Don Kotlos Posted August 27, 2015 Share Posted August 27, 2015 Just received the A7rII. Late in the night, I just mounted both cameras on the same plate with a heavy handle and did a quick & dirty IBIS test. I just moved around without trying to shake the cameras like crazy (ok maybe just a bit at some point ) . There might be some extra movement because of the stability of the rig with the cameras (but both cameras do physically move the same way). Settings are as close as possible. 1/60 f/1.4 ISO 800 WB3100. 25mm T0.95 SLRMagic + Tiffen UC3 on E-M1, 50mm f/1.4 AIS Nikon on A7RII.1080 30p Fine on E-M1, 4K FF 24p 100Mb/s on A7RII. Simple premiere edit to make the composite. No effects applied. I wanted to also compare to the warp stabilized A7RII version but only analyzing the 1.5' 4K video would take more than 30' and I would fall asleep before it was done (I now appreciate NX1's DIS a bit more, since can't imagine how much time it would take to analyze a 30' recording). Keep in mind that the DoF is different since I wanted to compare the same ISOs under shitty light. I might do another test in daylight and then the DoF will be controlled. Also the videos might seem unsynchronized but believe me they are. This is really the IBIS in action. Hope it is useful for some of you... Inazuma 1 Link to comment Share on other sites More sharing options...
Liam Posted August 27, 2015 Share Posted August 27, 2015 thanks for the test! just to be sure... which is which? Link to comment Share on other sites More sharing options...
Emanuel Posted August 27, 2015 Share Posted August 27, 2015 thanks for the test! just to be sure... which is which? In fact title should have been written in the reversal order... ; ) Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted August 27, 2015 Share Posted August 27, 2015 The one on the left is doing like 10x better whatever it is, we know em1 is great but maybe sony stepped up even more. Link to comment Share on other sites More sharing options...
Emanuel Posted August 27, 2015 Share Posted August 27, 2015 The one on the left is doing like 10x better whatever it is, we know em1 is great but maybe sony stepped up even more.Good Joke, Ebrahim! ;-) Link to comment Share on other sites More sharing options...
agolex Posted August 27, 2015 Share Posted August 27, 2015 Good Joke, Ebrahim! ;-)He wasn't joking, he was just confused by your improper/non-existent labeling of which is which. iamoui 1 Link to comment Share on other sites More sharing options...
fuzzynormal Posted August 27, 2015 Share Posted August 27, 2015 While a lot of folks will concentrate on IQ, color, DR, etc., and demand the best in that regard, I find that, for me, other features can be more practical for my productions. The built in Oly 5-axis has been really fun and rewarding to utilize. sgreszcz and Don Kotlos 2 Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted August 27, 2015 Share Posted August 27, 2015 Good Joke, Ebrahim! ;-)I am not. The only reason you might say that is you find the right one markedly better in stabilization so me saying the left is hard to believe? I'd be surprised, it looks horrible vs the left, almost no I IBIS at all vs the left actually. OP: which is which? Link to comment Share on other sites More sharing options...
Cinegain Posted August 27, 2015 Share Posted August 27, 2015 Pretty sure the Olympus stabilization is still unbeaten, so... that answers that for me.Also, Gordon Laing actually confirmed my suspicion in a recent interview.But yeah, without a definit answer, it's all just guesstimating. Don Kotlos 1 Link to comment Share on other sites More sharing options...
agolex Posted August 27, 2015 Share Posted August 27, 2015 I am not. The only reason you might say that is you find the right one markedly better in stabilization so me saying the left is hard to believe? I'd be surprised, it looks horrible vs the left, almost no I IBIS at all vs the left actually. OP: which is which? He said it: "reverse order of the video title"So left is Oly, right Sony. Comes as no surprise. Link to comment Share on other sites More sharing options...
Don Kotlos Posted August 27, 2015 Author Share Posted August 27, 2015 It didn't even cross my mind to label the video. I said that it was late in the night...But yeah left is E-M1 right is A7rII. Cinegain 1 Link to comment Share on other sites More sharing options...
Cinegain Posted August 27, 2015 Share Posted August 27, 2015 Yay. I was right. I mean, not left. So... right indeed. But not like in the test right.Maybe I should've left this alone,right? Don Kotlos, agolex and TheRenaissanceMan 3 Link to comment Share on other sites More sharing options...
