Adobe Lightroom-like video colorgrading
BrorSvensson
Hi, LUTs created with Look Converter are good. Files are light (around 60Ko, when the original 3D 64 LUT is 7Mb) because LUT generated is a 3D 17 LUT.The higher is the LUT (8, 17, 32, 64, ...), the more there is color accuracy.
Look Converter will generate a neutral filter (like the attached file).
You'll have to load this neutral filter image into Lightroom (or even Instagram) and apply your presets.
Then, Look Converter will generate a LUT from the difference between the neutral filter color values and the modified one.
Let me know if it's not clear ^_^
It was clear on how to create my own lut with the program (thank you for that!), but it wasn't clear to explain on what kind of image i could use that.
As example of my question, imagine if i have a timeline with a7s images (not s-log) and a gh4. What do a have to do before applying this LUT on images of both cameras?
What's the best starting point to use this kind o luts?
Thank you!
