Brian Caldwell Posted September 24, 2016 Share Posted September 24, 2016 On 9/24/2016 at 1:17 AM, Bioskop.Inc said: So is this the reason that people think that the 54 is less sharp than the 36, especially when shooting with a lens wide open, because in fact you won't be shooting at the aperture that you think you're shooting at? So in fact, when shooting with a 54 you really are shooting at the right aperture & so it will reveal the taking lens to either be sharp wide open or soft - nothing to do with the attachement, but more to do with the taking lens? Expand Its definitely a factor, and it certainly helps to be aware of what is actually the limiting aperture in the system. Even the Iscorama-54 isn't large enough to avoid stopping down an 85mm f/1.2. Although I don't have the Iscorama-54 design prescription and can't accurately evaluate its performpance, I do expect that it has plenty of aberrations on its own, especially at full aperture. A good test of the 36 vs 54 would be to use a prime lens with great performance that has an entrance pupil larger than 54mm. The 85mm Zeiss Otus comes to mind . . . Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted September 24, 2016 Share Posted September 24, 2016 On 9/24/2016 at 4:03 AM, Brian Caldwell said: Its definitely a factor, and it certainly helps to be aware of what is actually the limiting aperture in the system. Even the Iscorama-54 isn't large enough to avoid stopping down an 85mm f/1.2. Although I don't have the Iscorama-54 design prescription and can't accurately evaluate its performpance, I do expect that it has plenty of aberrations on its own, especially at full aperture. A good test of the 36 vs 54 would be to use a prime lens with great performance that has an entrance pupil larger than 54mm. The 85mm Zeiss Otus comes to mind . . . Expand Well I don't have a 36 anymore (not for a long time), but do have 2 other Isco-Gottingen made anamorphics (widescreen 2000 & Iscomorphot s8/x2 - both fixed focus), so might be worth a try to see what the difference is between different anamorphic back element sizes. The largest fast 85mm I have is the Helios 40-2, which is f1.5 & it looks like the pupil size is slightly larger than 54mm. Link to comment Share on other sites More sharing options...
AaronChicago Posted September 24, 2016 Share Posted September 24, 2016 This thread may be helpful for me. I just got the Rangefinder to use with my Takumar 50mm and Singer 16D. I did some testing with/without the rangefinder and the background is stretched vertically by quite a bit with the RF. Is that normal? It's rather odd looking compared to the "anamorphic only" footage. I can still return it and get the Rectilux but I wanted to find out if that's a characteristic of both, or just the RF. Link to comment Share on other sites More sharing options...
Hans Punk Posted September 24, 2016 Share Posted September 24, 2016 On 9/24/2016 at 3:46 PM, AaronChicago said: This thread may be helpful for me. I just got the Rangefinder to use with my Takumar 50mm and Singer 16D. I did some testing with/without the rangefinder and the background is stretched vertically by quite a bit with the RF. Is that normal? It's rather odd looking compared to the "anamorphic only" footage. I can still return it and get the Rectilux but I wanted to find out if that's a characteristic of both, or just the RF. Expand Quite normal...at least from my experience with DNA or any diopter for that matter. Oval bokeh stretch is often increased. It can be a good trade off when closing down on taking lens to retain sharpness on many scope lenses, since the apparent oval defocus is then reduced to a more 'regular' looking stretch ratio, akin to shooting with the taking lens with an open aperture when no diopter is used. Since most modern cameras perform very well at higher iso's...the effective loss of light by stopping down is far less of an issue. For example, Ive found f4 - f5.6 on Core DNA gives a comparable oval defocus stretch value to having the taking lens set at f2 - 2.8 when no diopter is up front. From most single-element diopters I've tried - I'd say f4 is as wide as you'd want to be to help avoid funky glows and highlight ghosting when used in front of most scope lenses....there is still plenty of defocus stretch, due to the diopter 'effect'. My advice to anyone using any of the vari-diopter solutions is to stop down 2-3 stops more than you would normally...so as to give the single-element optics a fighting chance at resolving sharpness, without ugly highlight edge artefacts...there will still be plenty of shallow depth of field for those who crave it. Ian Edward Weir, AaronChicago and Timotheus 3 Link to comment Share on other sites More sharing options...
