robtilbury Posted August 11, 2015 Share Posted August 11, 2015 Hey guys,Hope all is well.Been experimenting with the new 4:3 morph mode on the gh4.I run the feed through to a Marshall 5" external (VLCD51) and has been fine for run and gun for the last year or so.Ever since updating the firmware 2.2 I cannot get the monitor to display.I get a message saying 'Anamorphic (4:3) Enabled" and I cant get rid of it.I have played around with the HDMI out settings on the camera, obviously setting it to downscale to 1080p. The weird part is if i turn off the 'info display' in the HDMI out settings I can get a picture on the monitor but as soon as i hit record it goes black again...Super frustrating as I want to use the new 4:3 on a upcoming job but simply cannot deal without a monitor.Who on here has been using 4:3 mode with a external? please state which ones are working. Also tried to touch base with Marshall re firmware update for the 5" and had no luck. CheersRob Link to comment Share on other sites More sharing options...
anti12 Posted August 11, 2015 Share Posted August 11, 2015 @robtilbury you have to set the camera to 10bit (disabling internal recording) This will resize the 4:3 image to fit into a standard 16:9 4k Frame (loosing some resolution) I think you need at least an atomos shogun to monitor, de-squeeze and record anamorphic 4:3 Link to comment Share on other sites More sharing options...
