Lomo square front 35 as adapter
robbing
Hi,
If someone want one:
I found this one in Ebay.
http://www.ebay.es/itm/Lomo-Anamorphic-Block-35-10-3-F-35-1-2-5-/191647965185?hash=item2c9f1be001&clk_rvr_id=878482198961&rmvSB=true
I have the same one and I use it as adapter because I missing the focus mechanism of his prime.
Perhaps is a good opportunity.
Using this Lomo as adapter is the only one ANA x2 that can use very wide angle lens,from 28mm or 24mm to tele lens in APS or 4-perf 35mm film gate.
Close focus to 1m. 90º focus ring turn from 1m to infinite. Panavision like flares.
The ironic is that front ANA get better result with modern primes than his own spherical prime.
THE ISSUE: double focus. (Until someone develop a focus module for this Lomo. if this happens,I´m done...no more anamorphic lens searching,a huge ANA set just with one adapter)
Artifacts:
Barrel distortion
Chromatic aberration on the edges. (More noticeable using wide angle primes)
very Mump effects
very blue flares.
.....Anamorfic...you know.
