Hi Speed Cameras
leafcutter
I was playing around with my iPhone the other day taking shots at 240fps and was quite impressed with the results.  It got me thinking that if 240fps was readily available at consumer level is there anything out there that is faster and still relatively easily available?  I was reading about a motion tracking device that claims a camera speed of 10,000 fps - ok it costs several thousand dollars but presumably not all of that is the cost of the camera hardware.
Are there easily available high fps cameras out there (that maybe you could hook up to a computer for processing) or is it all in the realms of high cost specialist equipment?
I used the FS7 on a couple of projects recently which go up to 180 fps. I feel like that or maybe 240 is an slow as you'd need for 99% of film making shots. There are those times when you need a Phantom type slo-mo for mythbusters or a science program. To me the gap between 60fps and 240fps is key.
