ricardo_sousa11 Posted August 23, 2015 Share Posted August 23, 2015 Hi,One of the "issues" with the NX1 is time to convert HEVC. So using a LUT will speed up, thanks for helping the community with this. But I was thinking differently: can we get a setting out of the box, straight from camera and still have a cinematic look?Here are my settings:Settings:Gamma DRSaturation -2Sharpness -5Contrast +5 yes, it is really plus 5Hue 0Hand heldHEVC convert with ffmpeg script:echo start > ff.logdate >> ff.logfor F in *.MP4do OUT=`echo $F | sed s/MP4/mov/ ` ffmpeg -i $F -c:v prores_ks -strict -2 $OUTdone echo end >> ff.logdate >> ff.logStraight from camera, no color grading, only stabilized in FCPxCheers,Jorgen :-)These look absolutely gorgeous ! Will have to try out these settings ! Link to comment Share on other sites More sharing options...
Marco Tecno Posted August 24, 2015 Share Posted August 24, 2015 What I'd need from samsung is the possibility of storing different settings for video so to recall them fast and handy! Please samsung... iamoui and Werner H. Graf 2 Link to comment Share on other sites More sharing options...
ricardo_sousa11 Posted August 24, 2015 Share Posted August 24, 2015 Just graded (quick 1 minute grade) a clip of my last wedding (first job with the NX1), without this LOG, will later use the log to grade and see how it differs.Im still pretty noob at grading, still trying to learn how to grade with LUTs, curves and all that, but this camera..its just amazing what comes out of it...trully something incredible. This was shot with the Canon f1.8 at f1.8. The colors are still a bit off, skin looks a bit greyish and what not. Link to comment Share on other sites More sharing options...
ricardo_sousa11 Posted August 24, 2015 Share Posted August 24, 2015 Improvement over the last edit : kidzrevil, Marco Tecno, sandro and 2 others 5 Link to comment Share on other sites More sharing options...
LimitBreak Posted August 27, 2015 Share Posted August 27, 2015 The encoding I tested was HEVC -> ProRes 422HQIn the program I had to select ProRes 4k in order to be able to apply the LUT, I tested it both with 1080p100 and 2160p25 and it applied the LUT fine, some of my older 1080p25 overcranked footage before the increasing bitrate firmware came I see extreme banding in the sky but that might also just be me tweaking the settings to give me a flat profile with this ¤/!%#@( 8bit codec.The 1080p100 footage wont convert in ProRes 4k mode, I assumed its because ProRes does not support 100 fps or the program is simply incapable of it, though it will slow the footage down for you.DNxHD does not have the LUT option available its greyed out for some reasons, MXF is useless it gets wrapper problems, the MPEG Intra are 8bit only also useless, the TIFF 48bit mode worked fine for me as well with the LUT so did H264 export. As for 25fps render for a 25p project file which was for ProRes, my computer is quite beefy so it tends to spit out 10 minute HEVC files in RockyMountains Converter in 2 minutes to ProRes10 minutes HEVC clip to ProRes in 2 minutes ? Computer specs please iamoui 1 Link to comment Share on other sites More sharing options...
Werner H. Graf Posted August 30, 2015 Share Posted August 30, 2015 Sunnyday in a Swiss Garden NX 1, 16-50mm S, 1.4 Firmware. OSS & DIS, ND FilterCould be much slower movement with the new big Gimbal. Last clips DIS only MF Meyer Görlitz Primoplan 1.9 58 mm from 1960 a creamy buttery Bokeh...https://www.dropbox.com/s/cgpaemplziyz9lf/Samsung%20Garten.m4v?dl=0No grading. Part with Gamma C, some DR Settings from Andrew Reid's Setup Guide. UHD 25p FCPX 1080 50p, Conversion Edit ReadySome are Over exposed and some with 1/3 underhttp://www.eoshd.com/2015/08/new-eoshd-setup-guide-gives-samsung-nx1-log-capability-and-more/Filmed by my friend Cameramen/Producer/Regisseur. His house is in a medow with a view to mount Pliatus gorgeous!Together we made some Cinema Documentrys all over the world. The next one is about 4 Caregiver's supporting dying people. Link to comment Share on other sites More sharing options...
Marco Tecno Posted August 30, 2015 Share Posted August 30, 2015 Wow, dis is huge :-P When you say no grading, you mean out of camera with which settings? Link to comment Share on other sites More sharing options...
SMGJohn Posted September 8, 2015 Share Posted September 8, 2015 10 minutes HEVC clip to ProRes in 2 minutes ? Computer specs please System Specs:Clevo P150EMIntel Core i7-3940XMAMD Radeon M295X16GB of DDR3L 1600Mhz ram runs at 1333MhzCrucial M500 960GB SSD + Crucial 512GB mSSD + 2TB Samsung HDD That is RockyMountains Converter, ClipToolz v2 is usually a lot slower for God knows why, Adobe Media Encoder CC 2015 is also quite fast taking in the ProRes files and converting them to DNxHD444 in fact its almost faster than RockyMountains when I do 100 or 120fps LUT converting because I work with some people that uses FCPX and it does not like DNxHD and because ClipToolz does not like 100fps nor 120fps files I gotta convert it to ProResHQ (RockeyMountains) --> DNxHD444 with LOG (Media Encoder) --> ProResLT (RockeyMountains) Link to comment Share on other sites More sharing options...
eltorrete Posted September 12, 2015 Share Posted September 12, 2015 helloI'm delighted with your guide thank you very much for it.I wanted to ask what Deluts pack recommended for Nx1?and wath Samsung lens are best for video 45mm or 35mm? Link to comment Share on other sites More sharing options...