AaronChicago Posted September 24, 2016 Share Posted September 24, 2016 On 9/24/2016 at 5:09 PM, Hans Punk said: Quite normal...at least from my experience with DNA or any diopter for that matter. Oval bokeh stretch is often increased. It can be a good trade off when closing down on taking lens to retain sharpness on many scope lenses, since the apparent oval defocus is then reduced to a more 'regular' looking stretch ratio, akin to shooting with the taking lens with an open aperture when no diopter is used. Since most modern cameras perform very well at higher iso's...the effective loss of light by stopping down is far less of an issue. For example, Ive found f4 - f5.6 on Core DNA gives a comparable oval defocus stretch value to having the taking lens set at f2 - 2.8 when no diopter is up front. From most single-element diopters I've tried - I'd say f4 is as wide as you'd want to be to help avoid funky glows and highlight ghosting when used in front of most scope lenses....there is still plenty of defocus stretch, due to the diopter 'effect'. My advice to anyone using any of the vari-diopter solutions is to stop down 2-3 stops more than you would normally...so as to give the single-element optics a fighting chance at resolving sharpness, without ugly highlight edge artefacts...there will still be plenty of shallow depth of field for those who crave it. Expand Thanks! Great info. Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted September 25, 2016 Share Posted September 25, 2016 On 9/24/2016 at 3:46 PM, AaronChicago said: This thread may be helpful for me. I just got the Rangefinder to use with my Takumar 50mm and Singer 16D. I did some testing with/without the rangefinder and the background is stretched vertically by quite a bit with the RF. Is that normal? It's rather odd looking compared to the "anamorphic only" footage. I can still return it and get the Rectilux but I wanted to find out if that's a characteristic of both, or just the RF. Expand Good choice in taking lens, I've found that Super Taks are a great sharp taking lens with Anamorphics. As far as the extra stretched background, that's a bonus - oval out of focus areas is why a lot of us use anamorphics (Yes, it's not the flares! You get over them very quickly once they ruin a great shot & by ruin, I mean obscure what you really want people to be looking at, & yes that's not the flares). AaronChicago 1 Link to comment Share on other sites More sharing options...
AaronChicago Posted September 25, 2016 Share Posted September 25, 2016 On 9/25/2016 at 12:54 AM, Bioskop.Inc said: Good choice in taking lens, I've found that Super Taks are a great sharp taking lens with Anamorphics. As far as the extra stretched background, that's a bonus - oval out of focus areas is why a lot of us use anamorphics (Yes, it's not the flares! You get over them very quickly once they ruin a great shot & by ruin, I mean obscure what you really want people to be looking at, & yes that's not the flares). Expand Yeah I agree with oval bokeh and totally out of focus areas, but this is the entire frame, including the parts that are partially in focus. Everything except the dead center. Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted September 25, 2016 Share Posted September 25, 2016 On 9/25/2016 at 10:53 AM, AaronChicago said: Yeah I agree with oval bokeh and totally out of focus areas, but this is the entire frame, including the parts that are partially in focus. Everything except the dead center. Expand The way that you've written this sounds like it is a problem, can you throw up an image or 2? One thing that the Super Taks are renowned for is their thin plane of focus when wide open, but am assuming that this isn't the case.... Also, as Hans said, Diopters will introduce more distortion to the anamorphic qualities & this can produce an overly soft extra-stretched effect. Good quality diopters (doublets, not singlets) tend to control this more, but can still be present. I've found this to be a problem & now now tend to use longer taking lenses with my Iscorama, when i want to do close-ups etc... I also find getting too up close & personal with real people can be off putting for everyone concerned - objects don't get put off! Hans Punk and graphicnatured 2 Link to comment Share on other sites More sharing options...
sketch2099 Posted October 15, 2016 Share Posted October 15, 2016 Some frame grabs from a recent shoot with the Rectilux CoreDNA, Schneider ES Cinelux, Contax Zeiss, & Ursa Mini 4.6K. More frame grabs here: https://www.flickr.com/photos/seekingheartwood/albums/72157673728625850/with/29553327104/ Liszon, Ian Edward Weir and Juank 3 Link to comment Share on other sites More sharing options...
