dwijip Posted August 6, 2015 Share Posted August 6, 2015 First time actually utilising the Anamorphic option on the GH4 as there is no HDMI out in this mode. This was a just a little sketch I did in my room, by myself using the ImgApp. It is really great that the anamorphic mode can produce a 4:3 ratio image but it comes with some catchlines like no 1080p, no HFR, no HDMI out etc. For me it kind of gets pointless trying to use a tiny LCD screen for monitoring when you've got your camera heavily rigged up for shooting with other gear. So I guess I will stick with just 16:9 and cropping and hope for a firmware update. Speaking of firmware updates, jesus christ are they going to ferment V log before they release it. Zak Forsman 1 Link to comment Share on other sites More sharing options...
EricStephan Posted May 3, 2018 Share Posted May 3, 2018 Hi, there never came a firmware update out which allows hdmi out or record in 1080p right? Annoyed of it.. have you found a workaround? Link to comment Share on other sites More sharing options...
tweak Posted May 3, 2018 Share Posted May 3, 2018 4 hours ago, EricStephan said: Hi, there never came a firmware update out which allows hdmi out or record in 1080p right? Annoyed of it.. have you found a workaround? 1080p 4:3 doesn't exist on other pannys either. I can see the draw card for higher frame rates or really slow computers, but honestly the IQ drop you get with anamorphic makes 1080p from most cameras look pretty crappy imo. If you can it's much better to just film in 4K and downsample or make proxies if you need to. On GH5 it's even another level again with the 6K mode, it just makes anamorphic lenses look so nice, the way they take the harshness off what is mostly a pretty digital looking sensor/image, it makes me want to shoot everything in 6K... but then I have no 60p same with HLG. Link to comment Share on other sites More sharing options...
EricStephan Posted May 7, 2018 Share Posted May 7, 2018 On 3.5.2018 at 3:15 PM, tweak said: 1080p 4:3 doesn't exist on other pannys either. I can see the draw card for higher frame rates or really slow computers, but honestly the IQ drop you get with anamorphic makes 1080p from most cameras look pretty crappy imo. If you can it's much better to just film in 4K and downsample or make proxies if you need to. On GH5 it's even another level again with the 6K mode, it just makes anamorphic lenses look so nice, the way they take the harshness off what is mostly a pretty digital looking sensor/image, it makes me want to shoot everything in 6K... but then I have no 60p same with HLG. Is it true that you can monitor the GH5 in anamorphic mode in 4k with any external monitor? But not in 6k. Link to comment Share on other sites More sharing options...
tweak Posted May 13, 2018 Share Posted May 13, 2018 On 07/05/2018 at 3:39 PM, EricStephan said: Is it true that you can monitor the GH5 in anamorphic mode in 4k with any external monitor? But not in 6k. Yes. Link to comment Share on other sites More sharing options...
