Dearborn Posted September 4, 2015 Share Posted September 4, 2015 I'm having a problem playing back and editing some 4k clips and realizing my computer is just too slow. I'm going to try moderate overclocking but if I had to build a new computer what would you recommend? Budget would be around 1,000. Thanks for your help. Link to comment Share on other sites More sharing options...
Rinad Amir Posted September 4, 2015 Share Posted September 4, 2015 Instead of building new pc try to work in 1080p and when u finish output it to 4k? Or mayby am wrong Link to comment Share on other sites More sharing options...
jhnkng Posted September 4, 2015 Share Posted September 4, 2015 Assuming you're not under crazy deadlines, transcoding is your friend! I ttranscode my GH4 4K footage to Prores and I can edit on a late 2012 Mac Mini, it works great. Last time I built a computer from scratch I used an i7 4770 with a Gigabyte board and 16gb of RAM, with a GTX770, and that allowed me to edit my GH4 4K natively in Premiere. No such luck in Resolve, I'd peak out at 22 fps -- I read deep in the Blackmagic forums that to edit h.264 natively in Resolve you need to throw a ton of CPU cores, so I'd have to look at 6 core or 8 core CPUs for that to work.Personally I'd go the transcoding route, and use your $1000 budget on new hard drives (you'd need them!) Mat Mayer and sudopera 2 Link to comment Share on other sites More sharing options...
Santiago de la Rosa Posted September 4, 2015 Share Posted September 4, 2015 More than 1.000 for sure, but right now, I would buy:i7 5820K 6cores Haswell E (you can overclock it to 4,5Ghz at 1.3v)Cooler: Be Quiet Dark Rock 3 (air) or Corsair Hydro (water)Mainboard: Asrock Extreme 4 X9916GB 4x4GB G.Skill Ripjaws 4 Red 2133 CL152xSSD Samsung 850 Evo 500Gb (1xsystem and programs +1xvideo files)AMD 390x 8GbBuy a good PSU (Corsair AX / HX / RM) and a Fractal Design case.1.800€You have to add the external storage that you need (2x3Tb Seagate or more) Link to comment Share on other sites More sharing options...
arellaTV Posted September 4, 2015 Share Posted September 4, 2015 What does your current build look like spec-wise? Link to comment Share on other sites More sharing options...
