50fps to sync with audio
tokunbo
Right click source footage in project > interpret footage > change clip to 50fps.
Assuming you shot 50p with onboard audio from camera, you need to (presumably) reach 25fps with sync audio. So interpreting the footage to playing back at 50fps on a 25fps timeline will effectively give you normal (realtime) playback with sync sound. Speeding up the video clip by 200% will also work the same.
If this does not work, please give more detail (camera type and project settings in premiere).
From your limited description I'm assuming you need the realtime playback to be 25fps PAL and it sounds like you need to tell premiere that for the interview section you want the 50p to play back at 25p?
