BrorSvensson Posted September 9, 2015 Share Posted September 9, 2015 Hi! I really enjoy grading my photos in Lightroom and think that the tools are really straight forward, easy and fast to work with. Anyone know of a video color grading program similar to it? Link to comment Share on other sites More sharing options...
Inazuma Posted September 9, 2015 Share Posted September 9, 2015 Yes, Premiere Pro AaronChicago and Geoff CB 2 Link to comment Share on other sites More sharing options...
Don Kotlos Posted September 9, 2015 Share Posted September 9, 2015 Hi! I really enjoy grading my photos in Lightroom and think that the tools are really straight forward, easy and fast to work with. Anyone know of a video color grading program similar to it?There were a lot of people that asked the same. So now Premiere CC 2015 has the lumetri color panel that provides very similar experience to grading in Lightroom. Link to comment Share on other sites More sharing options...
BrorSvensson Posted September 9, 2015 Author Share Posted September 9, 2015 There were a lot of people that asked the same. So now Premiere CC 2015 has the lumetri color panel that provides very similar experience to grading in Lightroom. oh cool, i need to update my premiere Link to comment Share on other sites More sharing options...
AaronChicago Posted September 9, 2015 Share Posted September 9, 2015 oh cool, i need to update my premiereYeah man the newest Premiere has a great Lumetri Color Panel that is like Lightroom. 1tkman 1 Link to comment Share on other sites More sharing options...
benymypony Posted September 9, 2015 Share Posted September 9, 2015 Lightroom can edit videos, but it's not a very pleasant workflow.Otherwise you can make your settings in Lightroom on some frames from your videos and export as a LUT with Look Converter by Picture Instruments.Then you import your footage and your LUT in Premiere Pro or After Effects (...).This method is really simple and powerful, but some Lightroom options can't be exported as LUT.For example : noise reduction, vignetting, ...Hope it helps Link to comment Share on other sites More sharing options...
BrorSvensson Posted September 9, 2015 Author Share Posted September 9, 2015 Lightroom can edit videos, but it's not a very pleasant workflow.Otherwise you can make your settings in Lightroom on some frames from your videos and export as a LUT with Look Converter by Picture Instruments.Then you import your footage and your LUT in Premiere Pro or After Effects (...).This method is really simple and powerful, but some Lightroom options can't be exported as LUT.For example : noise reduction, vignetting, ...Hope it helps You cant export 60fps out of lightroom, thanks for the info Link to comment Share on other sites More sharing options...
Don Kotlos Posted September 9, 2015 Share Posted September 9, 2015 You cant export 60fps out of lightroom, thanks for the infoWhat he meant is that you can create the LUT in Lightroom (or photoshop too) that gives you the look that you want, and then use that LUT in Premiere instead of the built in color grading. Link to comment Share on other sites More sharing options...
kaylee Posted September 9, 2015 Share Posted September 9, 2015 What he meant is that you can create the LUT in Lightroom (or photoshop too) that gives you the look that you want, and then use that LUT in Premiere instead of the built in color grading. right! for me making a lut in lightroom or photoshop is a quick and easy way to make lumetri in premiere a lot more useful – i do both~! im p much just making luts to do gamut correction on my f------ bizarre slog2 footage, using that as an input lut in lumetri and having fun from there~!the real time playback in premiere w lumetri is why im trying to use it in the first place.... and bc of the the lightroom/acr simplicity that i am so familiar with regarding the op: BrorSvensson, premiere seems to be quite literally and figuratively the answer to your question as these guys have said; adobe has self consciously been adding more 'simple' color features in premiere, pushing its ultimate functionality more in the direction of speedgrade but with a bit of that lightroom easiness. im looking forward to a lumetri interface in the future that is even more like lightroom, w more power to adjust color like hue vs hue controls/etc.the weirdest thing to me about lumetri atm is the curves....... anybody else kno what im talking about here...??? the controls are... awkward. its sticky in a bad way and it just seems way too hard to drag the black and white points around.... i mean how many programs use curves lol? why cant that feel more like photoshopanyway, i fully support the continued evolution of a lumetri that is more like lightroom than speedgrade, a more acr-friendly slider interface, but considering PP 2015 is the first time lumetri has appeared i think its p cool 1tkman 1 Link to comment Share on other sites More sharing options...
ricardo_sousa11 Posted September 9, 2015 Share Posted September 9, 2015 For quite a while, I used to edit color in lightroom. My workflow would beImport all the files - color grade - export - edit in vegasNot that big of a deal, but you should def start using lumetri, is simple and after a while u get used to it. Link to comment Share on other sites More sharing options...
