Flynn Posted September 9, 2015 Share Posted September 9, 2015 One is a 35mm 2x. The other two a 50 and 70 1.33x? Link to comment Share on other sites More sharing options...
DBounce Posted September 9, 2015 Share Posted September 9, 2015 So who exactly are they targeting with these? They better be affordable if m43 mount, because pro cameras tend to be s35 or full frame. Link to comment Share on other sites More sharing options...
Zak Forsman Posted September 9, 2015 Share Posted September 9, 2015 So who exactly are they targeting with these? They better be affordable if m43 mount, because pro cameras tend to be s35 or full frame.for the price, I'm thinking somewhere south of the cost of an slr magic lens + anamorphot 2x + rangefinder. less than $2000 each? Link to comment Share on other sites More sharing options...
Caleb Genheimer Posted September 9, 2015 Share Posted September 9, 2015 Mediocre all round, tbh. 35mm on m43 is not wide, f2.8 is not fast, and m43 is not really the best sensor size format. S35 at least is preferred. Link to comment Share on other sites More sharing options...
BrooklynDan Posted September 9, 2015 Share Posted September 9, 2015 I too would rather see a full set of traditional S35-sized anamorphic PL mount lenses. Or at least in EF mount so that we could use them with a speed booster on m4/3. If that 35mm could cover Super 35, it would be a big deal. Aside from rental options, there are very few good wide-angle anamorphic lenses out there. Link to comment Share on other sites More sharing options...
Flynn Posted September 9, 2015 Author Share Posted September 9, 2015 Mediocre all round, tbh. 35mm on m43 is not wide, f2.8 is not fast, and m43 is not really the best sensor size format. S35 at least is preferred. I too would rather see a full set of traditional S35-sized anamorphic PL mount lenses. Or at least in EF mount so that we could use them with a speed booster on m4/3. If that 35mm could cover Super 35, it would be a big deal. Aside from rental options, there are very few good wide-angle anamorphic lenses out there. They say the 50 and 70 should work on full frame and they will also be showing some PL prototypes. for the price, I'm thinking somewhere south of the cost of an slr magic lens + anamorphot 2x + rangefinder. less than $2000 each?That would be incredible. I'll be shocked if you're right but if you are, WOW! Link to comment Share on other sites More sharing options...
Zak Forsman Posted September 9, 2015 Share Posted September 9, 2015 I was wrong. The 35mm 2x and 1.33x lenses are $2500 and the 50mm and 70mm lenses are $3000 each.2x Technical Data:SLR Magic ANAMORPHOT-CINE 35mm T2.4SLR Magic ANAMORPHOT-CINE 50mm T2.8SLR Magic ANAMORPHOT-CINE 70mm T4Lens Type: Anamorphic lensSqueeze factor: 2xCamera mode: 4:3 AnamorphicObjective front filter thread: Φ82Mount: micro four thirdsLens Coating: Multi CoatedClose Focus: 3’6Weight (oz./g): 47.9/1,360Length (cm): 19.25Diameter (cm): 10 Suggested aperture setting: T4-5.6Image Circle: mFT for 35mm T2.4, S35 for 50mm T2.8 and 70mm T4 MSRP : $2,499 for SLR Magic ANAMORPHOT-CINE 35mm T2.4 $2,999 for SLR Magic ANAMORPHOT-CINE 50mm T2.8 $2,999 for SLR Magic ANAMORPHOT-CINE 70mm T4 1.33x Technical Data:SLR Magic ANAMORPHOT-CINE 35mm T2.4SLR Magic ANAMORPHOT-CINE 50mm T2.8SLR Magic ANAMORPHOT-CINE 70mm T4Lens Type: Anamorphic lensSqueeze factor: 1.33xObjective front filter thread: Φ82Mount: Aluminium PL or Titanium PL compatible with optional EF adapterLens Coating: Multi CoatedClose Focus: 3’6Weight (oz./g): 38.8/1,100Length (cm): 13.5Diameter (cm): 10 Optional accessories: PL to EF adapterSuggested aperture setting: T4-5.6Image Circle: S35 for 35mm T2.4, FF for 50mm T2.8 and 70mm T4 MSRP : $2,499 for SLR Magic ANAMORPHOT-CINE 35mm T2.4 $2,999 for SLR Magic ANAMORPHOT-CINE 50mm T2.8 $2,999 for SLR Magic ANAMORPHOT-CINE 70mm T4 Flynn 1 Link to comment Share on other sites More sharing options...
