dhessel Posted September 2, 2015 Share Posted September 2, 2015 Anyone know where to get something like the lens support shown in this picture or know what it might be called? Thanks.http://i1243.photobucket.com/albums/gg541/QuickHitRecord/Lomo%20SquareFronts/Lomo_Set_2_zps1865b29d.jpg Link to comment Share on other sites More sharing options...
Hans Punk Posted September 2, 2015 Share Posted September 2, 2015 Grab a 15mm Lens or base support on eBay, then drill two holes in the riser plate to line up with the mounting holes on the square front. Then bolt together. This is what is in the picture you reference.I used central components from a base support by unscrewing the two additional plates. This gave me a adjustable plate with a square top and bottom and allowed me to fit perfectly under the squarefront. (Many stand alone lens supports have curved edge on top of the riser plate) The end result was virtually identical to QuickHitRecord's solution and worked perfectly to support the LOMO lump on 15mm rails.http://pages.ebay.com/link/?nav=item.view&alt=web&id=361205775929&globalID=EBAY-GB dhessel 1 Link to comment Share on other sites More sharing options...
dhessel Posted September 2, 2015 Author Share Posted September 2, 2015 I will give that a shot, thank you. Link to comment Share on other sites More sharing options...
dhessel Posted September 3, 2015 Author Share Posted September 3, 2015 Thanks for the tips, I ended up getting this one. I am just going to reverse it so the flat end is up and drill some holes. Thanks again.http://www.ebay.com/itm/171844700255?_trksid=p2055119.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT Hans Punk 1 Link to comment Share on other sites More sharing options...