Shield3 Posted August 27, 2015 Share Posted August 27, 2015 Are you absolutely sure the one on the left isn't the Sony? I see lots of strange flare that looks exactly like others get using adapters. Look closely again. Link to comment Share on other sites More sharing options...
Don Kotlos Posted August 27, 2015 Author Share Posted August 27, 2015 Are you absolutely sure the one on the left isn't the Sony? I see lots of strange flare that looks exactly like others get using adapters. Look closely again.There was no point at which I was confused as to which is which. The difference was so dramatic that I had to double check the A7rII had the IBIS on and at the correct focal length. That is why I didn't even think of labeling the footage. The flare is because of the filter that is used with the E-M1. I guess it was only clear to the ones that have used the Olympus IBIS before... I also didn't want to comment on the huge difference between the two so I wouldn't start a fight. All I can say is that I can't wait for the E-M1II to have 4K. Link to comment Share on other sites More sharing options...
Emanuel Posted August 27, 2015 Share Posted August 27, 2015 There was no point at which I was confused as to which is which. The difference was so dramatic that I had to double check the A7rII had the IBIS on and at the correct focal length. That is why I didn't even think of labeling the footage. The flare is because of the filter that is used with the E-M1. I guess it was only clear to the ones that have used the Olympus IBIS before... I also didn't want to comment on the huge difference between the two so I wouldn't start a fight. All I can say is that I can't wait for the E-M1II to have 4K. Right. But, no need! Go on post... ;-) Don Kotlos 1 Link to comment Share on other sites More sharing options...
fuzzynormal Posted August 27, 2015 Share Posted August 27, 2015 All I can say is that I can't wait for the E-M1II to have 4K. Same here. In the meantime, I've reluctantly become a little smitten with my EM5II. Once I learned the muscle memory for the egos it became a competent shooter. Not perfect, by any means, (no ISO exposure adjustment while shooting?) but a great creative tool if you wield it properly.Also, I'm discovering that shooting EM5II footage with vintage lenses really takes the edge off the video and gives it a more pleasing aesthetic, so not only is the body pretty cheap, but the lenses I'm using with it and getting the best results are as well. Don Kotlos 1 Link to comment Share on other sites More sharing options...
Emanuel Posted August 27, 2015 Share Posted August 27, 2015 You're also forgetting something most important if not from ages, at least since when a camera left the shoulders of the operator (considering a camera had left a tripod for first time some time earlier): steady hands! Link to comment Share on other sites More sharing options...
Don Kotlos Posted August 27, 2015 Author Share Posted August 27, 2015 Same here. In the meantime, I've reluctantly become a little smitten with my EM5II. Once I learned the muscle memory for the egos it became a competent shooter. Not perfect, by any means, (no ISO exposure adjustment while shooting?) but a great creative tool if you wield it properly.Also, I'm discovering that shooting EM5II footage with vintage lenses really takes the edge off the video and gives it a more pleasing aesthetic, so not only is the body pretty cheap, but the lenses I'm using with it and getting the best results are as well. Yep thats the reason for using the Tiffen UC3... Also outdoors a variable ND of questionable quality makes it even better since both act like low pass filters that take care of the aliasing. Link to comment Share on other sites More sharing options...
Cinegain Posted August 27, 2015 Share Posted August 27, 2015 Think they made it clear they want the E-M1 to be the photography flagship. Didn't even get 24p/25p.Instead, they brought out a E-M5II for the naysayers that's all about 'cinema-quality movies', 'Top-class movie performance', 'all at top-class level', 'Advanced movie features for professional level movie making', 'professional level movie editing', 'professional level movies making' and 'Functions that go beyond flagship models'.So, no, I'm not expecting the E-M1II to have 4K video or be as videocentric as the E-M5II. The E-M5III might be, but by that time they've probably hooked off anyways and leave video be to Panasonic, Sony and BlackMagic. Link to comment Share on other sites More sharing options...
Don Kotlos Posted August 27, 2015 Author Share Posted August 27, 2015 So, no, I'm not expecting the E-M1II to have 4K video or be as videocentric as the E-M5II. The E-M5III might be, but by that time they've probably hooked off anyways and leave video be to Panasonic, Sony and BlackMagic.In that case they will be pissing away on a big opportunity. In the worst case I hope they somehow improve the 1080p quality. Link to comment Share on other sites More sharing options...