Shield3 Posted September 9, 2015 Share Posted September 9, 2015 Also, if you want to grade a video exactly like Lightroom (for the most part, with the ACR control panel):Use a recent version of Photoshop. Open a video file. Right click on said video, and select "Convert to smart object".Then you will see the Raw filter available from the filter menu. Quick 4 step process (obviously once graded you hit "File / Export video". The rendering process isn't too quick, but I've had good results. Michael Ma, 1tkman, BrorSvensson and 1 other 4 Link to comment Share on other sites More sharing options...
1tkman Posted September 9, 2015 Share Posted September 9, 2015 I like the look of these two Netflix shows.Are their free LUTs that would mimic or should I perform the process above (assuming this is the quickest way). Regardless, I really appreciate the post above from Sheild... it got me thinking. I also agree, Lightroom is really incredible. Link to comment Share on other sites More sharing options...
Michael Ma Posted September 10, 2015 Share Posted September 10, 2015 I wished exporting video in photoshop was a bit more optimized. I usually find that trying to color grade in photoshop directly takes forever to encode, although it's the most direct and straightforward to color grade a video with photoshop. LUTs are good if you are working with the same lighting and camera/color profile. kaylee 1 Link to comment Share on other sites More sharing options...
kaylee Posted September 10, 2015 Share Posted September 10, 2015 after rereading this thread i had to laugh its a bit ironic that all the software we're talking about is made by ~the same company~the people on this website are really smart i wish we could organize a PP 2015/Adobe feedback master thread that adobe would actually read because it would be great advice for them. its coming from smart users who often have a lot of design educationand i say this as a creative cloud subscriber~! i pay $60 a month and i want my apps to overlap more Link to comment Share on other sites More sharing options...
Asmundma Posted September 10, 2015 Share Posted September 10, 2015 For those on FCPX - use ColurFinale plugin - If use have Track X, it also possible to do tracking, in addition to FCXP shape tools- A very good video can be found here by Denver Riddle Link to comment Share on other sites More sharing options...
Michael Ma Posted September 10, 2015 Share Posted September 10, 2015 after rereading this thread i had to laugh its a bit ironic that all the software we're talking about is made by ~the same company~the people on this website are really smart i wish we could organize a PP 2015/Adobe feedback master thread that adobe would actually read because it would be great advice for them. its coming from smart users who often have a lot of design educationand i say this as a creative cloud subscriber~! i pay $60 a month and i want my apps to overlap more Definitely room for adobe here to improve the way people want to use it. I like many, know how to do my best work with Adobe Camera RAW, can only do minor adjustments with RGB curves and Levels. Would love ACR filter optimized to work in Premiere Pro. kaylee 1 Link to comment Share on other sites More sharing options...
BrorSvensson Posted September 10, 2015 Author Share Posted September 10, 2015 Also, if you want to grade a video exactly like Lightroom (for the most part, with the ACR control panel):Use a recent version of Photoshop. Open a video file. Right click on said video, and select "Convert to smart object".Then you will see the Raw filter available from the filter menu.Quick 4 step process (obviously once graded you hit "File / Export video". The rendering process isn't too quick, but I've had good results.Gonna give that a shot Link to comment Share on other sites More sharing options...
samuel.cabral Posted December 5, 2015 Share Posted December 5, 2015 Hello, @benymypony.Can you tell how useful are these LUTs created with Look Converter by Picture Instruments?I mean.. if i've created a LUT using a VSCO preset for Lightroom what would be the best workflow to apply it?First i should make all my footage look flat (like log or raw) than apply it?I just don't understand how this LUT could useful to any camera if different brands have different colors.Hope someone can explain it to me.Thanks! Link to comment Share on other sites More sharing options...
SR Posted December 5, 2015 Share Posted December 5, 2015 I tried working on some cinemagraphs with 1080p footages on Photoshop and, despite my Skylake i7 + 960m laptop, I had to give up exporting. It was just taking too damn long. Link to comment Share on other sites More sharing options...
benymypony Posted December 5, 2015 Share Posted December 5, 2015 Hello, @benymypony.Can you tell how useful are these LUTs created with Look Converter by Picture Instruments?I mean.. if i've created a LUT using a VSCO preset for Lightroom what would be the best workflow to apply it?First i should make all my footage look flat (like log or raw) than apply it?I just don't understand how this LUT could useful to any camera if different brands have different colors.Hope someone can explain it to me.Thanks! Hi, LUTs created with Look Converter are good. Files are light (around 60Ko, when the original 3D 64 LUT is 7Mb) because LUT generated is a 3D 17 LUT.The higher is the LUT (8, 17, 32, 64, ...), the more there is color accuracy.Look Converter will generate a neutral filter (like the attached file).You'll have to load this neutral filter image into Lightroom (or even Instagram) and apply your presets.Then, Look Converter will generate a LUT from the difference between the neutral filter color values and the modified one.Let me know if it's not clear Link to comment Share on other sites More sharing options...