Liszon Posted October 15, 2016 Share Posted October 15, 2016 Hey Sketch, do you have a picture of your rig? How do you like the Mini 4.6K so far? By the way, I downloaded your shots from Flickr, and when viewed in full res I can see a vertical line pattern embedded in the image. Is that visible in the source files as well? What format where you shooting in? Link to comment Share on other sites More sharing options...
sketch2099 Posted October 15, 2016 Share Posted October 15, 2016 Hi Liszon, thanks for reminding me to change my privacy settings on Flickr. Those stills are from an unreleased project and I should try to prevent quite so many stills from being downloadable. There's some FPN in some of the images from the Ursa Mini 4.6K where I pushed the sensor pretty hard. I can clean it up, but I just did a super quick grade for those stills until the director sits down with the colorist. Shooting in 4:1 compressed raw. No images of the camera build, but it's pretty standard, rails, lens supports and lenses. Liszon 1 Link to comment Share on other sites More sharing options...
Grimor Posted July 19, 2020 Share Posted July 19, 2020 Someone know how to adjust infinity of core dna? I realized that my anamorphic and taking can reach perfect infinity point, but is in the single solution where I can't reach to the infinite and beyond! Link to comment Share on other sites More sharing options...
Timotheus Posted July 19, 2020 Share Posted July 19, 2020 On 7/19/2020 at 1:03 PM, Grimor said: Someone know how to adjust infinity of core dna? I realized that my anamorphic and taking can reach perfect infinity point, but is in the single solution where I can't reach to the infinite and beyond! Expand Sorry to hear. How long have you had Hardcore DNA? There is a known batch with optical issues, more specifically not reaching infinity. Has been discussed a few times on Anamorphic Shooters facebook group. Best bet is to contact John and ask for replacement glass. Might be an issue though if you are not the first owner. Grimor 1 Link to comment Share on other sites More sharing options...
Grimor Posted July 19, 2020 Share Posted July 19, 2020 On 7/19/2020 at 8:37 PM, Timotheus said: Sorry to hear. How long have you had Hardcore DNA? There is a known batch with optical issues, more specifically not reaching infinity. Has been discussed a few times on Anamorphic Shooters facebook group. Best bet is to contact John and ask for replacement glass. Might be an issue though if you are not the first owner. Expand OMG I buy it secondhand on eBay. @JohnBarlow how can I see if is one of those batch? Link to comment Share on other sites More sharing options...
Grimor Posted July 20, 2020 Share Posted July 20, 2020 3 samples of my combo: 1 taking solo 2 taking and anamorphic 3 taking, anamorphic and core dna On 7/19/2020 at 8:37 PM, Timotheus said: Sorry to hear. How long have you had Hardcore DNA? There is a known batch with optical issues, more specifically not reaching infinity. Has been discussed a few times on Anamorphic Shooters facebook group. Best bet is to contact John and ask for replacement glass. Might be an issue though if you are not the first owner. Expand Link to comment Share on other sites More sharing options...
Timotheus Posted July 20, 2020 Share Posted July 20, 2020 Yeah it seems off by a bit. Make sure you test extensively by finetuning focus on all three lenses with magnified view. If it's impossible to reach infinity try to reach John directly through Facebook. Or, if there is still time, the seller you bought it from? Grimor 1 Link to comment Share on other sites More sharing options...
Grimor Posted July 20, 2020 Share Posted July 20, 2020 On 7/20/2020 at 8:15 PM, Timotheus said: Yeah it seems off by a bit. Make sure you test extensively by finetuning focus on all three lenses with magnified view. If it's impossible to reach infinity try to reach John directly through Facebook. Or, if there is still time, the seller you bought it from? Expand I bought it 2 years ago. All this time I was thinking I have to fine tunning my Kowa like Tito do in his video. My bad. Link to comment Share on other sites More sharing options...
