JazzBox Posted August 24, 2015 Share Posted August 24, 2015 Ciao!I like to shoot as cinematic as possible and for outside shoots I bought a variable ND filter.I had some problems in few shots (mainly artifacts and green "ghost" flares) so I sold it and I started to use some fixed ND. With them I had some luck, but also some bad surprise in some wide angle scenes, such as heavy degradations in leaves, far trees and grass.All my ND were HOYA, I gave them back to the shop as used. For the moment I'm controlling the exposure outside with high angle shutter, but I'd love to shoot 1/50 as much as possible.Could you please suggest some good fixed ND? Do you think is it ok to stuck a couple of ND together?Thank you very much! Link to comment Share on other sites More sharing options...
Zak Forsman Posted August 24, 2015 Share Posted August 24, 2015 Which Hoya NDs did you have? Their ProND line is very good. But their others, not so much. If you want a variable ND, I've have very good experiences with SLR Magic's. In this video I compared it to the Tiffen VariND. mercer, kaylee, Jonesy Jones and 2 others 5 Link to comment Share on other sites More sharing options...
kaylee Posted August 24, 2015 Share Posted August 24, 2015 Which Hoya NDs did you have? Their ProND line is very good. But their others, not so much. If you want a variable ND, I've have very good experiences with SLR Magic's. In this video I compared it to the Tiffen VariND.wow thanks zak. i just started researching *variable* nds and i was looking into the slr magic for my rx10m2, do you think i would have any trouble using it with a 62-77mm step up ring? like i said ive just started investigating all this but ive already run into the weirdness of an "X" pattern at higher densities which can be exacerbated (?) by having the nd ~over~ another filter or whatever......video was so helpful!!!! Link to comment Share on other sites More sharing options...
Zak Forsman Posted August 24, 2015 Share Posted August 24, 2015 I haven't run into an X pattern with the SLR Magic yet but I know they (SLR Magic) have stated it can happen. I use it with step-up rings as well (49, 52, 62 to 77). I believe the only hesitation I have about it is that it maxes out at cutting 6 stops. And sometimes, especially on bright southern california days, I wish I could cut as many as 8 stops. kaylee and JazzBox 2 Link to comment Share on other sites More sharing options...
Inazuma Posted August 24, 2015 Share Posted August 24, 2015 What's your cameras base ISO, Zak? And what crop? Link to comment Share on other sites More sharing options...
Zak Forsman Posted August 24, 2015 Share Posted August 24, 2015 GH4 in C4K recorded externally to an Odyssey 7Q+. for day exteriors i'm usually trying to shoot at T/2.8 with ISO at 200. JazzBox 1 Link to comment Share on other sites More sharing options...
Gregormannschaft Posted August 24, 2015 Share Posted August 24, 2015 I have the Genustech Eclipse Variable ND and really, really rate it. Never really dealt with any sort of bad colour cast.http://www.genustech.tv/products/eclipse-nd-fader-77mm kaylee, iamoui and JazzBox 3 Link to comment Share on other sites More sharing options...
JazzBox Posted August 24, 2015 Author Share Posted August 24, 2015 Thank you very much to you all!I had normal HOYA, not professional,m but they were not so cheap SLR Variable looks amazing from your footage! Thank you!Do you have any suggestion for fixed ND also? Link to comment Share on other sites More sharing options...
The Chris Posted August 24, 2015 Share Posted August 24, 2015 Zak, colors look pretty good with the SLR Magic compared to the Tiffen. I had two different versions of the LCW Vari-ND (not the new thin version which is supposed to be better) and the Singh-Ray and they both had the dreaded X at about 5 or 6 stops, beyond that it was unusable for me. Gonna have to check the SLR Magic out. Link to comment Share on other sites More sharing options...
mercer Posted August 24, 2015 Share Posted August 24, 2015 I haven't run into an X pattern with the SLR Magic yet but I know they (SLR Magic) have stated it can happen. I use it with step-up rings as well (49, 52, 62 to 77). I believe the only hesitation I have about it is that it maxes out at cutting 6 stops. And sometimes, especially on bright southern california days, I wish I could cut as many as 8 stops.You use multiple step up rings to 77... Why not just a 49 to 77? Link to comment Share on other sites More sharing options...
Zak Forsman Posted August 24, 2015 Share Posted August 24, 2015 i don't use multiple step up rings. i use a either a 49, 52, or 62 to 77mm. i've got step up rings coming outta my ears. i'm silly with all these step up rings. mercer and kaylee 2 Link to comment Share on other sites More sharing options...
mercer Posted August 24, 2015 Share Posted August 24, 2015 i don't use multiple step up rings. i use a either a 49, 52, or 62 to 77mm. i've got step up rings coming outta my ears. i'm silly with all these step up rings.haha. yeah, i need to get some step up rings. for the money i spent on inexpensive variable nds, of different sizes, i could have bought that slr magic. is there a click at every stop, or just at the ends? Link to comment Share on other sites More sharing options...
BrorSvensson Posted August 24, 2015 Share Posted August 24, 2015 Sorry for off topic, but i want to purchase a 4/5 stop nd filter but do not know what to get. The main thing for me is that there is low color cast on the image. JazzBox 1 Link to comment Share on other sites More sharing options...
Damphousse Posted August 24, 2015 Share Posted August 24, 2015 Link to comment Share on other sites More sharing options...
TheRenaissanceMan Posted August 25, 2015 Share Posted August 25, 2015 For straight NDs, I like the Tiffens. Very affordable and good performers. BrorSvensson and JazzBox 2 Link to comment Share on other sites More sharing options...
Foray into 4k Posted August 25, 2015 Share Posted August 25, 2015 GH4 in C4K recorded externally to an Odyssey 7Q+. for day exteriors i'm usually trying to shoot at T/2.8 with ISO at 200. Very helpful video.How many stops are you managing in bright sunlight to shoot wide open with the f2.8's? Link to comment Share on other sites More sharing options...
Zak Forsman Posted August 25, 2015 Share Posted August 25, 2015 Very helpful video.How many stops are you managing in bright sunlight to shoot wide open with the f2.8's?need to cut about 7 or 8 stops. Link to comment Share on other sites More sharing options...
bamigoreng Posted August 25, 2015 Share Posted August 25, 2015 I started to use some fixed ND. With them I had some luck, but also some bad surprise in some wide angle scenes, such as heavy degradations in leaves, far trees and grass. All my ND were HOYA, I gave them back to the shop as used. Hoya ProND - Bryan Carnathan spotted sharpness/ghosting problem. Review: http://www.the-digital-picture.com/Reviews/10-Stop-Neutral-Density-Filter.aspx Link to comment Share on other sites More sharing options...
JazzBox Posted August 25, 2015 Author Share Posted August 25, 2015 This is exactly the problem I had with both Panasonic mirrorless and Canon DSLR. Hoya ProND - Bryan Carnathan spotted sharpness/ghosting problem. Review: http://www.the-digital-picture.com/Reviews/10-Stop-Neutral-Density-Filter.aspxThis is the problem I had with both Panasonic mirrorless and Canon DSLR. Link to comment Share on other sites More sharing options...
bamigoreng Posted August 26, 2015 Share Posted August 26, 2015 Btw, Marumi DHG ND filter works for me: http://blog.danfrei.com/2011/07/12/marumi-nd8-filter-review/ JazzBox 1 Link to comment Share on other sites More sharing options...
