Inazuma Posted August 13, 2015 Share Posted August 13, 2015 Hi allI have an external monitor which is quite light, but after putting one of these bad boy batteries in (Sony NPF970) my shoulder rig ends up leaning to one side a bit too much. I was thinking, is there some kind of product which will allow me to mount the batteries onto the back of my 15mm rail rig and then using cables, gives power to the monitor? Link to comment Share on other sites More sharing options...
Zak Forsman Posted August 13, 2015 Share Posted August 13, 2015 IndiPro makes this...http://www.bhphotovideo.com/c/product/1019817-REG/indipro_tools_ipgrid_pksony_dual_sony_7_2v_battery.html/prm/alsVwDtl Link to comment Share on other sites More sharing options...
User Posted August 13, 2015 Share Posted August 13, 2015 Can someone point me towards a unit like this that can easily be bolted to a small cage that houses an A7rII while powering it? Link to comment Share on other sites More sharing options...
docmoore Posted August 14, 2015 Share Posted August 14, 2015 Can someone point me towards a unit like this that can easily be bolted to a small cage that houses an A7rII while powering it?Wooden Camera has a fairly complete line of products ...This is the high end for the Sony A7 series.... http://woodencamera.com/Sony/Camera-Support-Sony/Sony-A7s-Accessory-Kit-Pro.html but look at their complete listings. Bob aldolega 1 Link to comment Share on other sites More sharing options...
Inazuma Posted August 14, 2015 Author Share Posted August 14, 2015 IndiPro makes this...http://www.bhphotovideo.com/c/product/1019817-REG/indipro_tools_ipgrid_pksony_dual_sony_7_2v_battery.html/prm/alsVwDtlThanks, that's almost ideal! If the power connector were DC it'd be spot on. In fact, is there some kind of adapter? Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted August 14, 2015 Super Members Share Posted August 14, 2015 I have this one.Can be had with various connectors and it also has a regular power outlet so you can use whatever cable you want.It has a regular 1/4" screw to mount on a regular cage, arm, what have you.It can also be bought with clamps.I you zoom in on the left side on the eBay picture you se the second outlet which is a standard power outlet.http://www.ebay.com/itm/Blackmagic-BMCC-Camera-Battery-Mount-Plate-Power-Supply-Adapter-For-Sony-BP-U60-/370877762077?pt=UK_Camera_Battery_Grips&hash=item565a098a1d User and Inazuma 2 Link to comment Share on other sites More sharing options...
User Posted August 14, 2015 Share Posted August 14, 2015 Thank you Mattias. Link to comment Share on other sites More sharing options...