SMGJohn Posted September 13, 2015 Share Posted September 13, 2015 helloI'm delighted with your guide thank you very much for it.I wanted to ask what Deluts pack recommended for Nx1?and wath Samsung lens are best for video 45mm or 35mm?Best lenses for Samsung camera regarding video is obviously the Samyang/Rokinon/Bower lenses which are cheap ultra-fast cine lenses with great value for what you get.Check this out for best deals on them: https://***URL not allowed***/the-best-samyang-rokinon-bower-cine-lens-deals-updated-sep-18th/ Remember that not all of them are APS-C size so you gotta apply crop factor on some of them since they are full-frame (Crop factor for NX1 is x1.53)If you just want an all around cheap and good Samsung lens for video I recommend the Samsung Compact 18-55mm f/3.5-5.6 OIS Zoom Lens its good value for money and it covers most of the zoom ranges you would need in video. If you need extra wide I recommend the Samsung Compact 12-24mm f/4-5.6 ED and of course if you got cash to burn get the Samsung 16-50mm f/2-2.8 OIS S lens. I do not really recommend neither the 45mm nor the 35mm because no one will notice the picture difference from them to the 12-24mm or the 18-55mm when it comes to video, these lenses are designed for high megapixel usage with Samsung cameras and the max you will use these for videos are generally 1080p and 2160p so the distortion is minimal. Link to comment Share on other sites More sharing options...
deezid Posted September 13, 2015 Share Posted September 13, 2015 These look absolutely gorgeous ! Will have to try out these settings !Cinematic is definitely the wrong term here. Looks oversharpened as hell and has a strange magenta cast. At least no burnt out highlights. Link to comment Share on other sites More sharing options...
eltorrete Posted September 16, 2015 Share Posted September 16, 2015 Best lenses for Samsung camera regarding video is obviously the Samyang/Rokinon/Bower lenses which are cheap ultra-fast cine lenses with great value for what you get.Check this out for best deals on them: https://***URL not allowed***/the-best-samyang-rokinon-bower-cine-lens-deals-updated-sep-18th/ Remember that not all of them are APS-C size so you gotta apply crop factor on some of them since they are full-frame (Crop factor for NX1 is x1.53)If you just want an all around cheap and good Samsung lens for video I recommend the Samsung Compact 18-55mm f/3.5-5.6 OIS Zoom Lens its good value for money and it covers most of the zoom ranges you would need in video. If you need extra wide I recommend the Samsung Compact 12-24mm f/4-5.6 ED and of course if you got cash to burn get the Samsung 16-50mm f/2-2.8 OIS S lens. I do not really recommend neither the 45mm nor the 35mm because no one will notice the picture difference from them to the 12-24mm or the 18-55mm when it comes to video, these lenses are designed for high megapixel usage with Samsung cameras and the max you will use these for videos are generally 1080p and 2160p so the distortion is minimal.thank you very much, I think we will try to find a Samyang 35mm or 24mm Link to comment Share on other sites More sharing options...
Joebizzle Posted September 23, 2015 Share Posted September 23, 2015 I have been trying to buy the NX1 guide for a few weeks now and the link not active, keeps giving an error404. Does anyone know where the right link is? Can anyone help. Thank you. JGlimmer 1 Link to comment Share on other sites More sharing options...
MonGe El GenioMusical Posted September 28, 2015 Share Posted September 28, 2015 I have been trying to buy the NX1 guide for a few weeks now and the link not active, keeps giving an error404. Does anyone know where the right link is? Can anyone help. Thank you.same here! i was going to try it out.. JGlimmer 1 Link to comment Share on other sites More sharing options...
Brother Posted September 28, 2015 Share Posted September 28, 2015 I have been trying to buy the NX1 guide for a few weeks now and the link not active, keeps giving an error404. Does anyone know where the right link is? Can anyone help. Thank you.same here! i was going to try it out..Nothing wrong with the link in the sidebar: http://www.eoshd.com/samsung-nx1-video-settings-guide-tutorial/ Link to comment Share on other sites More sharing options...
Candye Posted October 19, 2015 Share Posted October 19, 2015 save my time, thank you very much. Link to comment Share on other sites More sharing options...
kidzrevil Posted November 3, 2015 Share Posted November 3, 2015 is it worth investing in Samsung glass ? I'm a little worried about being locked into the system but I feel like this camera will perform best with a lens set optimized for the nx mount such as the one made by Samsung Link to comment Share on other sites More sharing options...
kidzrevil Posted November 3, 2015 Share Posted November 3, 2015 Improvement over the last edit : wow Link to comment Share on other sites More sharing options...
ricardo_sousa11 Posted November 3, 2015 Share Posted November 3, 2015 is it worth investing in Samsung glass ? I'm a little worried about being locked into the system but I feel like this camera will perform best with a lens set optimized for the nx mount such as the one made by Samsung I'd love to get the 16-50S lens, it really seems like an amazing piece of glass, but I cant see myself paying 1k€ for that lens, considering it would be hard to resell. I bought the 30mm f2 for 150€ and im really happy with it, so happy im selling my Samyang 24mm f1.4, since I rarely use it anymore. Link to comment Share on other sites More sharing options...
Marco Tecno Posted November 3, 2015 Share Posted November 3, 2015 Ricardo, if your intention is to keep the nx1 for a couple of years, then definitely buy the 16-50s. Otherwise, don't. Also the 50-150s is gorgeous.P.s. even the 16-50pz is really nice, especially for video. Tiny, stabilized, cheap. Link to comment Share on other sites More sharing options...
