Van Diemen ISCO conversion II
jaquet
http://vandiemenbroadcast.co.uk/epages/eshop406899.sf/en_GB/?ObjectPath=/Shops/eshop406899/Products/7235
EARLY ADOPTERS DISCOUNT OF 5% FOR ORDERS TAKEN DURING JUNE 2015. USE VOUCHER CODE - Isco June Offer - at checkout
The Cine Iscorama Anamorphic II can be designed to suit a number of focal length lenses and formats.
General Specifications:
Static front ring with 77mm front thread.
The back thread diameter is typically 58mm at a standard pitch of 0.75mm (filter thread).
The front lens cap diameter is 80mm.
Once screwed into position the Anamorphic can be aligned and locked.
Close Focus is 3ft 7in.
End to end focus rotation is around 180 degrees.
1/4" Whitworth threaded hole for support is provided as standard.
Support system for 15mm bars at 600mm (apart) is available at extra cost.
ISCO_II_Assembly_View.thumb.jpg.090e43ea
  • 3 years later...