DBounce Posted September 9, 2015 Share Posted September 9, 2015 I'm sure this is a great deal... For someone, but I'm gonna pass. The Rectilux core dna seems like a better, and more reasonable option. Link to comment Share on other sites More sharing options...
richg101 Posted September 9, 2015 Share Posted September 9, 2015 'suggested aperture setting: t4-t5.6' huge price for a set of lenses that need to be closed down 2 stops in order to be used on m4/3. the iscorama and a 35/2, 50/1.4 and 85/2 does all of the above and more, and can be used wide open all day long on s35! sudopera and Bioskop.Inc 2 Link to comment Share on other sites More sharing options...
sudopera Posted September 9, 2015 Share Posted September 9, 2015 I think that this is great that someone tries to bring anamorphics to the masses, but that focus ring on the front clearly an issue for mattebox users... this looks like Rangefinder implemented into lens design. Maybe I'm nitpicking here a little bit to much Also I see from Zak's writeup that PL ones with larger image circle are just 1.33x squeeze, that's a bummer because URSA Maxi / Mini will have an option to shoot 6:5 ratio and with 2x anamorphics will get true 2.4:1 desqueezed. It seems that their focus in this case is more towards 16:9 shooting cameras and I understand the reasoning behind this because there are much more of those on the market, but still I think it would be better that they made them 2x. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted September 9, 2015 Administrators Share Posted September 9, 2015 Full announcement and press release -http://www.eoshd.com/2015/09/slr-magic-announce-set-of-21-anamorphic-cinema-primes/ Link to comment Share on other sites More sharing options...
Flynn Posted September 9, 2015 Author Share Posted September 9, 2015 Maybe the price will drop a little when the Veydra 25mm 2x is released early next year, though the Veydra might be more expensive. Link to comment Share on other sites More sharing options...
DBounce Posted September 9, 2015 Share Posted September 9, 2015 Maybe the price will drop a little when the Veydra 25mm 2x is released early next year, though the Veydra might be more expensive. Think those are $5k. Link to comment Share on other sites More sharing options...
Flynn Posted September 9, 2015 Author Share Posted September 9, 2015 They said at NAB no more than $5,000 and they were hoping for a far lower price. Maybe SLR Magic has put some pressure on them to get it closer to $3,000. I'm thinking the Veydra is gonna be nicer. Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted September 9, 2015 Share Posted September 9, 2015 Kind of a Catch 22 situation going on here: Low Budget filmmakers want an all-in-one anamorphic, but they are difficult & costly to make.Judging from their previous offerings, i just don't think SLR Magic are going to deliver something that's going to have enough of the WOW factor that people are looking for, at a price that they can afford or are willing to pay.I agree with Rich here, if you're going to invest in an anamorphic lens, the Iscorama is still the go to adaptor/lens. Also, you've got to consider that by being able to pair them with different taking lenses, you can drastically change the look of your projects & so aren't stuck with one look specific look, but a variety.The market place has just been blown wide open with the Rectilux Core DNA & the SLR Rangefinder, so now Dual Focus Anamorphics have become much more user friendly - shit, you could buy a couple or more & it'll still be cheaper.I know that there aren't that many pre-36s or non-MC 36s out there, but the hype that they are the best Iscorama just does my nut in. Yes i've owned one & yes i sold it - I prefered the look of the Kowa for B&H, was prepared to endure the extra hassle & the extra cash in my pocket.Just remember that you can get MC anamorphics to flare - in the recent-ish Star Trek film they shone really powerful torches/lights into them to really get the lenses to flare in a crisp over the top way. I recently encountered this with an MC lens whilst filming a concert & I wasn't even in control of the lighting! When i've got time, i'm going to try & demonstrate this, which will hopefully dispel some of these myths.But having said all that, I do tip my hat to SLR Magic for actually making them & really hope that they have come up with the goods. Andrew Reid, richg101 and nahua 3 Link to comment Share on other sites More sharing options...
raf702 Posted September 9, 2015 Share Posted September 9, 2015 Definitely not an attractive price, although still cheaper than other true anamorphics. As stated above, you can snag all kinds of other anamorph adapters along with the SLR RG/Rectilux and still have money left over versus a set of these anamorph primes. If these were priced around $2K or under a piece, then it would have my attention, maybe that's just me. Link to comment Share on other sites More sharing options...
EddieC Posted September 9, 2015 Share Posted September 9, 2015 I am so excited about this, I'm going to buy the set. Very exciting times to be a GH4 owner!! Link to comment Share on other sites More sharing options...
ken Posted September 9, 2015 Share Posted September 9, 2015 I was told SLR lenses are made by http://www.zyoptics.net/ from China.So the price should have lots of drop space. Flynn 1 Link to comment Share on other sites More sharing options...
BrooklynDan Posted September 9, 2015 Share Posted September 9, 2015 In other news at the complete opposite end of the price spectrum:http://www.vantagefilm.com/en/news/minihawks-proof-of-performance-10456New MiniHawks from Vantage Film. Compact. High Speed. Zero breathing. Super Close Focus. The set includes a 180mm prime at a jaw-dropping T1.5. The video they made contains some of the richest, most stunning anamorphic imagery I've ever seen. They'll probably cost six figures. Per lens. Julian 1 Link to comment Share on other sites More sharing options...
elgabogomez Posted September 10, 2015 Share Posted September 10, 2015 Is it just me or those mini hawks don't seem to have "enough anamorphic look"? the 35, 40 and 50... the fact that they don't breathe, don't flare and don't have 2x anamorphic blur unless super close focus, they almost look like what you get with a filter with oval bokeh cut in front of a spherical... On the other hand, what a great focus puller work at display on that promo!! Link to comment Share on other sites More sharing options...
