character but i like to see how it could look for corporate work. The other two show the versatility of choosing various vintage glass. Link to comment Share on other sites More sharing options...
J S H Posted December 19, 2025 Share Posted December 19, 2025 11 hours ago, Andrew - EOSHD said: Got any shots from that? I own the Blazar adapter and have used it extensively. I like that it can go wide, most 40-45 vintage lenses will cover full frame, especially if they have 52mm threads. It will even work with a few older 35-70 zooms past about 40mm. It's a little dreamy on the sides when using wider lenses, but once you go to around 75mm, it cleans up across the frame. It also has great focusing performance - with the taking lens set at infinity, you can do it all with the focus ring on the adapter and even wide open, infinity is spot on with every lens I've tried. Below are a few samples I have handy. First two shots are the 50 Nokton around F8. With my copy of the adapter, no amount of stopping down cleans up the edges on 40-50mm lenses. 3rd Shot is the 58 Biotar. Next 3 shots are the 75 Nokton. Image is great across the frame when stopped down a bit, but there is some fringing with the lens wide open. Andrew - EOSHD 1 Link to comment Share on other sites More sharing options...
