DayRaven Posted April 11, 2016 Share Posted April 11, 2016 19 hours ago, shooter said: But, even able to do one for sure, this "one" can end to devastate the shutter, no? My point is: can G7 offer the same as A7RII? A7RII offers slow shutter in video 25fps 4K. Can I mimic the same with G7 or similar camera without devastating the shutter? If it's in a video mode - options 1, 2 or 3 from my post, it won't use the mechanical shutter, so you're fine. If you're using option 4, manual stills mode, you must ensure you engage the electronic shutter, not the mechanical one because yes, it will put wear on the mechanism Link to comment Share on other sites More sharing options...
shooter Posted April 11, 2016 Author Share Posted April 11, 2016 2 hours ago, DayRaven said: If it's in a video mode - options 1, 2 or 3 from my post, it won't use the mechanical shutter, so you're fine. If you're using option 4, manual stills mode, you must ensure you engage the electronic shutter, not the mechanical one because yes, it will put wear on the mechanism Thank you for help. I know mechanical shutter has a short cycle of life for multiple frames per second for sure. About the electronic shutter, no more wear than to use it comparing with A7RII going on 1/5th shutter once in this latter case (A7RII) is video mode?? Link to comment Share on other sites More sharing options...
DayRaven Posted April 11, 2016 Share Posted April 11, 2016 15 hours ago, shooter said: Thank you for help. I know mechanical shutter has a short cycle of life for multiple frames per second for sure. About the electronic shutter, no more wear than to use it comparing with A7RII going on 1/5th shutter once in this latter case (A7RII) is video mode?? You're welcome, any camera with electronic shutters - which is any camera with a video mode has zero wear on the mechanics when that is engaged. If in doubt, take a single still photo, listen to the sound with electronic shutter engaged and disengaged. When it is using the mechanical shuitter you can hear, and often feel the mechanism working. Do a test shoot in your chosen mode, just a few seconds won't put any appreciable milage on your camers and it will quickly be apparent from the noise whether you are or not putting wear on the camera Good luck and have fun! Link to comment Share on other sites More sharing options...
shooter Posted April 11, 2016 Author Share Posted April 11, 2016 19 minutes ago, DayRaven said: You're welcome, any camera with electronic shutters - which is any camera with a video mode has zero wear on the mechanics when that is engaged. If in doubt, take a single still photo, listen to the sound with electronic shutter engaged and disengaged. When it is using the mechanical shuitter you can hear, and often feel the mechanism working. Do a test shoot in your chosen mode, just a few seconds won't put any appreciable milage on your camers and it will quickly be apparent from the noise whether you are or not putting wear on the camera Good luck and have fun! That one I understood. I am just wondering if the wear on the camera with the electronic shutter using the G7 is the same going with the A7RII in video mode / slowest shutter speed... Link to comment Share on other sites More sharing options...
shooter Posted April 12, 2016 Author Share Posted April 12, 2016 I meant wear other than mechanical shutter. Does electronic shutter have zero wear? No, isn't it? Does A7RII have the same wear with slowest shutter speed in video mode? 6 hours ago, DayRaven said: You're welcome, any camera with electronic shutters - which is any camera with a video mode has zero wear on the mechanics when that is engaged. If in doubt, take a single still photo, listen to the sound with electronic shutter engaged and disengaged. When it is using the mechanical shuitter you can hear, and often feel the mechanism working. Do a test shoot in your chosen mode, just a few seconds won't put any appreciable milage on your camers and it will quickly be apparent from the noise whether you are or not putting wear on the camera Good luck and have fun! Link to comment Share on other sites More sharing options...
DayRaven Posted April 12, 2016 Share Posted April 12, 2016 9 hours ago, shooter said: I meant wear other than mechanical shutter. Does electronic shutter have zero wear? No, isn't it? Does A7RII have the same wear with slowest shutter speed in video mode? Electronic shutters have zero wear. Link to comment Share on other sites More sharing options...
